Old 12th October 2013, 08:58   #1  |  Link
lulalala
FFmpeg lossless rgb input/output command
I have successfully used x264.exe and avisynth to encode/decode RGB bmp images losslessly, using the following command:
x264 --crf 16 --bframes 0 --colormatrix GBR --qp 0 --preset placebo --range
pc --input-range pc --input-csp rgb --output-csp rgb -o "%2" "%1"
However I want to switch to using FFmpeg.exe to do the encoding (because avisynth does not support unicode). How can I do this? What is ffmpeg's equivalent of the command above?
I have tried this but it does not work:
ffmpeg -i "%1" -c:v libx264 -pix_fmt yuv444p -preset
veryslow -qp 0 "%2"
thanks.
lulalala is offline   Reply With Quote
Old 12th October 2013, 12:55   #2  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
ffmpeg.exe -i "RGB_source.avi" -c:v libx264 -qp:v 0 -profile:v high444 -pix_fmt yuv444p "444_out.avi"
raffriff42 is offline   Reply With Quote
Old 13th October 2013, 14:16   #3  |  Link
lulalala
Sorry I just tried your solution, but it still shows a difference.
I am wondering if you can take a look. I have packed my test. Running test.bat will do the encoding/decoding/compare and the diff image will be save at o2/diff.bmp
https://mega.co.nz/#!qchAxLBQ!cLt4TE1ggGD6OLilCkkBRgGcTXANIIif7fGkwBIInRc
Thanks a lot
Old 13th October 2013, 15:30   #4  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
[DEL]IIRC, FFmpeg currently doesn't support RGB H.264 output with libx264 yet (correct me if I'm wrong). It'll convert RGB24/BGR24 to YUV444P before feed to libx264, maybe that's why there's a difference.[/DEL]
EDIT: I'm wrong. You can output RGB H.264 with this command line:
ffmpeg.exe -i %RGB_Source% -c:v libx264rgb -qp 0 -pix_fmt rgb24 %Output%
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain
the_weirdo is offline   Reply With Quote
Old 13th October 2013, 16:01   #5  |  Link
poisondeathray
I don't think ffmpeg libx264 can encode RGB (and you will have lossess during the RGB=>YUV conversion).
You can use use some other lossless RGB codec in ffmpeg eg.. FFV1 or UTvideo which also supports RGB
I was going to suggest piping ffmpeg to x264, but yuv4mpegpipe doesn't support RGB either (not aware of any rgb4mpegpipe)
Old 13th October 2013, 17:52   #6  |  Link
Reino
Reino's Avatar
Exactly, the_weirdo:
ffmpeg.exe -i <rgb-source> -pix_fmt bgr24 -c:v libx264rgb -preset veryslow -qp 0 <output>
The RGB Matrix coefficients are added automatically, so there's no need to specify that. But...speaking of which, and this might be a bit off-topic, but how can one set those in FFMpeg? RGB as it turns out doesn't need them to be set, but YCgCo does! The only way to set matrix coefficients in FFMpeg that I know of is by using -x264opts colormatrix=YCgCo, but doesn't FFMpeg have such a VUI-option of its own? -colorspace 8 doesn't seem to work at least.
Another thing I'm really puzzled about is how to specify input- and output range as PC with FFMpeg.
ffmpeg.exe -i <YCgCo-source> -pix_fmt yuv444p -c:v libx264 -preset veryslow -qp 0 -color_range 2 -colorspace 8 <output>
Output #0, matroska, to 'D:\rgb_test(ffmpeg,q0,YCgCo).mkv':
  Metadata:
    encoder         : Lavf55.19.100
    Stream #0:0: Video: h264 (libx264) (H264 / 0x34363248), yuv444p(pc, YCgCo), 640x480, q=-1--1, 1k tbn, 25 tbc
As you can see, as a result of -color_range 2 -colorspace 8, FFMpeg's output even suggests the file would be full-range with a YCgCo VUI-matrix, but in reality will be tv-range and no VUI-matrix, which MadVR detects as BT.601.
Sorry for being off-topic, but am I doing something wrong, or is FFMpeg limited or something?
My hobby website
Reino is offline   Reply With Quote
Old 13th October 2013, 17:58   #7  |  Link
poisondeathray
EDIT: ahh I see it's libx264rgb , not libx264
Old 13th October 2013, 18:46   #8  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
@CoRoNe
It seems that FFmpeg doesn't pass those VUI-options to libx264. You still need to use -x264-params for that (it doesn't recognize "range" option, but you can use "fullrange=on").
Last edited by the_weirdo; 13th October 2013 at 18:50. Reason: for some reason, fullrange=on doesn't work with x264opts
Old 13th October 2013, 18:57   #9  |  Link
Reino
Reino's Avatar
I know, with -x264opts fullrange=on:colormatrix=YCgCo FFMpeg at least doesn't throw in an error, but fullrange=on doesn't do anything.
My hobby website
Old 13th October 2013, 19:00   #10  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
Yes. I've also noticed that. However, it works with -x264-params for some reason.
Old 13th October 2013, 19:27   #11  |  Link
Reino
Reino's Avatar
Haha, you're right! Great find!
That's some strange behaviour. Especially since fullrange isn't a valid x264.exe-command anymore. And I didn't expect there to be any differences between -x264opts and x264-params.
My hobby website
Old 17th October 2013, 02:54   #12  |  Link
lulalala
Sorry for the late reply. Thank you! Both
and
works.
Just want to ask, is -pix_fmt rgb24 the same as -pix_fmt bgr24 ?
Old 17th October 2013, 13:19   #13  |  Link
Reino
Reino's Avatar
BGR24 is the default format. Afaik the difference is only a byte order, but maybe someone more knowledgeable could comment on this.
My hobby website
ffmpeg, lossless, rgb, x264
