Old 29th December 2008, 15:24   #161  |  Link
flebber
Practising Schemer
HI I like the GUi. Can I ask do you have a prefered build of x264?
I ask because I downloaded two versions of x264 1063 and 996 from http://x264.nl/ but when I went to encode with your gui they ran slow quoting me times of 100hrs +.
So I copied the current x264.exe Megui is using and put that in the leiming.exe directory in place of the other versions. And normal quick encoding is back, it will take about 15 minutes at 5.2 fps (its only a small file). So this leads me to think that certain versions or build types work better. Do you have any ideas or preference ?
Quick second question how do I get the video output to be mkv by default?
flebber is offline   Reply With Quote
Old 10th February 2009, 11:00   #162  |  Link
lion09503
why is it that the audio is the only one that encodes
lion09503 is offline   Reply With Quote
Old 10th February 2009, 13:35   #163  |  Link
DarkZell666
aka XaS
DarkZell666's Avatar
Would you mind explaining a bit more clearly what you mean ?
Do you mean you have a black picture ? Or that you only have one audio track when you had two in the source video ? Something else ?
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS
DarkZell666 is offline   Reply With Quote
Old 14th February 2009, 05:48   #164  |  Link
lion09503
what i mean is that if i insert a video to encode and start the encoding the audio is the only one that encodes and the video won't be encoded
Old 14th February 2009, 09:57   #165  |  Link
DarkZell666
aka XaS
- What format is the source video ? (ie: xvid+mp3 in avi ? x264+aac in mp4 ? etc.)
- Do you have good codecs installed ? (ie: ffdshow-tryouts and Haali's Media Splitter ?)
Edit : it turns out you need to choose an item in the "AVS script" dropdown box to load your source file correctly.
You can add more AVS templates in the avsinc folder. I believe an extra one like this would also be helpful, since all the directshow-based scripts bundled with the app have convertfps=true with a specific fps value :
directshowsource(fs)
converttoyv12()
ConvertAudioTo16bit()
Old 18th April 2009, 12:25   #166  |  Link
leiming2006
leiming2006's Avatar
It's the last version.
leiming2006 is offline   Reply With Quote
Old 18th April 2009, 12:34   #167  |  Link
buzzqw
HDConvertToX author
it's sad. Any particular reason for saing last ?
i hope anyone knowing PB get the source code and work on it
thanks for your work leiming2006!
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 8th July 2009, 19:06   #168  |  Link
vampiredom
Hi -- Does anyone know of any good Blu-Ray presets for this GUI? Being new to x264 encoding, is there a way to specify interlaced vs. progressive encodes? Thanks.
vampiredom is offline   Reply With Quote
Old 10th June 2011, 14:37   #169  |  Link
Miras
Bielizna
The software allows encode the parallel on several computers?
8) BaGRoS 8)
Bielizna damska i posciel
Miras is offline   Reply With Quote
