24th September 2018, 12:22 | #16121 | Link | |
"Server1CommandLine=/port 1000 /minimize /priority low" |
24th September 2018, 12:53 | #16122 | Link |
/priority low sets EncodingServer.exe,ffmpeg.exe,x264.exe,x265.exe
so my suggestion is to manually change priority for encodingserver.exe from low to high. Rest of encoding processes (ffmpeg and so on) will be running in normal priority (because child processes can't inherit higher priority from parent).
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 24th September 2018 at 13:13. |
24th September 2018, 13:16 | #16123 | Link | |
Just got newest auto update with new core & encoder build's. So just confirm, (I just went into Process Hacker to have a look for myself), so once the priority is changed, then save for encoder.exe, to lock it in. |
24th September 2018, 13:23 | #16124 | Link |
Encoding Server Startup Crash on Latest Update
Updates just applied and I'm receiving a error when starting up the EncodingServer.exe. Error: List index out of bounds (0)
I've updated two different servers and both are receiving the same errors. |
24th September 2018, 13:39 | #16125 | Link | |
Haven't given the latest update a "proper" run. |
24th September 2018, 14:36 | #16127 | Link | |
ByteShare
24th September 2018, 19:38 | #16129 | Link | |
ByteShare
Stuck using the 1.12.1.0 debug version right now, since I didn't have a backup of the official 1.12.1.0 Last edited by byteshare; 24th September 2018 at 20:22. |
24th September 2018, 19:48 | #16130 | Link | |
ByteShare
This is a Win10 Machine, the same one that I went from 4 to 2 encoding servers. Not sure why it stalled. Running the Priority High change now... Last edited by byteshare; 24th September 2018 at 19:50. |
25th September 2018, 02:24 | #16131 | Link | |
If anyone is interested in trying to solve this, I'd be happy to to receive your help. As it is, whenever I try a simple batch job , every other file loaded (the even numbered jobs) results in a "Job Rejected" message. The log file states "I don't know what YV12 means" but, apparently, it does "know" what YV12 means because the odd numbered jobs process fine. |
25th September 2018, 02:42 | #16132 | Link | |
Back to the drawing board
http://www.mediafire.com/file/5y5qwn...pdate.jpg/file This is on W10 (1809) RS5. Changing Encoder priority doesn't change anything either. The only thing that does do anything is if you disable DE, which isn't really a good option So definitely back to the drawing board !!!!! Well, I have an interesting update to share.. I get this above error on both Windows 10 Pro (1809), and Windows Server 2016 Datacentre....which are both single cpu pc's. (No NUMA) and the only way to get rid of the error is to go back to the previous build of encoder.exe. However, the error does NOT occur on Windows 10 Enterprise (1809), but this pc is a dual "old" Xeon X5690 with NUMA Nodes enabled. So I'm just trying to give some options to what might be the problem. Haven't tried in on the W7 pc, yet. Just tried it on my little DELL laptop, with some DE servers enabled, on W7...no problem. I get all the updates on this, and copy them around all the other pc's I've got. OK, yet another update...just tried it on the W7 dual "old" Xeon pc, and has the same error So you either have to do 1 of 2 things, replace the encoder.exe with previous, or disable DE. Last edited by burt123; 25th September 2018 at 07:04. Reason: more info after testing |
25th September 2018, 22:58 | #16134 | Link | |
ByteShare
26th September 2018, 17:38 | #16135 | Link |
New update, new error
Established connection with client... 192.168.1.3:1003 ERROR! File \\192.168.1.3\RipBot264temp\job228\Chunks\21.cmd does not exist! Encoding terminated. Connection Closed Gracefully. ERROR! File \\192.168.1.3\RipBot264temp\job228\Chunks\21.cmd does not exist! Encoding terminated.
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
26th September 2018, 17:52 | #16136 | Link |
Change Client ip
26th September 2018, 23:56 | #16138 | Link | |
ByteShare
Doesn't seem to have fixed the not starting an encode (getting stuck at starting). Over all seems in a better place. And now, for some reason, I can't connect from one computer to another, but I can when using the 1.12.1.0 Test Debug version. I've turned off Windows Firewall on both computers while testing this. Both are Windows 7 machines. I think the newer version for some reason isn't registering the port correctly because if I start the Debug version either before or after the 1.12.2.0 it will still use the same ports. And I have tried a Reboot on both machine. |
27th September 2018, 02:06 | #16139 | Link | |
I've yet to try this update !!! |
27th September 2018, 06:23 | #16140 | Link |
Will this have to be changed every time you open/re-open Ripbot, if you have multiple nic's/IP's ??
I think I've answered my own question...and yes, it does appear to remember Last edited by burt123; 27th September 2018 at 06:48. |
