2nd October 2009, 15:10 | #441 | Link |
Using aacskeys
I've been trying to get this program to run, but can't get past error message: "Could not open file c:\\ProcessingDeviceKeysSimple.txt Error: Process MKB, error: -1
when I attempt to run from the command function. My aacskeys folder is under my C: directory and the above mentioned txt file is directly under the aacskeys folder, not under a sub folder. Based on what I've seen in the forum archives, that is correct. Confused??? Can anyone enlighten me?? |
2nd October 2009, 19:51 | #443 | Link |
aacskey
Thank you for your prompt response. However, I'm still confused as to where to put the text file. Here's the file config I've presently got:
Local Disk (C aacskeys-o.4.0 (folder) bin (folder) win 32 (folder) aacskeys.exe (app file) ProcessingDeviceKeysSimple (text file) My command line from the C prompt in DOS is as follows: c:\aacskeys-0.4.0\bin\win32\aacskeys.exe e Where the last e is the drive. When I run this command, I get the error message in my last message. What am I doing wrong here?? |
2nd October 2009, 20:57 | #446 | Link |
aacskeys looks for the Processing Key file and the Host Certificate file in the current working directory, thats the directory from where you issue the command. In your example this is C:\, apparently this is not the directory where these files reside, they are in aacskeys-0.4.0, so you have to change into that directory first.
Your steps should look like this: Code:
C:\Users\KenD00> cd c:\aacskeys-0.4.0 C:\aacskeys-0.4.0> bin\win32\aacskeys e |
3rd October 2009, 02:00 | #447 | Link |
I had the same issue http://forum.doom9.org/showthread.php?t=149727
Place the ProcessingDeviceKeysSimple.txt here C:\ ProcessingDeviceKeysSimple.txt right where the error is telling you it's missing and ALSO the same folder as aacskeys .exe and all will be well Last edited by HOGGER; 3rd October 2009 at 02:06. |
3rd October 2009, 04:09 | #448 | Link | |
3rd October 2009, 14:28 | #449 | Link |
aacskeys
Thanks KenD00 for the feedback.
Yes, by using your syntax, I can get the command file to work. However, now I'm getting an error message "c:\aacskeys-0.4.0\bin\win32\aacskeys.exe is not a valid Win32 application." I've also noticed that when I click on the aacskeys.exe file from Windows, I also get the same error message. It seems to me that earlier when I did that, I got a flash of the Command file on the screen. Not sure whats up all of sudden. Maybe I should delete and reload aacskeys files? |
3rd October 2009, 15:32 | #450 | Link | |
I eventually got lazy and cut and pasted the path in command prompt and than ran the exe Guess that is where I made my mistake |
3rd October 2009, 16:09 | #451 | Link |
aacskeys
KenD00
Thanks for your assistance in this issue. I got it going by reloading the aacskeys files. It now runs, but I get an error message as attached. Reading through some of the archives, I see this may be related to drive patching? |
5th October 2009, 07:44 | #452 | Link |
Hmm, the recent Host Certificate should work for all known MKB versions, are you using the 0.4.0c release?
What MKB version does the disc have that you are using, and is this the newest disc you ever played back with that drive? Run aacskeys in verbose to get the MKB version of the disc, like Code:
aacskeys -v e |
7th October 2009, 11:47 | #455 | Link |
Well, uhhh, of course, you are just supplying some different command line arguments...
Ok, it looks like you have not really an idea of what are you doing here so basically i wonder what are you actually trying to achieve? With the recent Host Certificate there is again a much more unexperienced user friendly free way to decrypt your HD-DVD / Blu-Ray - recent BD+ discs (read: after the initial setup insert a disc and press 5 buttons) available, maybe this is the better solution for you. |
17th December 2009, 07:50 | #456 | Link |
what is agid? what is it used for?
i trace aacskeys on windows xp, i have no blu-ray drive, i use daemon tools instead, my iso is aacs protected, but it is failed to get agid. what is agid? what is it used for? why it error? any helps would be thanks.
aacskeys.exe -va k aacskeys 0.4.0 by arnezami, KenD00 Current path: E:\work\dvd\tools\aacskeys\aacskeys-0.4. 0c MKBv: 1 Processing key: 09F911029D74E35BD84156C5635688C0 Encrypted C-value: D4CCD72D8986CCA08A736A151A3FACD3 Corresponding uv: 00000001 Decrypted C-value: EEAE604BAC9FDF681EF4C36C840E7618 Media key: EEAE604BAC9FDF681EF4C36C840E7619 Encrypted verification data: 6E7813E65978F033DC5A71B709F82398 Decr verif data should be: 0123456789ABCDEF Decrypted verification data: 0123456789ABCDEF3A1A2A8290AE5A52 Drive FW info: 1.03 AACS Version: 00 Number of concurrent AGIDs: 0 Supports BN generation: NO BN Block Count: 0 Inserted medium AACS protected: NO Host Private Key (Hpriv): 8C8647FE2A70EF0388EA9E43F432CC441C6B108C Host certificate (Hcert): 0200005CFFFF000000AE00004142A5411F1E63F1 85581C876B939FB40B523BF69C004CA69E047606 EE5183C0ABEF1E7D04CB6E65260677E7B0573D08 E60957935503ED78F7E27B190B4A7CAFCBAFF4A2 836453ECF72E49668DAF1DB9 Host Nonce (Hn): 2923BE84E16CD6AE529049F1F1BBE9EBB3A6DB3C All AGIDs in use. ERROR: AGID: SK: 0x5, ASC: 0x24, ASCQ: 0x00, errnr: -2 Last edited by ttwater; 17th December 2009 at 07:52. |
17th December 2009, 12:10 | #457 | Link |
ttwater, you cannot do what you are trying to do. Each AACS-protected disc has a "host protected area" that the drive itself will refuse to deliver to the desktop PC directly. When you copy a blu-ray disc to an ISO image you don't get the data from the host protected area. The missing data must be read in a special way from the drive when the original blu-ray disc is inserted. I'm sorry, but the image you have is useless unless you already have the disc keys.
18th December 2009, 03:57 | #458 | Link | |
your mean is that the daemon tools + iso environment is different from the blu-ray drive + blu-ray disk, now i have a new question, What is stored in the "host protected area"? What is it used for? what is its function? thanks again... |
18th December 2009, 06:54 | #459 | Link |
It contains the decryption key for the protected blu-ray video data. If you have the key already then you can decrypt the video. I believe AnyDVD HD comes with a large database of known keys, so it would be worthwhile for you to download and install it to see if it can handle your particular disc image.
18th December 2009, 09:49 | #460 | Link | |
Yes, AnyDvd works well, but I want to achieve the same function without AnyDvd. it seems impossible, maybe i should give up. Rupan, do you have any suggestions? |
