23rd March 2010, 14:05 | #221 | Link |
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
26th March 2010, 19:32 | #222 | Link |
@_hawk_
you gonna include a all inclusive tools package .7zip for the next release? how is coding coming along i see you've been busy keep it up buddy the buzz is spreading just like i told you x64 bit support in the video community is getting better thanks Windows 7
26th March 2010, 20:01 | #224 | Link | |
Aviysnth64 users need this beta of haali media splitter otherwise they won't be able to split VC-1 (latest release) or won't have a 64 bit splitter. There's no real easy way to check the version other than to calculate crc or check the file modified date for Feb 1, 2009. They'll also need 64 bit decoders like ffdshow64. You can check for this by checking for AMD64 in %PROCESSOR_ARCHITECTURE% and registry for HKLM\SOFTWARE\GNU\ffdshow64. Piping 32 to 64 bit with avs2yuv or vfw4x264 is always slower then 32 bit if using faster then --preset fast with slower settings it can be up to about 15% faster with placebo but default x264 settings is only about 5% faster. Whereas avsiynth64 is just as fast for the fastest x264 settings and with heavy filtering and slow x264 settings expect up to about a 40% speed increase, x264 default is about a 10% speed increase. |
28th March 2010, 00:38 | #227 | Link |
@blubberbirne
it's a test version stable should be available on google code soon stay tuned
28th March 2010, 21:41 | #228 | Link |
28.03.2010 22:25 Uhr MESZ 1001 downloads of BluRip
http://code.google.com/p/blurip/downloads/list Congratulations and a huge Thank You to _hawk_ |
29th March 2010, 14:26 | #229 | Link | |
BluRip author
2) You can use a 2-pass profile but have to calc the bitrate yourself. I plan to add a bitrate calculator later.
BluRip : 1-Click BluRay/m2ts to h264 mkv converter http://code.google.com/p/blurip/ |
29th March 2010, 17:27 | #231 | Link |
BluRip author
So you would like to enter crop/resize values manually? Or something else?
30th March 2010, 01:09 | #232 | Link |
i personally dont see the need to enter manual crop sizes. i see it as either you want it cropped or you dont. if you do then the autocrop feature works just fine. if you dont i would like to see an option to simply disable autocropping and leave the material as is.
30th March 2010, 04:30 | #234 | Link | |
Banned
Not getting too far - couldn't open the program after downloading:
30th March 2010, 08:59 | #236 | Link |
BluRip author
You will need .NET 3.5 + VC++2008 runtime. Atm I don't use any 3.5 specific features so it would be easy to switch to 2.0.
30th March 2010, 18:23 | #238 | Link | |
BluRip author
But I think that more and more programs will use 3.5 so you will have to install it sooner or later..
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264 |
