28th August 2018, 02:09 | #682 | Link |
You can't, nor UTVideo. DaVinci Resolve doesn't support third-party VFW codecs per se. The only system-supported, 'near/visually lossless' AVI codecs are Cineform and Grass Valley HQ/HQX. Otherwise the same in Quicktime (MOV) format, along with DNxHD, DNxHR and ProRes. DNxHD and DNxHR in MXF format also. Take your pick.
Nostalgia's not what it used to be Last edited by WorBry; 28th August 2018 at 02:22. |
28th August 2018, 15:43 | #683 | Link | |
29th August 2018, 01:45 | #684 | Link |
Thought I'd been clear. The only option for 'lossless encoding', whether transcoding for input (using Resolve's own Transcode function) or rendered output, is uncompressed. What is your video source material, out of interest ?
BTW, ProRes encoding is only available in the Mac version, but the Windows version will accept ProRes input. Edit: I see the Studio (purchased license) version of Resolve 15 now supports Kakadu-based lossless JPEG 2000 encoding.
Nostalgia's not what it used to be Last edited by WorBry; 29th August 2018 at 02:22. |
29th August 2018, 07:33 | #685 | Link |
Angel of Night
If you're in production, you should give up the idea of a lossless intermediate at all stages. The storage and throughput requirements will absolutely kill you, even if you did use software that gave you the flexibility. Grass Valley (Canopus) HQX Superfine is an amazingly good codec that not only holds up to repeated re-encoding, but to extensive transformation between re-encodings. Cineform is great too, but HQX Superfine gives you double the bitrate for the perfectionist in you. The occasional off-by-one, especially in 10-bit, really isn't worth 10x the storage space.
What you really need to worry about is your HDR format and coverage. That's what's going to get you. |
29th August 2018, 16:40 | #687 | Link | |
Cineform's "issue" is that sometimes pre-compressed sources are getting encoded with fairly low bitrate, even for best setting. Good part- it keeps PSNR very steady, so all frames have relatively same quality. These ares results for never compressed shot on film STEM DCI test footage (going from v210, back to v210 without any RGB on the way): Cineform FS2: PSNR y:56.9 u:57.0 v:58.5 Average: 57.3 dB Min: 56.6 dB Avg bitrate: 226Mbit Cineform FS1: PSNR y:50.6 u:50.9 v:54.1 Average: 51.3 dB Min: 49.9 dB Avg bitrate: 136Mbit ProResHQ PSNR y:55.1 u:55.7 v:57.7 Average: 55.8 dB Min: 46.5 dB Avg bitrate: 172Mbit GV HQX (Q=0, S=100) PSNR y:56.0 u:53.9 v:58.3 Average: 55.8 dB Min: 52.6 dB Avg bitrate: 219Mbit DNxHR HQ PSNR y:54.0 u:53.9 v:55.5 Average: 54.3 dB Min: 45.2 dB Avg bitrate: 176Mbit DNxHD HQ PSNR y:53.3 u:50.7 v:53.9 Average: 52.6 dB Min: 43.5 dB Avg bitrate: 176Mbit XAVC-I 200 PSNR y:53.2 u:51.2 v:54.3 Average: 52.8 dB Min: 44.3 dB Avg bitrate: 183Mbit ProResXQ 444 (converted back to 10bit 422) Avg y:62.5 dB Min y:57.6 dB Avg bitrate: 378Mbit Last edited by kolak; 29th August 2018 at 16:43. |
29th August 2018, 21:13 | #690 | Link |
That's interesting. Just ran some Cineform (Best=FilmScan 2) and GV HQX (Best) transcodes, both AVI and MOV, from a 10-bit 422 source using Resolve's transcode function. Indeed, Resolve reports all four transcodes to be 10-bit, according to Clip Details. Yet, MediaInfo reports 8-bit for the GV HQX AVI transcode (and no bit depth at all for the other 3).
Nostalgia's not what it used to be Last edited by WorBry; 29th August 2018 at 21:41. |
29th August 2018, 23:58 | #693 | Link |
Yep, it's proper integration (also on Linux if I'm correct), but Resolve and Edius are about the only apps where you can import/export HQX at 10bit.
There is workaround for AE also (+decoding in ffmpeg). Not big choice of apps though. You better of using DNxHR which is also good and has RGB and YUV modes for 4:4:4. It also supports 12bit for 4:4:4. Cineform 4:4:4 mode is always RGB and ProRes 4:4:4 is always (95% sure) YUV+ 12bit is not really kept. It's more like 11.5 bits (at least in my test in AE and Resolve). Last edited by kolak; 30th August 2018 at 00:01. |
30th August 2018, 16:02 | #695 | Link |
Don't ask for best or you will get banned.
It's your choice- what works for you. DNxHR or ProRes depending on the OS are good choices. Do you need near lossless? What is your source, what you do with it in Resolve and what are you going to do with it after export? Lossless or intermediate codecs are used to provide high quality end master which is later used further eg. passed to 3rd parties for further transcoding for web etc. Last edited by kolak; 30th August 2018 at 16:05. |
30th August 2018, 16:16 | #696 | Link | |
Then I load it to AvsPmod, then i will write the filterchain (Convertbits 10bit -> 8bit, dirty.lines fix, crop, resizemod, etc..). Then encode it with x264. Last edited by preludium975; 30th August 2018 at 16:17. Reason: spelling fix |
30th August 2018, 16:29 | #697 | Link |
DNxHR HQX or Cineform (best quality setting) will be good enough.
Is Resolve HDR to SDR conversion any decent? I think you may get as good results natively in avs or vs and avoid whole Resolve route. |
31st August 2018, 00:00 | #698 | Link |
Interesting observation here also:
https://forum.blackmagicdesign.com/v...434432#p434432 I can see I've going to have to install the Grass Valley VFW codecs again to satisfy my curiosity about this.
Nostalgia's not what it used to be |
31st August 2018, 10:52 | #699 | Link |
Not much to satisfy- HQX VFW codec is 8bit on input/output and that's about it
It has been like this from the beginning and unlikely to change. GV is not really interested to provide new version. Edius is actually dying. |
4th September 2018, 22:11 | #700 | Link |
I tried DNxHR HQX and GoPro CineForm. All of them, after exporting, at 30 seconds-1 minute intervals duplicate frames. Like fps drop, but not fps drop, its just sometimes duplicate frames.
Here is a test encode for example, at 00:43-00:47. here Who has an idea? |
