Old 22nd January 2013, 01:24   #81  |  Link
SAPikachu
SAPikachu's Avatar
Yes, enable10bithack will automatically convert source to 16bit for easier previewing, so you should specify input_depth=16 in f3kdb/f3kdb_dither.
f3kdb 1.5.1 / MP_Pipeline 0.18
ffms2 builds with 10bit output hack:
libav-9a60b1f / ffmpeg-1e4d049 / FFmbc-0.7.1
Built from ffms2 6e0d654 (hack a9fe004)
Mirrors: http://bit.ly/19TwDD3
SAPikachu is offline   Reply With Quote
Old 22nd September 2013, 14:57   #82  |  Link
leoenc
With enable10bithack I'm getting a double height frame (1920x2160). I tried both progressive and interlaced sources, and AVC-Intra and DnxHD sources. I tried ffms2-9417b9c-libav-aca2510 and ffms2-r734-libav-e6160bd.
The bottom 1080 part is filled with colorful blocks and cropping resolves the issue.
Is that expected behavior?
leoenc is offline   Reply With Quote
Old 22nd September 2013, 19:52   #83  |  Link
cretindesalpes
cretindesalpes's Avatar
Yes, it’s the “stack16” 16-bit format. Use DitherPost() if you want to go back to 8 bits, or don’t set enable10bithack.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding
cretindesalpes is offline   Reply With Quote
Old 23rd September 2013, 07:00   #84  |  Link
leoenc
Ok, thanks
Old 23rd December 2015, 04:32   #85  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
It seems this version of FFM2 doesn't support VP9 videos, while the official version does.
MysteryX is offline   Reply With Quote
avisynth, black frames, detecting, dnxhd, mov
