Old 28th June 2012, 19:02   #1  |  Link
ssuave
ssuave's Avatar
Bitrate of each frame in a H.264 file?
I wonder how can we compute/extract bit-rate for each frame of an H.264 encoded video file?
Parse the bit-stream somehow and then collect this info but how?
Any ideas/hints on it?
Thanks!
ssuave is offline   Reply With Quote
Old 30th June 2012, 13:29   #2  |  Link
Ma-Xell
Somewhere Back in Time
Ma-Xell's Avatar
Bitrate is usually specified in kbit or mbit per second and if your video is for example 25 frames in a second, then its very simple.
This of course would give the average for one frame across the whole video.
But why would you need this info?
Ma-Xell is offline   Reply With Quote
Old 30th June 2012, 13:36   #3  |  Link
ssuave
ssuave's Avatar
Originally Posted by Ma-Xell View Post
Thanks but averaging doesn't seem to be good solution for me. I need the exact bit-rate for each encoded frame, otherwise known as 'residual frame' obtained after motion compensation.
Old 30th June 2012, 13:50   #4  |  Link
Andouille
Registered sausage
Andouille's Avatar
ffdshow has an option for displaying the size of each frame.
If it is not enough for ya, since ffdshow is based on ffmpeg, you should have some command in ffmpeg to output a log with the frame number/type/size (I guess)
Andouille is offline   Reply With Quote
Old 30th June 2012, 13:53   #5  |  Link
If you want to create your own code for this, rather than using an existing utility to dump the frame sizes, you get the H.264 spec and read the part where it tells how to recognize the start of a new frame in the bitstream. Then you parse the bitstream to find these boundaries. The boundaries let you determine the frame sizes. You have the frame rate and so you have the time per frame. Now you have everything you need to calculate the bitrate for any frame.
If you are asking how to parse H.264, then that is also described in the spec.
There is sample code in the JM reference decoder that I used as the basis for the H.264 parsing in my tools.
Old 1st July 2012, 03:11   #6  |  Link
upyzl
zj262144
upyzl's Avatar
MPC-HC 1.7.8 / LAV Filters 0.64+ (tMod) / XySubFilter 3.1.0.705 / madVR 0.87.14
Direct264 Mod (src & win32 builds): code.google.com/p/direct264umod (maybe outdated)
upyzl is offline   Reply With Quote
Old 3rd July 2012, 18:33   #7  |  Link
obieobieobie
It's actually impossible to have a bit rate for a still image.
obieobieobie is offline   Reply With Quote
Old 3rd July 2012, 18:42   #8  |  Link
If you have a defined display time for the image then the concept of bitrate for the image has a meaning.
Old 3rd July 2012, 18:57   #9  |  Link
poisondeathray
A free way is ffdshow's osd (checkmark "coded frame size"), it has option to print out csv file
A non free way is to use a stream parser like elecard streameye
Old 4th July 2012, 16:26   #10  |  Link
obieobieobie
Yes, you are of course correct.
Old 25th July 2012, 14:07   #11  |  Link
ssuave
ssuave's Avatar
Thanks all. I appreciate it!
bitrate, frame, h.264/avc
