7th June 2013, 17:59 | #81 | Link | |
9th July 2013, 03:40 | #82 | Link |
how do to put the nnedi3 instead of BilinearResize in the SAA?
is it possible? I'm not able... Clp.PointResize(OX*SS,OY*SS).SangNom().TurnRight() \ .SangNom().TurnLeft().BilinearResize(OX,OY) Now, for the use that I do, I'm putting spline36resize Clp.PointResize(OX*SS,OY*SS).SangNom().TurnRight() \ .SangNom().TurnLeft().spline36resize(OX,OY) |
10th July 2013, 07:01 | #84 | Link | |
Nani miten da yo? Baka!!
25th July 2013, 20:18 | #85 | Link |
Hi, i'm using the aaa() from wiki, and i got a question: What adds suchs a heavy noise to picture?
I've got a pretty clean animation frame, then i add aaa(Xshrp=55,Yshrp=55,chroma=false), and i get a tremendous amout of temporal noise. it changes with every frame. I'm afraid to clean it up because of detail loss. You guys have the same results? here's an example: http://screenshotcomparison.com/comparison/33785 at first i thought it's because of unsharp values of 55, but it adds noise on default, too... Last edited by spx; 25th July 2013 at 20:30. |
26th July 2013, 14:56 | #86 | Link | ||
In regards to ediaa(), wouldn't replacing
For me it gives a speed increase from 1 fps to 1.6 on 1080p. |
27th July 2013, 09:42 | #87 | Link |
Oz of the zOo
AA scripts that use turnleft and/or sangnom may be significantly sped-up with sangnom2+fturn - for better results drop the chroma plane by using Y8 colorspace during processing and copy original chroma in the end (example). Realtime AA of 1080p @ 24fps on my pc...
29th July 2013, 19:08 | #88 | Link |
Hi all,
sorry for capturing this thread , but I've a similar issue. I got a poorly deinterlaced clip here (simple bob().SelectEven() ) with quite a lot of jaggy edges I'd like to fight. This is not Anime material but captured from a VHS tape. Your anti-alias-script uses SangNom, but that's for interlaced material - not ? But my vid is already progressive encoded and now I'd like to reencode plus a bit upsizing. So what would be the best "way to do it ?" The original is lost only reencoded vid is here. TIA |
8th August 2013, 03:45 | #89 | Link |
my first function, MC DAA3
#Motion-Compensated Anti-aliasing with contra-sharpening by A.SONY #some ideas was taken from Didée scripts daa and this http://forum.doom9.org/showthread.php?t=153219 #created because when applied daa3 to fixed scenes, it could damage some details and other issues. # v3.55 function mcdaa3(clip input) { sup = input.HQdn3d().FFT3DFilter().MSuper(pel=2,sharp=1) fv1 = sup.MAnalyse(isb=false,delta=1,DCT=2,Truemotion=false) fv2 = sup.MAnalyse(isb=true,delta=1,DCT=2,Truemotion=true) csaa = input.daa3mod() momask1 = input.MMask(fv1, kind = 1, ml=2) momask2 = input.MMask(fv2, kind = 1, ml=3) momask = mt_average(momask1,momask2,u=3,v=3) mt_merge(input,csaa,momask,u=3,v=3) } ############################# #Anti-aliasing with contra-sharpening by Didée with some modifications, v3.55 FUNCTION daa3mod(clip c1, val "slow", int "threads") { avs25 = VersionNumber() < 2.60 isslod = defined(slow) slow = default (slow , true) isslob = isbool(slow) issloi = Isint(slow) Assert(isslob || issloi, "'slow' only accepts bool or int") slowb = isslob ? slow : isslod threads = default (threads , 0) rescale = slowb && issloi ? slow > -1 : slowb upsizer = rescale ? issloi ? slow!=0 ? "BilinearResize" : "Spline36Resize" : "Spline36Resize" : nop() downsizer = slowb ? issloi ? slow!=0 ? "BicubicResize" : "Spline36Resize" : "Spline36Resize" : nop() c = rescale ? threads!=1 ? Eval("""try { Eval("c1."+upsizer+"mt(c1.width, c1.height*3/2,threads=threads)") } catch(error_msg) { Eval("c1."+upsizer+"(c1.width, c1.height*3/2)") }""") : Eval("c1."+upsizer+"(c1.width, c1.height*3/2)") : c1 nn = issloi ? slow > 1 ? c.Padding(slow==2 ? 0 : 4,4,slow==2 ? 0 : 4,4).nnedi3(field=-2,threads=threads).crop(slow==2 ? 0 : 4,4,slow==2 ? 0 : -4,-4) : c.nnedi3(field=-2,threads=threads) : c.nnedi3(field=-2,threads=threads) c =isyuy2(c) && avs25 ? c.Interleaved2Planar() : isyuy2(c) ? c.converttoyv16() : c nn=isyuy2(nn) && avs25 ? nn.Interleaved2Planar() : isyuy2(nn) ? nn.converttoyv16() : nn isslow4 = slowb && issloi ? slow > 3 || slow < -1 : false istof = isslow4 ? c1.getparity : nop() seto = isslow4 ? istof ? selecteven(nn) : selectodd(nn) : selecteven(nn) seto = isslow4 ? threads!=1 ? Eval("""try { Eval("seto."+downsizer+"mt(c.width, c.height,src_top=-0.5,threads=threads)") } catch(error_msg) { Eval("seto."+downsizer+"(c.width, c.height,src_top=-0.5)") }""") : Eval("seto."+downsizer+"(c.width, c.height,src_top=-0.5)") : seto sebo = isslow4 ? istof ? selectodd(nn) : selecteven(nn) : selectodd(nn) sebo = isslow4 ? threads!=1 ? Eval("""try { Eval("sebo."+downsizer+"mt(c.width, c.height,src_top=0.5,threads=threads)") } catch(error_msg) { Eval("sebo."+downsizer+"(c.width, c.height,src_top=0.5)") }""") : Eval("sebo."+downsizer+"(c.width, c.height,src_top=0.5)") : sebo dbl = mt_average(seto,sebo,U=3,V=3) dblD = mt_makediff(c,dbl,U=3,V=3) shrpD = mt_makediff(dbl,dbl.removegrain((width(c)>1100) ? 20 : 11,Planar=true),U=3,V=3) DD = shrpD.repair(dblD,13,Planar=true) fd1 = dbl.mt_adddiff(DD,U=3,V=3) fd2 = rescale ? threads!=1 ? Eval("""try { Eval("fd1."+downsizer+"mt(c1.width, c1.height,threads=threads"+((downsizer!="Spline36Resize") ? ",b=0.3, c=0.2" : "" )+")") } catch(error_msg) { Eval("fd1."+downsizer+"(c1.width, c1.height"+((downsizer!="Spline36Resize") ? ",b=0.3, c=0.2" : "" )+")") }""") : Eval("fd1."+downsizer+"(c1.width, c1.height"+((downsizer!="Spline36Resize") ? ",b=0.3, c=0.2" : "" )+")") : fd1 fd3 = isyuy2(c1) && avs25 ? fd2.Planar2Interleaved() : isyuy2(c1) ? fd2.converttoyuy2() : fd2 return fd3 } like this example:- original - daa3 - mcdaa3 And here apply of daa3 and mcdaa3 on a moving scene:- original -daa3 -mcdaa3 download link (it's old now) edit1: mcdaa3 and normal daa can deal with ifade too, In fact, the daa function is the remnants Interlaced cleaner after IVTC edit2: now you can use it like this smam(filter=daa3mod()) , this support YUY2 and more up to date edit3: since smam now will add daa3mod() is some cases, if you use it like this smam(filter="daa3mod()") it will be 2 daa3mod(), so you must change smam settings like this smam(filter="daa3mod()",usedaa3mod=0) or use it as I write in "edit2" above, or smam(filter=last) edit4: if the clip has black border on top or bottom it beter to crop it before using any daa/daa3 method since it will add some Artifacts unless you set slow to -2 or more than 0 (better but slower as you go on with the number)
See My Avisynth Stuff Last edited by real.finder; 7th August 2019 at 00:18. Reason: new slow method |
8th August 2013, 19:50 | #91 | Link | |
3rd March 2015, 13:31 | #92 | Link | |
Or, rather, do I need to just invoke the functions with empty parameters or I need to specify clip? Last edited by Kein; 3rd March 2015 at 13:42. |
3rd March 2015, 16:13 | #93 | Link | |
function mcdaa3(clip input) http://avisynth.nl/index.php/External_filters
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 3rd March 2015 at 16:22. |
3rd March 2015, 16:58 | #94 | Link | |
