25th September 2010, 06:24 | #9661 | Link | |
Hmm, now i get always the Extract Audio Subs error message.... |
25th September 2010, 12:35 | #9663 | Link |
BD-RB 0.34.11.
Prince of Persia (the movie is split into 140 files !) Movie-only mode, other Movie-Only playlist selected, resize to 720p, BD-5. The 2 selected subtitles were not extracted correctly. I got 2 sup files of the first movie segment (studio intro) in the workfolder, 0 bytes each. The rest is missing. No big issue really. Apart from the missing subtitles, everything came out perfectly. Last edited by Sharc; 25th September 2010 at 13:11. |
25th September 2010, 13:16 | #9664 | Link | |
Comes out of the cmd line. [14:05:29] BD Rebuilder v0.34.11 (beta) - Source: PRINCE_OF_PERSIA - Input BD size: 23,38 GB - Approximate total content: [01:55:53.486] - Target BD size: 45,80 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [14:05:30] PHASE ONE, Encoding - [14:05:30] Extracting A/V streams [VID_00066] - Extracting A/V to M2TS [VID_00066] - Extracting A/V from M2TS [VID_00066] - Error in attempt to extract audio/subs. - H.264 stream does not contain fps field. Muxing fps=23.976 - Error in attempt to extract audio/subs. - H.264 stream does not contain fps field. Muxing fps=23.976 [14:11:34] - Failed to retrieve audio, aborted |
25th September 2010, 14:22 | #9665 | Link |
@Longtom: Posted from all of your BD_Rebuilder logs: - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
I think maybe I am just being dense this morning but when I do movie only encodes all my logs all have something in this Audio section with a (1) in it. My apologies if I am missing something. bye, Worknstiff |
25th September 2010, 15:21 | #9667 | Link | |
25th September 2010, 17:30 | #9669 | Link | |
what is the advantage of this procedure? sorry for my bad english i'm italian |
25th September 2010, 18:23 | #9670 | Link | |
25th September 2010, 20:55 | #9672 | Link | |
25th September 2010, 22:16 | #9673 | Link |
FIxed the problem..but
i read on a google search this can keep menus? is this correct?.. when i load the program on its default settings, i see the main menu stream and the main menu stream but as soon as i change the target size from bd9 or bd5 the main menu disappears and im only left with the main movie? [it reappears again if i change it back to bd5/9.. is this a bug or is it intentional? i want to compress the main movie only but keep the title menu.. is this viable? also ive been trying to do 2 pass to a custom size but it always says no reencode req'd.. is this a bug? it will reencode if i set it to bd9.. its 23GB in total Last edited by al4x; 25th September 2010 at 23:26. |
26th September 2010, 13:42 | #9677 | Link |
I've tried to create a profile of my own for alternate output. Wanting MKV, 1280x720 and AC3 at 640K.
So I put this into alternate. [00010] caption=MKV Container, 1280x720, 640Kbs AC3 vBitrate=1230 aBitrate=640 aType=0 vFormat=4 and the logfile seems OK. [12:58:51] BD Rebuilder v0.34.11 (beta) - Source: GOOD_BAD_WEIRD - Input BD size: 19,11 GB - Approximate total content: [02:04:42.399] - Target BD size: 4,36 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - RESIZE 1080p to 720p enabled - Mode: MKV Container, 1280x720, 640Kbs AC3 - Audio Settings: AC3=1 DTS=0 HD=0 Kbs=640 [12:58:51] PHASE ONE, Encoding - [12:58:51] Extracting A/V streams [VID_00000] - [13:11:19] Reencoding: VID_00000 (1 of 1) - [13:11:19] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 25,000fps, 187*060 frames - Convert: 1280x720, 50,000fps, 374*120 frames - [13:11:19] Reencoding: VID_00000, Pass 1 of 1 - [14:30:03] Video Encode complete - [14:30:03] Reencoding audio tracks (if req'd) - [14:33:26] Multiplexing M2TS [14:33:26]PHASE ONE complete [14:33:26]PHASE TWO - Rebuild Started - [14:33:26] Rebuilding stream 00000 [1 of 1] - [14:33:26] Building ALTERNATE OUTPUT Structure [14:38:57] - Encode and Rebuild complete [14:38:57]JOB: GOOD_BAD_WEIRD finished. But in the end, to my surprise, I got an MP4. What did I do wrong? |
26th September 2010, 15:29 | #9678 | Link | |
Text from the existing ALTERNATE.TXT file: Code:
# The options below show up in the Alternate Output Dialog # Settings: # caption=Text to show on alternate selection list # vBitrate=Bitrate to use for two-pass video encoding # aBitrate=Bitrate to use for audio encoding # aType=Output Audio Type, 0=AC3, 1=AAC # vFormat=Video Format: 0=320x240/180, 1= 480x360/270, 2= 640x480/360 # 3= 1024x768/576, 4= 1280x720, 5= 1920x1080 # cType= Container/limits type, 0=MP4 (iPod), 1=MKV, 2=MP4 (iPad) Last edited by jdobbs; 26th September 2010 at 15:32. |
