Old 28th May 2010, 17:09   #41  |  Link
leeperry
Kid for Today
it looks to me that the 3 grain layers in GrainF3 w/ 1.4 are not random anymore...they all seem to use the same pattern(except for the chunk size). w/ 1.1 I do get my "Grain EE 3D pop effect" feeling I've spent so much time working on...making halo-based EE is so yesterday
Old 2nd June 2010, 03:47   #42  |  Link
leeperry
Kid for Today
..which makes me think that "seed repeatable" implies that provided I would find a "best" combination, I might be able to modify GrainF3 to always use the very same seeds/patterns....interesting!
Old 5th June 2010, 00:34   #43  |  Link
leeperry
Kid for Today
BTW:
seed (-1)
Specifies a repeatable grain sequence. Set to at least 0 to use.
constant (false)
Specifies a constant grain pattern on every frame.
at least 0? so this will set the grain sequence? what's the max? I'm not sure how to take advantage of the "repeatable seed" feature of 1.4
Old 5th June 2010, 04:17   #44  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
The max is probably either 2 billion or 4 billion, I forget. Any number will work about as well as any other. Every one will give you a different sequence of grain, but it'll always be identical for the same source parameters. Different colorspace or size will change everything. Give it a shot, set seed to something and keep reloading the script on different frames.
Old 5th June 2010, 05:08   #45  |  Link
leeperry
Kid for Today
ok, interesting...this could do exactly what I want.
EDIT: and it does! many
Old 26th October 2010, 08:02   #46  |  Link
TurboPascal7
TurboPascal7's Avatar
Looks like a bug here. Bug appears with uvar > 0 and constant=true.
Example:
Right down corner. Seems to work incorrect on any resolution on yv12.
TurboPascal7 is offline   Reply With Quote
Old 25th November 2010, 15:47   #47  |  Link
SSH4
hmm, i have some bug
SSH4 is offline   Reply With Quote
Old 26th November 2010, 06:02   #48  |  Link
AlekseiV
drink lots of orange juice
AlekseiV is offline   Reply With Quote
Old 26th October 2011, 20:46   #49  |  Link
Reino
Reino's Avatar
Originally Posted by foxyshadis View Post
...it may also be SSE2 only (haven't run it on the Athlon yet).
I have and your filter doesn't work an my AMD Athlon XP 3200+.
For MCTemporalDenoise your filter is required, but here it comes down with this error:
Evaluate: System exception - Illegal Instruction
(GradFun2DBmod.v1.5.avsi, line 291)
GradFun2DBmod.v1.5.avsi:
290 grain  = custom=="empty" ? dither.addgrainC(str,strC,0,0)
291 \      :                   Eval("dither." + custom)
292 diff   = custom=="empty" ? blankclip(dither,color_yuv=$808080).addgrainC(str,strC,0,0)
293 \      :                   Eval("blankclip(dither,color_yuv=$808080)." + custom)
Removing the AddGrainC calls makes MCTemporalDenoise work, so I guess a SSE cpu, as mentioned in the readme, is not enough and your filter is actually SSE2 only at the moment.
If you find some time, could you please have a look?
My hobby website
Reino is offline   Reply With Quote
Old 26th October 2011, 22:08   #50  |  Link
cretindesalpes
cretindesalpes's Avatar
Does this version work better?
EDIT: Link now points to v1.5.3 instead of 1.5.2, I also fixed a bug occurring with RGB24 colorspace, causing unwanted coloration.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding
cretindesalpes is offline   Reply With Quote
Old 27th October 2011, 00:20   #51  |  Link
Reino
Reino's Avatar
Wow, that's quick! Thanks a lot cretindesalpes. It works like a charm.
My hobby website
Old 27th October 2011, 05:27   #52  |  Link
kypec
User of free A/V tools
kypec's Avatar
You might want to update "AddGrain.txt" version history section with that fix as well.
kypec is offline   Reply With Quote
Old 27th October 2011, 12:26   #53  |  Link
SSH4
cretindesalpes can you check bug from TurboPascal7 post http://forum.doom9.org/showpost.php?...6&postcount=46 ?
Old 27th October 2011, 20:54   #54  |  Link
cretindesalpes
AddGrainC 1.5.4 fixes this problem, as well as other minor issues.
Old 28th October 2011, 21:05   #55  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Update 1.6.0 - SSE2
I took some minutes to add SSE2 code, now it's about 50% faster.
To turn off SSE2 and return to MMX set "sse2=false".
Here is the new version: AddGrainC 1.6.0
LaTo is offline   Reply With Quote
Old 29th October 2011, 11:29   #56  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Update 1.6.1
Just a one line update to add automatic switch to MMX if your cpu doesn't support SSE2.
Here: AddGrainC 1.6.1
Old 3rd November 2011, 17:07   #57  |  Link
leeperry
Kid for Today
awesomeness,
Old 16th August 2012, 00:29   #58  |  Link
cretindesalpes
Update 1.7.0
AddGrainC 1.7.0
This version supports the new Avisynth 2.6 colorspaces: Y8, YV16, YV24 and YV411.
Old 16th August 2012, 01:21   #59  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Thanks very much for your effort
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 16th August 2012, 01:44   #60  |  Link
Reel.Deel
AddGrainC 1.7.0
Wow cretindesalpes, your on a roll! Kudos to you.
Any future plans for the lsb in/out parameters?
