28th December 2006, 06:33 | #61 | Link |
New features
New features in Elecard XMuxer Pro v 2.2 and Elecard XMuxer Lite v 1.1:
You can read more detailed information on all changes in Release Notes for each product. Best Regards, Konstantin. |
29th December 2006, 22:45 | #62 | Link |
Xmuxer can be usefull for demuxing nontypical TS streams as can be seen on this picture
Sample 34MB with multiaudio tracks was recorded with SkyView . sample Sample can be played with VLC Player with possibilty to set required audiotrack to play it back. There is also multiplexed additional PID 0012 EIT carring all data about songs /all/ from that transponder with title, singer, album data, timing and so on. Task to do: demux individual audiotrack and split that tracks to individual songs with all data connected with this song. BTW SkyView can record songs as individual pieces with apropiate header but only from one PID. eb |
26th March 2007, 11:06 | #63 | Link |
Elecard XMuxer Lite 1.2
Hi all, I am glad to inform you that Elecard releases new version of Elecard XMuxer Lite 1.2.
New features in XMuxer Lite v.1.2: - AVI file support - GOP-accurate AVI (DV, XviD, DivX, 3ivX, etc) trimming - Transport stream - special ISDB-T support - LPCM multiplexing to Program Stream - New hot key Ctrl+M - sets current position to the next marker on timeline and displays the marked frame in Preview window Read more about new features and bug fixes here: http://www.elecard.com/products/prod...er/xmuxer-pro/ Best Regards, Konstantin |
17th May 2007, 08:46 | #64 | Link |
Elecard XMuxer polling
Hi all. We strive to make a product easy to use for everybody. Therefore we set up a polling to find out what you like or dislike in our product, what other features in our product you would like to see.
http://www.elecard.com/forum/viewtopic.php?t=1778 Best Regards, Konstantin. |
31st May 2007, 04:35 | #65 | Link |
Elecard XMuxer Pro 2.5 Beta
Hi All,
New version of Elecard XMuxer 2.5 Beta is accessible on our site. Read more here: http://www.elecard.com/products/prod...al/xmuxer-pro/ Best Regards, Konstantin. |
19th June 2007, 06:08 | #66 | Link |
Elecard XMuxer Lite v 1.2 for Windows Vista
Hi all,
I am glad to inform you that Elecard XMuxer Lite v 1.2 has been officially Certified for Windows Vista. Read more here: http://www.elecard.com/products/prod...r/xmuxer-lite/ Best Regards Konstantin. |
23rd June 2007, 22:52 | #67 | Link |
All the Xmuxer Pro I have used always have problems with the software and full of bugs. The same goes for MainConcept Encoders (on MPEG2 works fine).
The Idea behind Xmuxer is terrific, if it could only work as it should it would be a great program. Am not alone, go thru their forums and you'll be amazed how buggy are their programs and their poor customer support.
VAIO VGX-XL3 4gig RAM, 4Tb HDD. MEDIA CENTER WINDOWS 7 simply the best!! |
23rd June 2007, 23:29 | #68 | Link |
To prove my point I am using Elecard XMuxer Pro 2.2.70328 I just want to mux AVC+AC3.
Everything good so far. Look what happens when I press start. -------------------------------------------------------- nothing happens after 5 minutes. Then a quick look at Task Manager reveals "NOT RESPONDING". If any Xmuxer PRO can mux a AVC+AC3 let me know.
24th June 2007, 03:21 | #70 | Link | |
When I record a .ts video that has errors thats when I run it through MPEGRepair 1.0.1.5 -> Xmuxer Pro to Remux the stream. Then try to fix the audio with AC3 Delay Cut -> BeSliced (Fix). Other than that I never use Xmuxer. That's only if I can't get the video on a re-run (like the Super Bowl). Remux an MPEG2 file to me it works. Mux has never worked (AVC & AC3) ofcourse, because if is MPEG2 I rather use Womble VCR to mux. To Demux!!, what better than your master piece DG MPG Dec. Now, I don't have a use for Xmuxer Pro. All my sources are MPEG2 and I rather use millions of apps out there. When DirecTVHD moves to AVC then I'll give it a try to edit out commercials but till then I leave this app as the last resort. Just out of curiosity, why on earth would you need Xmuxer Pro?
24th June 2007, 04:56 | #71 | Link |
Dear Toti,
Please upload on any ftp your test files which you could not multiplex in Elecard XMuxer Pro. Or upload this files on ours ftp (ftp.elecard.com, user name:uploader, password: ybrjveybrf,tkmyjcnm, file size must be more than 25Mb). It will help us to define a problem. Best Regards Konstantin. |
24th June 2007, 15:09 | #72 | Link |
For me personally, I need a muxer for combining AVC and audio (various formats) to create test streams for my company's silicon decoders and to create streams for demos at shows such as CES. But since I was given a very good in-house-created muxer by one of our customers, I don't need to use XMuxer Pro or Manzanita anymore. Don't ask for it; I cannot distribute it.
24th July 2007, 14:56 | #75 | Link |
Unfortunately it doesn't works. Installed latest beta trial version and after cutting I have distorted transport stream and I can't export this back to HDV camcorder.
Original stream: Remuxed stream: Regards, AK |
25th July 2007, 02:44 | #76 | Link | |
Can you upload your file on any ftp? You can upload your file on ftp.elecard.com (user name: uploader, password: ybrjveybrf,tkmyjcnm) and inform me file name. Thanks. Best Regards, Konstantin. |
5th August 2007, 11:52 | #79 | Link | |
On market is big hole - lack of good tools, lack of good muxer/demuxer... Even very high priced tools (Tektronix) are very poor in quality... |
