13th April 2008, 22:27 | #1001 | Link | |
14th April 2008, 00:16 | #1003 | Link | |
http://forum.doom9.org/showthread.ph...76#post1125176 |
14th April 2008, 00:33 | #1004 | Link | |
Would be cool though if tsMuxer could use a more user friendly and informative naming scheme for demuxed files (e.g. "track Info" + Audio Delay). File names are getting really long with mpls referring to multiple source m2ts! |
14th April 2008, 01:09 | #1005 | Link | |
Thanks for the link. |
14th April 2008, 07:18 | #1008 | Link |
Hi roman76r!
Thanks for all your hard work on tsMuxeR! I used 1.7.6(b) today to remux Terminator II (EUR) HD DVD to BluRay (kept VC-1 video and DTS-HD audio). Unfortunately tsMuxeR introduced corruption into a perfectly good video stream (source is clean). I tried it twice, once with "remove pulldown" and once without. The corruption was the same each time. Here is an example: The muxer also complained about a total of three "bad DTS-HD frames" which I find highly unlikely. Regards S. |
14th April 2008, 10:01 | #1010 | Link |
Restore cropped video to full size
Hi roman76r,
I'm interested in the "Restore cropped video to full size" option in the General tab page. Is it a feature developed in the near future ? Is it possible to add black bars to cropped movies without fully reencoding them to become Blu-ray standard resolution ? (It is the main problem with the use of the AVCHD format.) Great work. |
14th April 2008, 11:26 | #1011 | Link | |
For Blu-ray, the vbv (or cpb) delay cannot be greater than 1 second. Ron
HD MPEG-2 Test Patterns http://www.w6rz.net Last edited by drmpeg; 14th April 2008 at 11:51. |
14th April 2008, 15:10 | #1014 | Link | |
lexor
14th April 2008, 19:18 | #1017 | Link |
Caped Crusader
For roman76r.
SkyHD (h264) files are playing with no video just Audio when remuxed with tsMuxer, with all default settings. This is version 1.7.6. If I go back to version 1.6.3 and remux they play fine with both audio and video. MKV remux and play fine with the latest version, its just the SkyHD h264 .ts files are not working. Oh this is playback on a PS3. Heres a sample of a file pre remux. http://www.divshare.com/download/4253839-97b Cheers. Heres a link to the older version. http://www.divshare.com/download/4253853-afc Last edited by B4tm4n; 14th April 2008 at 20:11. |
14th April 2008, 22:09 | #1018 | Link |
I'm new to the software and indeed PS3s. I've tried creating a blue ray disc from an MKV and I get a large green area at the bottom of the screen (fine on PC). I believe its a pixel size issue? Is there any solution to this issue?
Also, whats the best format to output in if I want several movies on one blue ray disc on the PS3? Last edited by rendez2k; 14th April 2008 at 22:16. |
14th April 2008, 22:22 | #1019 | Link |
VOB Subtitles
version 1.76 does not recognize subtitles in VOBs. I assume it's known, but still a pity. I wanted to fuse 2 DVDs (part 1+2 with 2 audio and 2 subtitiles) to one single BluRay, to spare me the shuffling... The audio streams are recognized, but not the subpictures. So I demuxed them with VOBedit and transformed the sup-files (which were not directly readable by tsmuxer) with SUPread to BluRay-format. Those were recognized by tsmuxer. The muxing went ok until the mpls and clipinfo were generated. Here I got the error: Creation of Blu-ray stream info and seek index. Bitstream exception. (Mux complete. Return code: -3) There is no clipinfo-file generated and the mpls seems to be a little bit short considering, that I wanted to have every 5mins a chapter and the movie has over 3h. The resulting m2ts-file is processable through TSRemuxer and results in a playable BluRay. But no subpictures are displayed although they are selectable in the menue of PowerDVD. Regards. PS: I should mention, that watching the resulting m2ts I realised, that besides of the not displayed subtitles, also the audio-delay during playback changes. While it is ok at the beginning it starts to grow toward the end... So in prinziple it would be good, if tsmuxer could read directly all streams of a vob file. Last edited by arrgh; 14th April 2008 at 22:57. |
tsmuxer |
