3rd April 2008, 22:21 | #1101 | Link |
Hi all and I wonder if you can help. Im very new to this tool RipBot and it is one amazing tool, just what i have been looking for, but the problem being is this.. How do add chapters when encoding from mkv to bluray....???
I know in ts remux its possible but every thing i have done so far has no chapters to it. Am I doing something wrong. Thanks again for this wonderfull bit of kit. |
3rd April 2008, 22:26 | #1102 | Link |
If you send some mkv samples with chapters I will see what I can do
3rd April 2008, 22:29 | #1103 | Link |
Ok thanks... but how do you add chapters to a mkv then. Sorry if this sounds noobish but im new to the whole mkv scene lol. Is it possible to add them to one so when re encoded in RipBot it has these in there or can RipBot do this for you
3rd April 2008, 23:30 | #1104 | Link |
[QUOTE]Ok thanks... but how do you add chapters to a mkv then.[QUOTE]
I don't know . I don't use chapters.
4th April 2008, 02:24 | #1106 | Link | |
I did as you suggested, no luck... output file never appears in the destination. Other suggestions? Log: C:\>"C:\RipBot264v1.9.2\tools\bepipe\bepipe.exe" --script "import(^C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job1\job1.avs^)" | "C:\RipBot264v1.9.2\Tools\enc_aacPlus\enc_aacPlus.exe" - "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\audio.aac" --lc --cbr 131072 *************************************** BePipe by dimzon *************************************** Script used: # BEGIN import("C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job1\job1.avs") # END Scanning for Audio Stream... ERROR: Can't find audio stream! No accelerated IMDCT transform found ******************************************************************** * AACPlus v2 Encoder (using Winamp 5.2 enc_aacplus.dll) * Source timestamp Mon May 15 17:24:26 2006 * Build May 15 2006, 17:24:35 ******************************************************************** * NOTE! enc_aacplus.dll must be into executable directory * get it from Winamp 5.2 plugins directory * tested on Winamp 5.2 Release Feb 23 2006 Full (Not Pro) version) ******************************************************************** Input file must be WAV PCM! C:\>"C:\RipBot264v1.9.2\tools\x264\x264.exe" "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job1\job1.avs" --pass 1 --bitrate 1024 --stats "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job1\job1.stats" --level 4.1 --sar 1:1 --aud --nal-hrd --vbv-bufsize 14000 --vbv-maxrate 25000 --filter 0,0 --bframes 3 --direct auto --subme 2 --analyse none --me dia --threads auto --thread-input --progress --no-psnr --no-ssim --output "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\video.264" No accelerated IMDCT transform found avis [error]: unsupported input format (DIB ) x264 [error]: could not open input file 'C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job1\job1.avs' C:\>"C:\RipBot264v1.9.2\tools\x264\x264.exe" "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job1\job1.avs" --pass 2 --bitrate 1024 --stats "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job1\job1.stats" --level 4.1 --sar 1:1 --aud --nal-hrd --vbv-bufsize 14000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --mixed-refs --bframes 3 --b-rdo --bime --weightb --direct auto --subme 6 --trellis 1 --analyse p8x8,b8x8,i4x4,i8x8 --8x8dct --me umh --threads auto --thread-input --progress --no-psnr --no-ssim --output "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\video.264" No accelerated IMDCT transform found avis [error]: unsupported input format (DIB ) x264 [error]: could not open input file 'C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job1\job1.avs' C:\>"C:\RipBot264v1.9.2\tools\mp4box\mp4box.exe" -tmp "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp" -add "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\video.264" -fps 25 -add "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\audio.aac" -mpeg4 -new "C:\Documents and Settings\admin\Desktop\ChavezOnthewaytosuccess.mp4" Cannot find H264 start code Error importing C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\video.264: BitStream Not Compliant[/SIZE] |
4th April 2008, 03:23 | #1108 | Link |
tried number of files, same or similar issue. preview never worked, here's preview error screen shot
Only logical solution is to load fresh copy of the OS and try again. that's something that I will do in a week or two, assembling new box, so no point of di$king around with this one. I used mkv2vob app w/o any problems, but RipBot264 gives me a lot more options, especially since some of content that I have is in various formats and isn't cooperating with PS3. Anyone tried using RipBot on Vista 64bit? |
4th April 2008, 05:09 | #1109 | Link |
I dont care so should you
The creator uses Vista to build RipBot I don't know if it is x64 version but I C no reason why it shouldn't...
Do you have the latest build of DDShow and haali media splitter. http://haali.cs.msu.ru/mkv/ for haali http://downloads.sourceforge.net/ffd...4&big_mirror=0 For DDShow
My Installer's || |
4th April 2008, 11:12 | #1110 | Link |
I suspect problem with avisynth. Try 64bit version or 32bit.
4th April 2008, 15:02 | #1111 | Link |
yeap, i'm running latest ver. of AviSynth, FFDShow, Haali Media Splitter - all of which were reinstalled as of last night. I'm using XP SP2 Pro 32bit OS.
I'll try loading Vista 64bit and see if that eliminates the issue. Thanks everyone for suggestions and will report back once a new OS is installed. |
4th April 2008, 15:07 | #1112 | Link |
н∂-ƒαиαтι¢
^ latest version of avisynth which is? 2.5.8?
if so, uninstall and try 2.5.7 or 2.5.6: http://sourceforge.net/project/showf...group_id=57023 |
4th April 2008, 19:43 | #1114 | Link |
Hi there me again . I managed to add chapters in the end to my previous question but my next question is this....
I am creating bluray files from a mkv with a screen size of 1288*544. Now to get this to play on my ps3 correctly do i need to adjust the screen size to 1280*720 or can i add borders to it, or do I do both |
4th April 2008, 19:55 | #1115 | Link |
No If you want to use m2ts only
Yes If you want to use whole Blu-ray Structure
4th April 2008, 22:53 | #1119 | Link |
RED? Forget it.
6th April 2008, 12:02 | #1120 | Link |
Thanks Atak_Snajpera for such a cool program!! My kids had ruined a few blu-ray movies. Now I can rip the blu-ray (movie and 1 sound track only) and back them up to a DVD-DL disc. The movies still looks better than any store boughten DVD, and when put in our home blu-ray player, it says now loading Blu-Ray. WOW! Now my kids can watch a Blu-Ray movie on a single DVD-DL disc and when it gets scratched it won't cost me another $30 to replace it... THANKS A MILLION!!!
ps... the only thing missing that would be a great improvement to this program is chapter points but still it's the best program I seen so far!!! Keep up the great work! Thanks! |
