6th October 2010, 02:13 | #9762 | Link |
Still not available, tried several movies, unchecked all subs/audio in setup and made sure there were no subs/audio selected for title. Still no blank item option available
BD-Rebuilder 0.34.11 beta NM, just searched the thread and found that it hasn't been implemented yet Last edited by jellyhead1; 6th October 2010 at 02:19. |
6th October 2010, 03:26 | #9763 | Link | |
6th October 2010, 17:41 | #9765 | Link | |
6th October 2010, 17:42 | #9766 | Link | |
6th October 2010, 18:02 | #9767 | Link |
@jdobbs:
I don't know whether or not this has been reported yet, but here goes: Using latest release (0.34.11) I did Iron Man 2 full backup to BD25. The main movie is seamless-branched (some sort of special feature that in one playlist plays a set of m2ts's that assembles the movie, and in another playlist it replaces some m2ts's with different ones to show additional info over certain scenes) so as a result the whole thing it is split over quite a few m2ts files. Anyways - bug report: BD-Rebuilder forgot to change the OUT_TIME of all the m2ts's and chapters in both playlists. It altered the IN_TIME to the standard tsmuxer 00:10:00:00, but left the OUT_TIME as it was on the original disc. Worth checking out. I'll provide additional information should you request it. |
6th October 2010, 18:06 | #9768 | Link | |
6th October 2010, 18:14 | #9769 | Link |
Actually, I just found that this isn't unique to those 2 playlists. There are alot of playlists on this disc and many of them contains a tsmuxer 10:00 in-time and an original-disc unaltered out_time.
Take a look here: http://img801.imageshack.us/img801/9657/bdrb.png |
6th October 2010, 18:19 | #9770 | Link | |
August 2nd, 2010 - v0.34.06 - Modified the MPLS update routine so it checks original OUT times against those created by TSMUXER and correct where they differ. This could correct a slight stutter at M2TS change point on some software players playing a multi-part feature on a full backup. Last edited by jdobbs; 6th October 2010 at 18:29. |
6th October 2010, 18:22 | #9771 | Link | |
As for it being possibly tsmuxer's fault - I tried opening the m2ts in tsmuxer and remuxing it in blu-ray authoring mode just to see if it outputs the right in/out times in the generated playlist, and it does. (Besides, how likely would it be that TSMuxer uses the EXACT out_time of the original-disc untouched m2ts?) Hope this helps. Last edited by PurpleMan; 6th October 2010 at 18:27. |
6th October 2010, 18:32 | #9772 | Link | |
I was just about to post a new version -- but I'm going to hold off until I figure this one out. Last edited by jdobbs; 6th October 2010 at 18:43. |
6th October 2010, 18:54 | #9773 | Link | |
Do you still have the log from when you did that job? Last edited by jdobbs; 6th October 2010 at 18:56. |
6th October 2010, 19:43 | #9774 | Link | |
Here is the log: http://pastebin.com/cvurMQ8n Glad I could help again |
6th October 2010, 20:08 | #9775 | Link | |
6th October 2010, 20:11 | #9776 | Link | |
7th October 2010, 04:43 | #9778 | Link |
BD Rebuilder v0.35.01 (beta)
I have updated the first post of this thread with a new release of BD-RB (v0.35.01). Changes for this release:
- Added code to workaround certain types of audio and subtitle extraction errors when working with high count multi-part sources in movie-only mode. - Corrected an error in which audio/sub tracks may be incorrectly identified by track/language when reencoded using movie-only mode from a multi-part source with a large number of segments. - Added the ability to inverse telecine interlaced sources. You select it by right-clicking on the stream in the stream list. This can dramatically improve picture quality on hard or soft telecined sources by encoding at 23.976 with pulldown flags rather than 29.97. Note: Please be careful in using this option as executing inverse telecining on a non-telecined source will result in a severely stuttering picture. It is not uncommon for new users to confuse interlaced "combing" with telecining. Since some types of inverse telecining requires AVISYNTH, LAVF usage for a stream may be by-passed when it IVTC selected. - Added a new selection to the SETUP dialog to enable automatic Inverse Telecining (IVTC) of sources where pulldown/soft telecine is detected. This option instructs BD-RB to inverse telecine during decoding and to reinsert pulldown flags on any detected soft telecined (3:2 pulldown) 29.97fps sources. IVTC also converts soft telecined 1080i sources to 1080p. IVTC is recommended for processing sources that are targeted for playback on standalone units, but may not be suitable if the final playback device is a PC as some PC codecs (e.g. the FFDSHOW AVC codec) don't sometimes play back smoothly when pulldown flags are used. Automatic IVTC for individual streams can be manually deselected via the stream list (see bullet 1 above). - Corrected several instances in which a failed demux in TSMUXER could incorrectly result in the error "ExtractAudio Subs() 00053 1605" or other errors. - Added a fix that corrects bad characters in the source Volume ID that could prevent the creation of the output folder. - Added code to distinguish between full pulldown and hybrid sources. Hybrid is marked with "***" in the streams window, soft telecine (pulldown) is "*". - Corrected an error in which using LAVF on hybrid or pulldown sources could cause audio sync problems. - Corrected an error in which starting and stopping a full backup under certain circumstances could cause incorrect OUT time values to be inserted during MPLS file updates. - Updated the included version of X264.EXE to the latest release (r1732). - Updated the included version of X264-64.EXE to the latest release (r1732). - Other minor corrections and cosmetic fixes. |
7th October 2010, 04:55 | #9779 | Link |
hi i have a problem here is the info
- [13:50:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 211,499 frames - Bitrate: 4,953 Kbs - [13:50:45] Reencoding: VID_00000, Pass 1 of 2 - [16:40:11] Reencoding: VID_00000, Pass 2 of 2 - [20:52:09] Video Encode complete - [20:52:11] Multiplexing M2TS [20:55:37]PHASE ONE complete [20:55:37]PHASE TWO - Rebuild Started - [20:55:38] Rebuilding AVCHD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Can't open file: T:\PELICULAS BD\MILLENIUM 3 RECODIFICADA\WORKFILES\00001.track_4608.SUP [20:55:39] - Failed to REBUILD what can it be wrong? |
7th October 2010, 06:17 | #9780 | Link | |
After a short test it seems to work! (Prince of Persia). I'll donate again! Great Work! |
