30th October 2009, 23:31 | #5782 | Link | |
@jdobbs,
cwh |
31st October 2009, 14:11 | #5784 | Link | |
@jdobbs,
And is there any special settings you can suggest that may solve my audio issue? I'm trying to use BD-R as "turnkey" with standard settings to fully backup onto a DVD-DL which I know is stating the obvious since that why we are reporting potential bugs here. For the last backups I've done, BD-R has been fantastic. Just completed the kids "ICE AGE 3" and it was a perfect dupe so I'm pretty confident with my settings -> just want to make sure I haven't missed any small tweaks that can address some of these particular BDs with higher audio and video track complexity in the main movie and extras (PiP,additional tracks, commentary, etc.). Thanks |
31st October 2009, 14:25 | #5785 | Link | ||
31st October 2009, 14:27 | #5786 | Link | |
I'm going to pick up a copy of "Monsters vs Aliens" this afternoon and see what it does for me. Last edited by jdobbs; 31st October 2009 at 14:33. |
31st October 2009, 15:17 | #5787 | Link | ||
@jdobbs,
And thanks for trying to reproduce my problem. |
31st October 2009, 16:41 | #5788 | Link | |
31st October 2009, 17:29 | #5789 | Link |
@jdobbs,
Tried turning both on and off at the same time. If I understood you to mean "do not include DTS convert to AC3" and "Do not reencode AC3" for BD-9. And also turning on and off "Keep HD Audio for BD25 encoding" when I tried to re-encode for BD-25 ... for me I couldn't find a setting that made any difference to the output.. |
31st October 2009, 19:03 | #5792 | Link |
Elit Amans
BD Rebuilder v0.31.01 Audio encode error
When I did Royal Space Force last night I got an audio encode error.
ReencodeAudio() 00075 1801 My setup was not to convert DTS, not reencode AC3 and not keep HD audio. I'm not sure what has happened here so here comes the logs: LOG: Code:
----------------------- [22:04:01] BD Rebuilder v0.31.01 (beta) - Source: ROYAL_SPACE_FORCE - Input BD size: 32,72 GB - Approximate total content: [02:08:12.351] - Target BD size: 23,73 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [22:04:01] PHASE ONE, Encoding - [22:04:01] Extracting A/V streams [VID_00000] - [22:19:54] Reencoding: VID_00000 (1 of 8) - [09:30:23] Extracting A/V streams [VID_00001] - [09:30:26] Reencoding: VID_00001 (2 of 8) - [09:31:37] ReencodeAudio() 00075 1801 [18:18:15] - Failed to reencode audio, aborted Code:
[Status] LABEL=ROYAL_SPACE_FORCE VERSION=v0.31.01 (beta) SOURCE_SIZE=35128576000 SOURCE_VIDEO_SIZE=35044798464 TARGET_SIZE=25480396800 REDUCTION=.724690121704904 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng;swe; BACKUP_MODE=0 QUICK=0 ENCODE_STEP=3 COMPLETED=1 [00000] AUDIO=111 PGS=11 M2TS_TARGET=24179667480 RATE=23129 NSIZE=23431065600 FLINK=0 MLINK=0 [00001] AUDIO=111 PGS=11 M2TS_TARGET=41759961 RATE=6038 Code:
[Options] MODE=0 ENCODE_QUALITY=3 TARGET_SIZE=23450 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng;swe; SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=0 AVCHD=0 REMOVE_WORKFILES=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=24300 QUICK_EXTRAS=0 [Paths] SOURCE_PATH=J:\TEMP\ROYAL SPACE FORCE\ WORKING_PATH=G:\TEMP\ROYAL SPACE FORCE\ Code:
"C:\DVD-Rip\BD_Rebuilder\tools\x264.exe" "G:\TEMP\ROYAL SPACE FORCE\WORKFILES\VID_00001.AVS" --preset slow --ref 4 --b-adapt 1 --qpmin=0 --bitrate 6038 --level 4.1 --sar 1:1 --aud --vbv-bufsize 30000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 35000 --threads auto --slices 4 --thread-input --stats "G:\TEMP\ROYAL SPACE FORCE\WORKFILES\VID_00001.AVS.MKV.stats" --pass 2 --output "G:\TEMP\ROYAL SPACE FORCE\WORKFILES\VID_00001.AVS.MKV" Edit: One thing I came to think of was that I manually choosed which audio tracks to keep in the "stream" window as my default options didn't apply on this disc. My OS is a freshly installed Win7. I never had any problems before, but yet again it is freshly installed so I could have missed something. //LD Last edited by LowDead; 31st October 2009 at 19:18. |
31st October 2009, 20:00 | #5793 | Link |
@jdobbs
Thanks for providing the Tweaks as hidden options. I tried it and it works well. . Now my question: If I do 1-pass crf encode, will the tweaks be applied for crf prediction pass as well? I am asking because I set TWEAK_PASS_ONE=--me umh --tune film TWEAK_PASS_TWO=--me umh --tune film and got an oversize (BD5 movie only) which I never have experienced before. Therefore my question whether the tweaks are applied for the crf prediction pass (actually they should), or if not, if this could be the cause of the oversize? |
31st October 2009, 20:13 | #5794 | Link |
I see the same oversize issue with TWEAK_PASS_TWO= --me umh --psy-rd 1:0 --direct-auto.
custom size 4555 MB = 4449 MB (4,455,xxx KB) without tweak with tweak 4489 MB (4,596,xxx KB). I'll try to find another calculation that works consistently with tweak. |
31st October 2009, 20:37 | #5795 | Link | |
I made a change to the CRF routine that rounds to the nearest .1 while looping (trying to reduce the number of passes). That's probably what caused the oversize. I'll go change it back. Last edited by jdobbs; 31st October 2009 at 20:48. |
31st October 2009, 20:59 | #5796 | Link |
Maybe im missing it or maybe it's feature request but is there any possibility to make a working bluray with menu. I want to rip all audio streams except one and i want to add one audio stream (cause i want to convert a PCM to DTS).
tia michiel |
31st October 2009, 21:18 | #5797 | Link | |
If so, I just tried to run it again & two of the problem vids were good on sync (0032 & 0051), but the other two vids (0033 & 0037) were just as OOS as before. See ya! |
31st October 2009, 22:40 | #5798 | Link | |
here is the ini [Options] MODE=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=1 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 TARGET_SIZE=23000 ENCODE_QUALITY=5 [Paths] WORKING_PATH=D:\ISO\ SOURCE_PATH=C:\BD BACKUP\DRAG_ME_TO_HELL\ Last edited by pakkman; 31st October 2009 at 22:47. |
31st October 2009, 23:52 | #5799 | Link | |
- [18:17:48] Performing CRF Prediction... - Analyzing 11.00 30.50 25.20 21.60 19.50 18.40 18.00 18.10 18.05 18.08 18.09 [18.09] The steps are .01 rather than 0.1. |
1st November 2009, 00:07 | #5800 | Link |
[17:44:52] BD Rebuilder v0.31.01 (beta) - Source: BATMAN_AND_ROBIN_WW - Input BD size: 30.25 GB - Approximate total content: [02:04:53.861] - Target BD size: 4.35 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [17:44:52] PHASE ONE, Encoding - [17:44:52] Extracting A/V streams [VID_00000] - [18:00:10] Reencoding: VID_00000 (1 of 1) - Switching to FFMS2.DLL for decoding. - Encode failed. Retrying. - Reached retry limit. Aborting. [18:01:15] - Failed video encode, aborted Could someone please tell me what this error means? I just set Windows 7 (yes, authentic student upgrade official release) up on a new machine and didn't encounter this under Vista. This is also a VC-1 disk and a legitimate rip. Last edited by happycase; 1st November 2009 at 00:41. |
