Old 23rd February 2012, 14:36   #1961  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Originally Posted by 8ternity View Post
Audio encoding has failed, same over ffmpeg process.
Why not use eac3to to encode your audio first?
and then AVStoDVD will automatically copy the audio over.
or re-rip the source to audio better than 32 kbps.
Also I notice your logs contain non-standard characters in their names, that could also lead to problems for a lot of programs.
Characters with accents can often lead to many problems with Windows environments.
É is not very Windows friendly for most programs.
I'd suggest renaming everything to very basic names with nothing fancy.
If É is very common, no matter what you do, a simple google search will show the proper way to remove different languages from your keyboard.
Most often the letter "É" is from a keyboard shortcut programmed to use French characters over North American characters. This can be fixed by going into the Control Panel > Languages > and removing/deleting/disabling stuff that's not North American English.
When working with most conversions, my basic principle is that every name must be as short as possible, including file names and folder names. this ensures less errors, as windows is... well just windows lol.
Aside from switching all foreign characters to standard English characters, I'd highly recommend using eac3to to convert your audio to AC3 for AVStoDVD before starting your next project.
You might even need to update/install MP3 decoding filters.
MP3 decoding requires either official LAME MP3 system decoder filters to be installed...
Or, "FFDshow Audio" to be configured to handle MP3 audio.
Either way works fine.
FFDShow would be easier as it does updates more often than official "LAME" releases.
...If FFDShow does not handle LAME MP3 after initial installation, configure it to do so.
Also to handle the usual "Raw Audio - Compatible" etc.
FFDshow on its own or by K-Lite Codec Packs is updated constantly.
LameACM is only good if the source is encoded with Lame MP3; which, yours has been: 3..97.
Lame is currently updated to 3.99.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Old 24th February 2012, 14:26   #1962  |  Link
gobbleman
Problem with PAL speedup
Hi MrC
I have a HD NTSC movie that I want to mux with PAL audio and subtitles.
I want to make a PAL DVD using the 4% speedup, so the video only needs to be resized, right?
So I encoded a 10Mb fragment (obtained using mkvmerge) with output set to Elementary MPEG2 streams.
Looking at the logfile I can see that the result has a different framerate and number of frames.
Q1. Why is DGPulldown used?
Q2. Why does the number of frames differ after encoding, and after DGPulldown?
Thank you very much for this brilliant program, and keep up the great work.
<11-Feb-12 02:35:51 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Titles number: 1
DVD Size: 81/4450 MB (2%)
DVD Output Setup: MPEG2 Streams
DVD Label: DVD
DVD Menu: No Menu
Output Folder: D:\_MyDocs\Movies\_AVStoDVD
Delete Temp Process Files: No
Delete Working Files: No
Edit Command Parameters: Yes
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
PAL SpeedUp: 1
Video Resolution: 1
Video BitRate Min: 2500
Video BitRate Level 1: 8500
Video Profile Level 2: 8500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 1
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 18pt (255,255,255)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: X: HL-DT-ST DVDRAM GH22LS40 LL01
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Display errors messages: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
Save General Settings: 1
TITLE 1 SOURCE FILES
Video: D:\_MyDocs\Movies\_Disney\_Ready\PINOCCHIO\Pinokkio.1940.x264.BDRip.720p\Pinokkio.1940.x264.BDRip.720p (1)-001.mkv
Info: AVC - 1095 kbps - 968x720 - DAR 1.344 - 23.976 fps (CFR) - Progressive - 1:23 minutes - 2000 frames
[MediaInfoLib - v0.7.50]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("D:\_MyDocs\Movies\_Disney\_Ready\PINOCCHIO\Pinokkio.1940.x264.BDRip.720p\Pinokkio.1940.x264.BDRip.720p (1)-001.mkv", CacheFolder="C:\Temp", FrameRate=23.976, VFR=false)
Video = Video.ConvertToYV12
#Using AssumeFPS() to upsize FPS
Video = Video.AddBorders(0,3,0,3)
Video = Video.Spline64Resize(720,576)
Return Video
AssumeFPS("pal_film", sync_audio=true).ResampleAudio(48000)
<11-Feb-12 02:35:57 PM>
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 81.1 MB
HCenc Parameters: -ini "C:\Temp\DVD_0_Pinokkio.1940.x264.BDRip.720p (1)-001.HCenc.ini"
HCenc ini file:
*INFILE C:\Temp\DVD_0_Pinokkio.1940.x264.BDRip.720p (1)-001_1.avs
*AVSRELOAD
*OUTFILE D:\_MyDocs\Movies\_AVStoDVD\DVD_0_Pinokkio.1940.x264.BDRip.720p (1)-001.m2v
*LOGFILE C:\Temp\DVD_0_Pinokkio.1940.x264.BDRip.720p (1)-001.HCenc.log
*MAXBITRATE 9000
*BITRATE 8500
*PROFILE BEST
*ASPECT 4:3
*PROGRESSIVE
*TFF
*BIAS 80
*DC_PREC 10
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 100
<11-Feb-12 02:38:55 PM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: D:\_MyDocs\Movies\_AVStoDVD\DVD_0_Pinokkio.1940.x264.BDRip.720p (1)-001.m2v (59.8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6064 kbps - 720x576 - DAR 1.333 - 23.976 fps (CFR) - Progressive (TFF) - 1:23 minutes - 1998 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "D:\_MyDocs\Movies\_AVStoDVD\DVD_0_Pinokkio.1940.x264.BDRip.720p (1)-001.m2v" -srcfps 23.976 -destfps 25 -inplace -tff
<11-Feb-12 02:38:56 PM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: D:\_MyDocs\Movies\_AVStoDVD\DVD_0_Pinokkio.1940.x264.BDRip.720p (1)-001.m2v (59.8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6059 kbps - 720x576 - DAR 1.333 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 1:23 minutes - 2002 frames
Log file created by AVStoDVD Release 2.4.2
gobbleman is offline   Reply With Quote
Old 26th February 2012, 21:12   #1963  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@8ternity
have you tried with 'Wavi+Aften' as AC3 encoder setup?
@gobbleman
wow, you have found a bug with the AviSynth script generation when 'PAL speedup' is selected AND audio is not present. I will surely fix it in the next release. Thanks!
As workaround you can edit the AviSynth script ('Edit Title'/'AviSynth') by replacing:
Return Video
with
AssumeFPS(Video, "pal_film")
About your questions: of course DGPulldown must not start if 'PAL speedup' is selected. Frames are higher after pulldown because they are inserted to convert framerate without altering the time length.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 3rd March 2012, 23:36   #1964  |  Link
8ternity
8ternity's Avatar
Originally Posted by MrC View Post
@8ternity
No. I've try with HenC 2pass; wich normally everything pass. I remember that Wavi+After has not worked well on many project with avi files; i used HenC Locked has recommended previously by you last year (starting to 2.3.2 version).
I've used Nero Vision Xtra 'latest' to resolve my issue for the moment. I can try later with same files this week to let you know if you need that i test to resolve the issue, or for knowledges, up to you.
THanks.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating.
8ternity is offline   Reply With Quote
Old 3rd March 2012, 23:45   #1965  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Wait, wait, HCenc 2-pass is a video encoding profile, we are speaking about AC3 audio encoder selection: 'Wavi+Aften' instead of QuEnc.
Bye
MrC
AVStoDVD Homepage
Old 5th March 2012, 14:42   #1966  |  Link
Disapearer
Hi MrC
Discovered your nifty piece of software after having issues with Avi2DVD. Searched around and various recommendations led me to AVS2DVD.
My problems with Avi2DVD stemmed with various files going out of sync when converted to an ISO. I've run the same files through AVS2DVD and am pleased to see there are no issues with synching, but there are issues with the picture quality that I've not had with Avi2DVD.
It seems movement causes distortion in the picture with horizontal streaking lines appearing around the edges of objects/characters moving. I've run it through both QuEnc and HCenc but the same problem occurs.
There's a few too many posts to go through every one and see if others have had this problem, but a quick scan through and I can't see anything. The fact that it doesn't appear to be a common complaint leads me to think that it might be easily fixable?
Any ideas or help would be most appreciated.
Many thanks
Disapearer is offline   Reply With Quote
Old 5th March 2012, 19:02   #1967  |  Link
manolito
manolito's Avatar
This certainly sounds like combing artifacts from an interlaced source. If your source is interlaced, you have to decide if you want to keep it interlaced or if you want to deinterlace it before encoding.
I don't have AVStoDVD installed ATM, but I remember that it offers the possibility to edit the AVS script, so you can add a deinterlacer to the script.
Cheers
manolito
Old 5th March 2012, 22:46   #1968  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
As Manolito says, your issue may be caused by an interlaced footage wrongly encoded. BTW AVStoDVD properly handles interlaced sources, if they are detected as interlaced.
Do you have still the project log file? Please post it here. If you don't, could you post the MediaInfo report of your source title?
Bye
MrC
AVStoDVD Homepage
Old 6th March 2012, 18:30   #1969  |  Link
Disapearer
Ignore.
Old 7th March 2012, 01:10   #1970  |  Link
manolito
manolito's Avatar
Video: C:\Torrents\Eastbound\Episode 1\eastbounds03e01.mkv
You won't get any help here for downloaded sources...
Cheers
manolito
Old 7th March 2012, 09:07   #1971  |  Link
Disapearer
Ignore my previous (now removed) email with my apologies.
Hopefully you'll forgive my foolishness and allow me to try again!
So, following on from my initial email, the issue I'm having seems to occur on all files (avi & mkv) and is not specific to any individual files.
Here's the log from a (different) file that had the problem:
<04/03/2012 16:55:33>
START PROCESS
PROJECT SETTINGS
DVD Size: 4449/4450 MB (100%)
DVD Output Setup: ISO UDF Image
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\Converted\AIB
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
Video Resolution: 0
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
DVD Burning Drive: D: TSSTcorp CDDVDW SH-S223C SB01
Save Log file: 1
Save General Settings: 0
Video: C:\Converted\AIB\AIB.avi
Info: XviD - 3999 kbps - 1280x528 - DAR 2.424 - 24 fps (CFR) - Progressive - 1:27:44 hours - 126337 frames
Audio 1: C:\Converted\AIB\AIB.avi
Info: AC3 - 448 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 1:27:44 hours (0 ms delay) - Internal
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\Converted\AIB\AIB.avi", CacheFolder="C:\DOCUME~1\Owner\LOCALS~1\Temp", FrameRate=24, VFR=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("C:\Converted\AIB\AIB.avi", CacheFolder="C:\DOCUME~1\Owner\LOCALS~1\Temp")
#Using DGPulldown/HCenc to upsize FPS
Video = Video.AddBorders(0,96,0,96)
AudioDub(Video, Audio)
Encoding Profile: QuEnc CBR 1-pass
Target Video FileSize: 4080.7 MB
QuEnc Parameters: -i "C:\DOCUME~1\Owner\LOCALS~1\Temp\DVD_0_AIB_1.avs" -o "C:\Documents and Settings\Owner\My Documents\My Videos\DVD_0_AIB.m2v" -b 6503 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<04/03/2012 16:55:46>
A2DVideoSource: AVISource
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\DVD_0_AIB.m2v (1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6222 kbps - 720x576 - DAR 1.778 - 24 fps (CFR) - Progressive - 1 seconds - 34 frames
DGPulldown Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\DVD_0_AIB.m2v" -srcfps 24.000 -destfps 25 -inplace -tff
<04/03/2012 16:55:47>
DGPulldown executed on File: C:\Documents and Settings\Owner\My Documents\My Videos\DVD_0_AIB.m2v (1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6298 kbps - 720x576 - DAR 1.778 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 1 seconds - 34 frames
<04/03/2012 16:55:52>
CHECK LOG FILE <C:\CONVERTED\AIB\DVD_0.LOG> FOR MORE INFO.
Thank you again.
Old 8th March 2012, 13:55   #1972  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Disapearer
I'm not sure what's now the problem: "horizontal streaking lines appearing around the edges of objects/characters moving" or the very short output file?
Bye
MrC
AVStoDVD Homepage
Old 8th March 2012, 14:43   #1973  |  Link
Disapearer
@Disapearer
Bye
Hi Mr C
Sorry, I'm a bit clueless when it comes to these sorts of things, that was possibly one conversion I abandoned early on (I have several of these in the same folder, thought the first would be the one to use!).
Please see what I hope is the correct version below and, yes, the issue is still the picture, and from looking at a site that had pics of interlacing I believe that is the issue:
<04/03/2012 18:20:38>
START PROCESS
PROJECT SETTINGS
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
Video Resolution: 0
Video Profile Level 2: 2500
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
Save Log file: 1
AVISYNTH SCRIPT
Encoding Profile: HCenc VBR 1-pass
HCenc Parameters: -ini "C:\DOCUME~1\Owner\LOCALS~1\Temp\DVD_2_AIB.HCenc.ini"
HCenc ini file:
*INFILE C:\DOCUME~1\Owner\LOCALS~1\Temp\DVD_2_AIB_1.avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\Owner\My Documents\My Videos\DVD_2_AIB.m2v
*LOGFILE C:\DOCUME~1\Owner\LOCALS~1\Temp\DVD_2_AIB.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 6503
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 70
*DC_PREC 10
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<04/03/2012 19:55:52>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\DVD_2_AIB.m2v (3959.1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6354 kbps - 720x576 - DAR 1.778 - 24 fps (CFR) - Progressive (TFF) - 1:27:44 hours - 126337 frames
DGPulldown Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\DVD_2_AIB.m2v" -srcfps 24.000 -destfps 25 -inplace -tff
<04/03/2012 20:05:55>
DGPulldown executed on File: C:\Documents and Settings\Owner\My Documents\My Videos\DVD_2_AIB.m2v (3959.1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6354 kbps - 720x576 - DAR 1.778 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 1:27:44 hours - 126336 frames
START AUDIO DEMUXING OPERATIONS (Track 1)
FFmpeg Parameters: -i "C:\Converted\AIB\AIB.avi" -acodec copy "C:\Documents and Settings\Owner\My Documents\My Videos\DVD_2_AIB_1.ToFix.ac3"
<04/03/2012 20:07:59>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\DVD_2_AIB_1.ac3 (281.1 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 1:27:44 hours (0 ms delay)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\DOCUME~1\Owner\LOCALS~1\Temp\DVD_2_BatchMux.ini"
BatchMux ini file:
-d "C:\Converted\AIB\DVD_2\VIDEO_TS"
-mxp "C:\DOCUME~1\Owner\LOCALS~1\Temp\DVD_2_MuxMan.mxp"
-l "C:\DOCUME~1\Owner\LOCALS~1\Temp\DVD_2_MuxMan.log"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-palette "C:\DOCUME~1\Owner\LOCALS~1\Temp\DVD_2_Palette.txt"
-v "C:\Documents and Settings\Owner\My Documents\My Videos\DVD_2_AIB.m2v"
-vidmode LB
-a1 "C:\Documents and Settings\Owner\My Documents\My Videos\DVD_2_AIB_1.ac3"
-a1lang en
-cellfr "C:\Documents and Settings\Owner\My Documents\My Videos\DVD_2_AIB_Chapters.txt"
-progfr "C:\Documents and Settings\Owner\My Documents\My Videos\DVD_2_AIB_Chapters.txt"
-chapfr "C:\Documents and Settings\Owner\My Documents\My Videos\DVD_2_AIB_Chapters.txt"
<04/03/2012 20:23:59>
CHECK DVD SIZE
DVD Folder (actual) Size: 4315.6 MB
vs Estimated Size: 4449 MB -> 3.0% undersize
vs Assets Size: 4240.2 MB -> OK
END DVD AUTHORING OPERATIONS
Created Folder: C:\Converted\AIB\DVD_2 (4315.6 MB)
<04/03/2012 20:24:06>
Thanks for your time.
Old 8th March 2012, 23:28   #1974  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Disapearer
well, source footage should be progressive, not interlaced:
and AVStoDVD has encoded it as progressive, preserving the field order/setup of the source:
Are you sure that source footage is ok? Do you have the possibility to upload a small portion of it somewhere (i.e. mediafire.com)?
Bye
MrC
AVStoDVD Homepage
Old 9th March 2012, 13:48   #1975  |  Link
Disapearer
@Disapearer
Bye
Hi Mr C
I'm not entirely sure how to take a small portion of footage out (I'd need to figure out how) but it is an issue with all files it seems, not just one, and as I mentioned in my original message the piece of software I have been using produces a perfect picture, it was just having a few audio synching issues that I couldn't solve on certain files. (So basically the files themselves are fine).
Did you want a sample to see a visual of what I'm talking about? Perhaps I can find a pic of something that looks similar?
Old 9th March 2012, 17:41   #1976  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
You can easily use VirtualDub or Avidemux to crop some seconds of footage.
Bye
MrC
AVStoDVD Homepage
Old 10th March 2012, 16:52   #1977  |  Link
Disapearer
Bye
Okay, so I was checking the files to see what footage I could use, and I checked the ISO through VLC.... and it was fine!
Burnt the ISO to disc, checked the disc through VLC, and that was fine too!
As soon as a play it in the blu-ray player through the TV, that's when the image problem begins. I've mucked about with the settings on both the player and TV but can't seem to fix the picture issue, and now I'm completely puzzled why it's occurring.
Any ideas? I'm completely lost (and out of my depth, tech-wise!).
Cheers.
Old 11th March 2012, 23:16   #1978  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
It could be that your BD player does not welcome mpeg2 footage with pulldown. In your case pulldown has been applied by AVStoDVD (thru DGPulldown) to change framerate from 24fps to 25fps.
Take a look to your player manual (or any related forum) to verify this guess.
If the guess is correct, as workaround you can go with the AssumeFPS approach. Add to the end of your project AviSynth script the following line:
Bye
MrC
AVStoDVD Homepage
Old 12th March 2012, 19:38   #1979  |  Link
Disapearer
Bye
Okay, well that fixed the picture issue (yay!) but it threw the audio completely out of synch by about a minute! So, somewhere in between then?
Thanks
Old 13th March 2012, 13:51   #1980  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Ops, sorry, I forgot to tell you to force audio re-encoding: go 'Edit Title'/'Audio' and toggle off 'Keep DVD compliant audio'.
Bye
MrC
AVStoDVD Homepage
[IMG] code is Off
