28th December 2009, 18:42 | #11021 | Link | |
And to Tetsuo: sure, all E/AC3 variants and most lossy codecs (DTS, Vorbis, etc.) should be decoded to 32fp. PCM output bit-depth is a separate issue. But really, I wasn't saying that you shouldn't use 24-bit output. If you can, then heck, why not. I was just advising the guy that, although he can't get 24-bits to work ATM, it's really not something to worry too much about. And I'd say that for anyone having similar problems. Apologies for my further OT blathering Last edited by flanger216; 28th December 2009 at 18:48. |
28th December 2009, 19:14 | #11022 | Link | |||
http://en.wikipedia.org/wiki/Dither "If colored dither is used at these intermediate processing stages then the frequency content can "bleed" into other, more noticeable frequency ranges and become distractingly audible." It's worth noting that some studios are using colored dither for 16bit lossless tracks (I checked that myself). So if 16bit lossless Blu-Ray tracks are processed by the source device *and* by the receiver, and the transport is done in 16bit, there may be 3 colored dithers added on top of each other. Quote:
Generally, I guess my point of view is that studio provided 16bit Blu-Ray tracks are ok, but I prefer 24bit transport, because that should reduce chances of audio ever being truncated or rounded down to 16bit somewhere in the chain... Last edited by madshi; 28th December 2009 at 19:17. |
28th December 2009, 19:32 | #11023 | Link | |
Even EVR custom is much better without loaded subs. Subs are heavy burden for MPC. With M$ decoder I can even use bicubic resizer (but not for 4:3 stretched to 16:9) and MPC HC works great despite small problem with internal decoder @Win7 |
28th December 2009, 19:33 | #11024 | Link |
Kid for Today
dithering is nice, but it adds white noise...and post-processing white noise ain't cool...native 16 bit can be great, but going 24>16 w/ dithering in eac3to sounds ugly to me...apparently each bit decimation adds twice more white noise.
I don't think they did...decoding lossy audio to anything else than 32fp doesn't make much sense(liba52 and libdts do decode to 32fp) Last edited by leeperry; 28th December 2009 at 20:41. |
29th December 2009, 09:46 | #11027 | Link |
Does anyone know of a way to get MPC-HC to read .m3u8 playlists? The player already can read and write playlists in UTF-8 but when I attempt to open a .m3u8 file created in winamp it will not open. I was under the impression the encoding was the only thing different about these types of files in comparison to regular .m3u files but perhaps there is something in the header that MPC-HC is missing?
29th December 2009, 14:23 | #11029 | Link |
If renaming works, then you could add .m3u8 to the playlists entry in options->player->formats
MPC-HC 2.2.1 |
29th December 2009, 16:31 | #11031 | Link | |
29th December 2009, 16:47 | #11032 | Link | |
29th December 2009, 17:19 | #11034 | Link | |
29th December 2009, 17:22 | #11035 | Link |
MPC-HC Project Manager
if windows7 works at 32bit float, its best to ouput the same thing straight from the decoder, in this case we have full control over the dithering used (if any)
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
29th December 2009, 18:08 | #11036 | Link | |
No problem for 24/48 5.1. Will MPC-HC audio renderer sometime support ASIO protocol output? |
29th December 2009, 18:16 | #11037 | Link |
I have tested the issue on two systems:
Software Setup Windows 7 64 bit 32 bit ffdshow 3171 32 bit MPC-HC 1453 32 bit Gabest Splitter for all codecs applicable (no Haali) AnyDVD (latest) EVR Custom Playing Bluray Movies right from disc - Public Enemy Superman System 1 Core i5 - 4GB RAM ATI 4870 x2 HDMI to Samsung 52" LCD System 2 Core 2 Quad Q9400 - 4 GB RAM Geforce 275] DVI to 24" monitor Without "Enable Frame Time Correction" it stutters and I see there is significant frame loss. With enabled plays smoothly but I see significant pixelation but is random. Depends on the scene and its not the whole image just certain parts - almost as if the bit depth of the color has decreased... I am using the default Windows codec but have tried FFDSHOW built in and WM9 codecs.. same results... any ideas? |
29th December 2009, 20:36 | #11038 | Link |
Strangely enough, renaming the .m3u8 playlist to .m3u works for me but, similar to betaking, leaving the extension alone and just adding it to the list in options>formats does not work. BTW, I downloaded a video file the other day that was .asx but was not a stream, it was a full video file stored locally. When I used MPC-HC to open the file, it crashed. However, when I renamed the file to .asf, it worked perfectly. Whether or not "use WM ASF reader" was checked made no difference. It seems the player is either looking for something in these playlist/streaming files (.asx, .pls, .m3u, .m3u8, etc.) that its not finding or it is failing to do something correctly.
29th December 2009, 20:47 | #11039 | Link |
mikelebron,
Are you are using ffdshow to decode h264/vc1, I don't think we can help with ffdshow. Try the default mpc-hc setup - enable internal filters, and output "EVR Custom Pres.", Bilinear PS2.0, EVR Buffers 5, and enable "Reinitialize when display changing." Remove ffdshow from external filters, if present. Also, nVidia & ATI drivers behave differently, so the same settings may not work on both, and may exhibit different behavior / bugs. |
