12th October 2007, 20:20 | #2161 | Link |
Interlaced pictures + spatial direct mode is not yet supported by libavcodec.
^ maybe your sample uses that.
MPC-HC 2.2.1 |
13th October 2007, 06:24 | #2162 | Link | |
I have a Nvidia 7900gs and it had been bothering me for a while. Is this the intended outcome? Anyways, whoohoo! |
13th October 2007, 11:40 | #2165 | Link | ||
And I've found another sub that gives problems if its embedded, externally shows correctly all characters but internally for example "É","é" aren't shown. If its useful, MPC doesn't have problems showing this embedded subs. thx Code:
http://massmirror.com/69c2dca1ade8b6d089c7ef3968e2cd9c.html |
13th October 2007, 12:50 | #2167 | Link |
If you use TortoiseSVN:
http://tortoisesvn.tigris.org/TortoiseMerge.html#patch |
13th October 2007, 13:09 | #2168 | Link |
Curious BetaTester
has anybody tried to build a unicode version of ffdshow with gcc ?
is it actually possible ?
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC |
13th October 2007, 13:20 | #2169 | Link | |
13th October 2007, 13:28 | #2173 | Link | |
13th October 2007, 14:59 | #2174 | Link | |
@yesgrey3,
It's not clear to me why these values are changed during the adaptation, although they some something about it in Annex I and II (those are removed in the final spec). Check your pm. |
13th October 2007, 14:59 | #2175 | Link | |
ffdshow user
http://rapidshare.com/files/62266102...3_xxl.exe.html |
13th October 2007, 17:53 | #2176 | Link | |
I can't get the sound out of the right SIDE speaker using custom matrix (can't route any audio out of this one using custom matrix). I can get sound out of left SIDE speaker and by using channel swap I can get sound out of right SIDE speaker. |
13th October 2007, 21:54 | #2177 | Link |
Otaku
@haruhiko_yamagata
Thanks for the patch, don't forget to eventually add the meters along with the solo and mute buttons on the volume filter for the back center and side surround speakers. Unfortunately I can't help test because I only have a 5.1 setup and an Audigy 2 ZS witch uses those 3 channel jacks for the surround speakers. Also, I was wondering if you can add a filter that could load directsound audio processing filters from within ffdshow, when you have the time of course. @_xxl Thanks for the build.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
14th October 2007, 01:01 | #2178 | Link |
Overlay + RGB output gives bad quality output for me. The picture is a bit blurred. No problems with VMR9 or Haali renderer.
It this a simple matter of crappy graphics hardware/drivers? Or is it a limitation of Overlay or perhaps an ffdshow bug?
MPC-HC 2.2.1 |
14th October 2007, 07:00 | #2179 | Link | |
I guess the side effect of using the conversion in FFDSHOW is that "modify full-screen video options" in forceware no longer works for me. But who cares, the picture quality is billion times better This should be default for anyone with Nvidia cards. I can't get over how good video looks now. Last edited by gunnerhkjp; 14th October 2007 at 07:03. |
14th October 2007, 11:16 | #2180 | Link |
Otaku
@clsid
That goes for me as well. I get a pixelrated image like it uses a different resizer for RGB32. For RGB 24 or lower I even get a different aspect ratio with overlay, haali and vmr7, for vmr9/evr it does not connect. 6800gs/163.75 [EDIT]VMR7/9 windowed looks like crap as well with RGB32[/EDIT]
