Old 11th September 2008, 22:49   #1441  |  Link
Yoshiyuki Blade
Novice x264 User
Yoshiyuki Blade's Avatar
Hmm... FAQ above the one I mentioned in my last post has me a bit concerned:
Q. What is new in GeForce 8400, GeForce 8500 and GeForce 8600 GPU video processors?
These GPUs feature a new video engine that includes a bitstream processor (BSP) and an improved programmable video processor (VP).
Are they referring to VP2? If so, the early generation 8 series cards won't be capable of this technology.
"I'll take a potato chip... and eat it!"
Yoshiyuki Blade is offline
Old 12th September 2008, 06:23   #1442  |  Link
nm
Yes. See this table for GeForce 8 cards that have/don't have VP2: http://en.wikipedia.org/wiki/Compari...its#Features_3
nm is offline
Old 12th September 2008, 06:31   #1443  |  Link
I think the decode will still work on VP1, though not as efficiently.
Guest is offline
Old 12th September 2008, 06:44   #1444  |  Link
squid_80
Doesn't the CUDA video decoder need compute capability 1.1?
squid_80 is offline
Old 12th September 2008, 09:28   #1445  |  Link
canTsTop
canTsTop's Avatar
Originally Posted by canTsTop View Post
4. Can be done something for preventing audio/video synchronization lost and DGAVCDecode crash for TS recordings with errors? Here is sample http://www.mediafire.com/?7wohntw2ijw
When i play it with MPC+ffdshow it shows corrupted frames (i don't mind it) but wont crash and audio/video synchronization is back after errors.
The crashing I can mitigate with a try/except block. I'll put that on the to-do list. The sync issues are more difficult. The reason MPC can do it is because MPC still has the timestamps in the stream. But when you demux you lose them. It's better I think to preprocess the stream with a tool such as ProjectX. I may write one.
Crazy idea. Is it possible to add future then saving project to decode audio to wav with correct time stamps so it matches video?
canTsTop is offline
Old 12th September 2008, 12:20   #1446  |  Link
Sorry, but I can't follow your point, as your English appears malformed.
Guest is offline
Old 12th September 2008, 14:19   #1447  |  Link
canTsTop
canTsTop's Avatar
Sorry for bad English... I meant: is it possible to decode audio using timestamps in TS file so audio and video be in sync. Like MPC synchronize audio after errors, to decode this synchronized version of audio. Probably its crazy idea...
canTsTop is offline
Old 12th September 2008, 14:28   #1448  |  Link
I'm not thrilled about the idea of doing audio decoding in DGAVCIndex. I have on my to-do list insertion/deletion of audio to demux a zero-delay stream, but it's not high on my priority list. And it would be for the start of the stream only. I think error correction for corrupted streams belongs in a separate application.
Guest is offline
Old 12th September 2008, 14:31   #1449  |  Link
Schmendrick
@canTsTop: What ProjectX does with Mpeg2Ts-streams is that it fills up missing or faulty video and audio frames, shifts the audio relative to the video to keep synchronity when both streams are demuxed, thus loose their time stamps and then are remuxed again. If at random frames in the original streams are missing or faulty then the desynchonization becomes unrepairable. If you keep the time stamps a proper decoder can resynchronize video and audio.
As long as you have faulty clips the streams should always be retained at least within their Programme Elementary Stream container.
Another problem is that the video frames in e.g. satellite H.264-streams are not transmitted in the order as the clip has been made, but rather in the order how the stream has been encoded. According to the time stamps I have found e.g. the following frame order within such a video stream: 7, 8, 3, 4, 1, 2, 5, 6, 15, 16, 11, 12, 9, 10, 13, 14, 23, 24, 19, 20, 17, 18, 21, 22,..... The audio stream is usually laging behind the video by up to one second.
To be able to properly synchronously cut such streams even if they are error free you would have to reorder the frames and shift the audio packets relatively to the video packets to be able to do a cut properly. The begining in front of an I-frame and the end after an I-frame or a P-frame.
Schmendrick
Schmendrick is offline
Old 15th September 2008, 07:26   #1450  |  Link
LOGiC
@all,
are there any known problems with the Indexing of bigger AVC/H264 files ? I tried to index a 1080p 8GB file, but when trying to load the indexed file into meGUI, it just gave me a green screen and no picture, but it works fine with i.e. 4,5GB 720 files. Any ideas ?
Thanks in advance.
LOGiC is offline
Old 15th September 2008, 11:18   #1451  |  Link
Ranguvar
Ranguvar's Avatar
I've indexed 1080p files over 15GB, so no.
Bad stream? Try muxing to M2TS/demuxing. If it still won't go, chop a sample, test, and send it in.
Ranguvar is offline
Old 15th September 2008, 15:33   #1452  |  Link
rebkell
I don't know if this has already been addressed, but on the CLI version, if you leave the dga off of the output file, it will crash, and if you put the .dga extension on the output file, then when demuxing the audio, it will include the .dga as part of the demuxed audio aka
Eureka0102.dga PID 1100 DELAY -39ms.aac
this is on 100a35, it's no big problem, just inconsistent with the gui version, which doesn't put the dga in the demuxed audio file.
It will actually index the file and create the output dga file, without an extension, but I guess it crashes on the audio file, it doesn't create one at all.
Edit: Ok, it does create the audio file when you leave off the dga extension, but it crashes on completion.
rebkell is offline
Old 19th September 2008, 02:07   #1453  |  Link
Ranguvar
Ranguvar's Avatar
Bug report, though I doubt you'll be able to replicate it, since it was random... I've used DGAVCIndex a lot today, and when I opened it this time, I couldn't see it, though it was on the taskbar. Hmm. Odd. What was really odd is that in WinFlip (fancy graphical Alt+Tab like Vista), I could see the window.
I downloaded DGAVCIndex again, ran the new one, and it worked. So, I checked my INI file, as that was the only difference between the two. Lo and behold - my window position was set to -3200,-3200. Changed it to 100,100, as it was in the default INI, and now it works.
Again, doubt you'll be able to replicate/fix, and it may have been on my end, but I'll post this for anyone else if they run across the problem.
Ranguvar is offline
Old 19th September 2008, 02:22   #1454  |  Link
It happened to me once, too. I couldn't repeat it and the code looks OK so I never bothered about it.
Guest is offline
Old 19th September 2008, 04:36   #1455  |  Link
Sagekilla
x264aholic
@Ranguvar: I think the issue has to do with the ini file. I had this same problem as well, but as soon as I closed the application and deleted my ini to have it regenerated, it worked perfectly fine.
I should note, neuron2, that this problem exists in DGAVCIndexNV too.
Sagekilla is offline
Old 19th September 2008, 12:14   #1456  |  Link
Same code for INI file handling. What we need to fix it is a procedure for making it happen. I could also add a sanity check on the values when loading the INI file.
Guest is offline
Old 19th September 2008, 12:28   #1457  |  Link
krieger2005
krieger2005's Avatar
The main question for me is where these numbers (-3200) came from. I mean, if DGAVCIndex write them into the ini-file it should get them from somewhere. Maybe it is a OS-Problem then? If so, then a so called "sanity check" whould be the best thing. In general i think such a check is usefull when for exaple if someone lower his resolution, so the DGAVCIndex fall out of the monitor-view. Or if someone give his DGAVCIndex zipped to his friend with different Monitor-Resolution.
krieger2005 is offline
Old 19th September 2008, 12:40   #1458  |  Link
squid_80
Don't break my secondary monitor (whose co-ordinates range from {-1280,0} to {0, 1024}). However do feel free to swear at MS for allowing stupid desktop geometries.
squid_80 is offline
Old 19th September 2008, 13:08   #1459  |  Link
GetWindowRect().
Guest is offline
Old 22nd September 2008, 12:45   #1460  |  Link
medp7060
I have a ts clip of h.264/aac+. DGAVCDec 1.0.0 Alpha 35 demuxed the audio as AAC LATM/LOAS. Strange thing was PowereDVD could not play the resulted aac audio. However, it played the original ts clip well. Any isea what was wrong?
medp7060 is offline
