17th June 2009, 18:16 | #101 | Link |
There was an attempt to revive it though, you can find it Here, latest version is VirtualDubMOD v1.5.10.3. I still use it for the ability to add Multiple Streams (Audio), as I usually tack on an Instrumental Track onto Music Videos.
(Not too sure if VirtualDub supports that, as the last time I check, it doesn't) |
23rd August 2009, 23:20 | #102 | Link |
FYI, the current version of VD has almost all the features used to be added in VDmod, either built-in or through plugins. see here for plugins
http://forums.virtualdub.org/index.php?act=ST&f=7&t=12664& http://forums.virtualdub.org/index.p...15&#entry59509 http://forums.virtualdub.org/index.p...T&f=7&t=12664&, http://forum.videohelp.com/topic348265.html Last edited by medp7060; 23rd August 2009 at 23:25. |
24th August 2009, 10:54 | #103 | Link |
These 2 Links arenīt working
by the way, is mp3 VBR in AVI now possible in VD or via plugins?
24th August 2009, 11:46 | #104 | Link |
VideoAudio
First link - "VirtualDub File Input Filter" topic
Third link - probably same as first (same topic number). VBR audio has been supported since VD 1.8.0.
VideoAudio.pl - Serwis o technologii wideo & audio |
24th August 2009, 14:53 | #106 | Link |
VideoAudio
Rather question is... VDM can be replacement for current VD?
I think - can't. Current VD does not support some features present in VDM (for example, partially support OGM and MKV). Some old reasons for use VDM are obsolete. Current VD support: VBR audio, import other audio than WAV, export RAW audio (practically same as demux), selection of audio stream, ... Also, VDM does not contain new (VD) features (smart rendering, curve editor, internal decoders for MJPEG and DV, import plugins support, ...) and of course does not contain bugfixes from last few years.
24th August 2009, 19:31 | #107 | Link |
Yes its unfortunate someone hasn't taken the virtualdub reigns. I don't mean using the old Virtualdubmod and re-releasing it with a fix or two, I mean taking the current release of Virtualdub and back-adding the plugins and support for the features that are still used in Virtualdubmod that aren't available in Virtualdub.
20th February 2010, 16:28 | #108 | Link | |
of VDMod, would love it if it came with VD regular. By the way, I currently have 3 versions of VD installed on different hot keys. You can just make a copy of the install directory and move it anywhere. The only difference I've ever noticed in copying that directory to a new install is, it pops up with the initial copyright notice etc, probably meaning it writes something to the registry. Just install, copy directory, remove and then do same with other VD versions. You will of course have to create shortcuts and hotkeys etc manually. You will also need to install your plugins in all directories. Also, beware, I've just recently upgraded the Mpeg2 source plugin and found it produced crashes on some MP2's. Same files loaded just fine in VDMod and VDMpeg2. So, keep a copy of the old plugin, just in case.
13th April 2011, 21:59 | #110 | Link |
Hi boys... how i can set "Aligned on Interleave" instead of "Split accross interleave" ??
i need to convert this file on XVID: Code:
General Complete name : C:\Users\Diabolik\Desktop\Prova.mpeg Format : MPEG-PS File size : 25.9 MiB Duration : 35s 40ms Overall bit rate : 6 202 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Default Format settings, GOP : M=3, N=12 Duration : 34s 880ms Bit rate mode : Variable Bit rate : 5 823 Kbps Nominal bit rate : 9 100 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.562 Stream size : 24.2 MiB (93%) Audio ID : 189 (0xBD)-128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : DVD-Video Duration : 35s 40ms Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 1.07 MiB (4%) Code:
General Complete name : C:\Users\Diabolik\Desktop\Prova2.avi Format : AVI Format/Info : Audio Video Interleave File size : 5.91 MiB Duration : 34s 880ms Overall bit rate : 1 422 Kbps Writing application : VirtualDubMod 1.5.10.2 (build 2542/release) Writing library : VirtualDubMod build 2542/release Video ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : 2 Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 34s 880ms Bit rate : 1 282 Kbps Width : 624 pixels Height : 352 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.233 Stream size : 5.33 MiB (90%) Writing library : XviD 58 Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Codec ID : 55 Codec ID/Hint : MP3 Duration : 34s 824ms Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 544 KiB (9%) Alignment : Split accross interleaves Interleave, duration : 41 ms (1.01 video frame) Interleave, preload duration : 500 ms |
13th April 2011, 22:28 | #111 | Link | |
Use Virtualdub and then use Mkvtoolnix to mux your MKV...
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card http://twitter.com/cwebdesign |
29th October 2017, 07:42 | #112 | Link |
VIRTUALDUBMOD
Hi I have two PC one AMD + one DELL i7 I have an inexplicably problem virtualdubmod works very well with AMD but "don't start" with i7, excactly don't start. I tried original virtualdub, this start but don't work to encode AVI with xvid 1.3.0, the same with nandub there is someone that can help me to understund what could be the problem? thanks |
29th October 2017, 08:01 | #113 | Link |
Try this, (sort of the current replacement for both VDub and VDubMod), VirtualDubFilterMod (AKA VirtualDub Deep Color):-
http://forum.doom9.org/showthread.php?t=172021
14th March 2018, 11:37 | #114 | Link |
No-one should be using the now defunct VirtualDubMod, the above post linked VirtualDubFilterMod is now renamed to VirtualDub2, and is better by far than all previous versions of VirtualDub (any flavor), also includes similar Avisynth script editor to that provided by the old VirtualDubMod (many versions of which had an off-by-one-frame error in the Insert TrimSet type keyboard functions).
It's lovely, why not suck-it-and-see Repeat link, VirtualDub2 by 'Shekh the Magnificent' (x86 & x64):- https://forum.doom9.org/showthread.php?t=172021
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 14th March 2018 at 15:32. |
