19th November 2003, 14:50 | #321 | Link |
@ookzDVD
First of all, make sure that the encoded avi does playback properly in Vdub. If it does you have a couple of choice: Turn off FFV1 decoding in the ffdshow 2003-10-28. MPC should now use ffvfw 2003-09-27 for decoding (you will see AVI Decompressor (FFV1) under filter). Or, copy the libavcodec.dll and libmplayer.dll file from your ffvfw 2003-09-27 folder and drop it into the ffdshow 2003-10-28 folder. Finally, the best solution, uninstall ffdshow 2003-10-28 and install ffdshow 2003-09-27 I downloaded the ffdshow 2003-10-28 and also got the green screen. It seems that libavcodec support for FFV1 is broken in both ffvfw and ffdshow 2003-10-28 builds. BTW, I still use ffdshow 2003-04-24... All the latest ffdshow either crash or freeze when playing Packeted Frames DivX50 avi with Chroma Dering postprocessing on. As for ffvfw setting, the default work fine for me: YV12 VLC 0 250 Last edited by winman; 19th November 2003 at 15:37. |
22nd November 2003, 18:38 | #322 | Link |
DVD Rebuilder!
@winman,
Thank you for the update, I did try encode use the build 2003-09-27 and disable the ffdshow for ffv1, and everything is working now. @CruNcher What is your decoder anyway ? PS. Wanna try with 2003-11-13 build again. Thanks. |
1st December 2003, 11:46 | #323 | Link |
heya
i think i am blind ffmpeg offers two error resilience methods: data partitioning and resync markers i only find the data part option in ffvfw, but not the resync markers (called "error resilience" in the ffmpeg docs)! would be great if this option could be implemented in ffvfw too edit: and doesnt ffmpeg support outputting real .mp4 streams (i mean no avi hacks aso)? if yes, would be great if that could be possible in ffvfw too
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 1st December 2003 at 11:54. |
1st December 2003, 19:50 | #324 | Link |
clueless n00b
if I may interject. Is there a way to use the standard ffmpeg 2 pass encoding method rather than the xvid one when using libavcodec's internal mpeg4 encoder?
31st January 2004, 01:38 | #325 | Link |
NickSteel
I'm testing ffvfw with an NTSC anamorphic Widescreen 2.35:1 DVD. I wish to make a test NTSC anamorphic Widescreen 2.35:1 DVD. I'm using Forcefilm in DVD2AVI. My avisynth avs, which I load into VDub, only contains the mpeg2source line with the d2v file.
I run Pulldown.exe at the command prompt as: "pulldown myfilmIN.m2v myfilmOUT.m2v" to get 23.976fps. TMPGEnc Author says that the GOP is "too long" (must be 18). Which settings, if any, should I change in ffvfw? What settings should I choose in DVDPatcher? Sorrrrrry about all the questions, but you can see I'm a bit confused. My encoding is usually confined to PVR250 TV captures, but I'm using this method to figure out how to use ffvfw. I would sincerely appreciate any aid / advice. |
12th February 2004, 19:52 | #326 | Link |
Any news on this codec?
I'd like to hear some feedback on MPEG-1/2 encoding with FFVFW, seems to have potential versus TMPGEnc and CCE. These guys have been crazy about it http://kvcd.net/forum/viewforum.php?f=68 But from what I heard it's not very stable in the 2-pass and rate control arena (I'm just talking about MPEG-1/2 here). Best regards, Bilu |
12th February 2004, 21:12 | #327 | Link |
NickSteel
Look on kvcd.net for some settings at:
http://www.kvcd.net/forum/viewtopic....r=asc&start=16 I've used the KDVD settings with very good results. The only real problem is the maximum bitrate sometimes generated. It hasn't affected my standalone player so far. I do PVR250 analog cable TV captures to DVD with a couple or three movies per DVD. Very good results. |
13th February 2004, 00:01 | #328 | Link |
My goal wasn't really FFVFW but FFMPEG, until I saw this post
http://kvcd.net/forum/viewtopic.php?p=62465#62465 I wanted to use FFMPEG or FFMPEG-based solutions like Mencoder for DVD backup under Linux/FreeBSD because it's 4 times faster than mpeg2enc/mjpegtools-based solutions like transcode. I have a thread on that subject. But in Kwag's opinion FFVFW already corrects some stuff from FFMPEG, it's not just a frontend. http://forum.doom9.org/showthread.php?s=&threadid=69598 Bilu |
21st March 2004, 02:51 | #330 | Link |
Matroska Dev
DV Decoding?
Would it be possible to add DV decoding to ffvfw?
The only other free DV VFW codec I know of is the Panasonic one which only does RGB in/out and it's YUV->RGB routines are not the best in quality.
The Matroska Effect |
5th April 2005, 18:49 | #332 | Link |
Can I somewhere download a copy of ffvfw.dll with MakeAVIS? I have problems with MakeAVIS deliverd with the latest fddshow (the first time I tried MakeAVIS). A guy in another forum has the same problems as I, and his problems began at the momemt ffvfw was integrated in ffdshow.
The problem is that DVD2SVCD cannot read a fake AVI made by MakeAVIS. In the preview window, a AviSynth error is showed: could not decompress frame 0. So my question: Can I download somewhere the latest version of ffvfw.dll with MakeAVIS? |
5th April 2005, 19:06 | #334 | Link | |
And the third post.. I will edit that post Last edited by ernstblaauw; 5th April 2005 at 19:11. |
5th April 2005, 22:07 | #335 | Link |
The link to a working makeAVIS version: http://forum.doom9.org/showthread.php?s=&threadid=84481 (the end of the first post)
7th April 2005, 17:11 | #337 | Link | |
