10th July 2007, 15:01 | #341 | Link | |
Maybe Tranzcode.exe (0.4) would be the Better implemention for eac3to Its a small exe and Tranzcode 0.4 can directly decode the dts hd to wave. It decodes the included dts core ofcourse simple command : tranzcode.exe inputdts.dts output.wav switches : / -mch = multichannel wave output /-16 or 24 or 32 and you can extract single channles only |
10th July 2007, 15:37 | #342 | Link | |
10th July 2007, 15:56 | #343 | Link |
surcode problem
Hi Madshi,
i tried different PCM track but still the same error. Creation of DTS failed. When i do manually, everything is ok, surcode will create proper DTS. Is there something i could be doing wrong? And the second question, mono wav file are correct as it says. Does it mean that they are also mapped to be feeded to surcode in order 0-1-2-3-4-5? (In this case, is C channel really C?) |
10th July 2007, 16:01 | #344 | Link |
@MichaelHarbart
eac3 mono wave (.wavs) output is : 1 Left 2 Right 3 Center 4 LFE 5 SL 6 SR Surcode input order is the same Have you Surcode DTS Pro 1.0.23 installed ? You need minimum v1.0.23 @madshi No Nero only decodes the Core. You can see it when you craete a graph with NeroAudioDecoder2 on a dtshd. Decoding info is only 1536kbps (core depended) And i never had succes to connect dts with sonic. When its possible ,i dont believe Sonic Decoder can decode full dtshd Theres currently no Decoder which can decode the full dtshd Imho the simple core extraction makes most Sense, unless you want encode standard dtscore to ac3 Maybe you can implement both Options for dts hd. Decoding dtshd(core) to wave with Tranzcode and extract dtscore from dtshd Last edited by ACrowley; 10th July 2007 at 16:13. |
10th July 2007, 17:39 | #345 | Link | |
Creation of mono wav files is always OK but then "Creating the DTS file failed". This message appears immediately after mono wav files are created. |
10th July 2007, 21:35 | #346 | Link | |
eac3to should name the mono files correctly. C should really be C etc. |
10th July 2007, 21:37 | #347 | Link | |
11th July 2007, 09:14 | #348 | Link |
Madshi,
Thanks for the method to transcode DD+ to LPCM. When using sox to change to Big endian, because the input file is raw I have to tell sox a few parameters of the input file so it can process it - i.e. sample rate, sample size, data encoding & channels. Is there any way to tell what the output file eac3to produces will be when the input file is DD+ so I can pass sox the correct data? Again, thank you for your time! |
11th July 2007, 09:31 | #349 | Link | |
11th July 2007, 09:37 | #350 | Link |
One more quick question. If nothing else is used in the eac3to command line, which DD+ decoder is used by default? I have both Sonic 4.2 and Nero (blu-ray & hd-dvd plugin) but I think my Sonic decoders have gone a bit "screwy", even after reinstalling them. If I wish to use the Nero decoder do I have to rename eac3to.exe to recode.exe?
I'm very sorry for so many questions! |
12th July 2007, 11:51 | #353 | Link |
Well, I finally decided to give up on LPCM. I was finding it too difficult to mux it into anything, so I decided to use flac. Gotta say the procedure is MUCH easier!
Anyway, when it comes to setting up a directshow graph to play back my completed mkv file, for those encoding to flac, what filter is the best to use? I'm currently using ffdshow (although an older version) and it seems to work OK, but I wanted to know if there's anything better out there? Also, is there any perceived quality difference between keeping 24 bit or downconverting to 16 bit? As an alternative, is transcoding to a multi-channel wav file a better way to go, quality-wise? Thanks to Madshi for a truly break-through app! |
12th July 2007, 12:17 | #354 | Link | ||
FLAC is lossless, so it's 100% identical to LPCM and to WAV. Basically WAV is the same as LPCM, just with a little header in front of the LPCM data. FLAC is like a zipped WAV. |
12th July 2007, 18:31 | #357 | Link |
new CinemasterAudio.dll v4.3.0.169 + SonicHDDemuxer.dll v4.3.0.89 are out (as part of CineVision 2.0.2final).
there are no "discontinuities" errors with the new versions: http://forum.doom9.org/showthread.ph...02#post1019802 and as a result there is no noise when decoding TrueHD, but the output is very different from the old CinemasterAudio.dll v4.3.0.151 + SonicHDDemuxer.dll v4.3.0.73 (part of CineVision 2.0.2beta): http://forum.doom9.org/showthread.ph...41#post1019241 which is very confusing, because the old version has almost the same output as Nero for "Nine Inch Nails: BYIT bonus TrueHD track" and now it is entirely different: and the "Vendetta TrueHD stream" output is no more 16bit, but seems more like 8bit: the big surprise is that after overwriting of the new DLLs with the old ones, there is again no noise and the output is byte by byte identical, so maybe some registry settings are affecting the behavior of the Sonic codec, but i haven't time to dig deeper and find out what is really going on. Last edited by xkodi; 12th July 2007 at 18:35. |
12th July 2007, 18:37 | #359 | Link | |
How does it sound? Does the WAV look and sound alright? |
12th July 2007, 18:51 | #360 | Link | |
P.S. i'm comparing part of Nine Inch Nails track with a lot of drums and Sonic even sounds much better than Nero, at least in my opinion. [edit] and with Vendetta track: Nero output is very bad - the voices are low and unclear, with Sonic the voices are very clear and the volume is much pleasant than the Nero. Last edited by xkodi; 12th July 2007 at 19:10. |
eac3to |
