21st January 2008, 16:20 | #2781 | Link |
Just did a new attempt with Born on the 4th of July.
2.15 gave a couple of frame gap/overlaps 2.16 gave less frame gap/overlaps problems 2.13 gave a smooth playable file with audio in synch (watched a couple of minutes at the start of the movie, att the middle and a few minutes before the end) |
21st January 2008, 16:46 | #2782 | Link | |
21st January 2008, 16:51 | #2783 | Link |
I was too slow to grab 2.15 before 2.16 came out. Would anyone be kind enough to provide a link to 2.15 via a site like rapidshare, mytempdir or other file hosting place please? Many thanks.
Chumbo |
21st January 2008, 17:59 | #2787 | Link | |
The garbled output appears on my PC with the MS VC-1 decoder and VMR9. The Sonic VC-1 decoder doesn't even show any picture. It just freezes. Had exactly the same symptoms with "The Searchers". That makes now 2 HD DVD VC-1 movies which my PC cannot handle at all. Fortunately all other VC-1 movies worked just fine for me until now. Not sure where the problems with those 2 movies are coming from. Maybe the VC-1 stream is incorrect somehow and PowerDVD's VC-1 decoder just knows a way to work around that somehow? |
21st January 2008, 18:31 | #2788 | Link |
I'm try to get a pulled down raw VC-1 stream out of an EVO with eac3to. I tried the -demux option and it said "no format was specified for the demuxer..." I did manage to get an mkv to work with 2.15, which is not what I want. Any pointers? Is this fixed in 2.16?
Why: My ultimate goal is to get a VC-1/AC3/TS (or M2TS) stream out of an HD DVD. There seems to be a lot better support for this with the commercial players and hardware units. If I can get the raw streams, I think I can mux it to TS with ffmpeg. I'll write a muxer if I have to. Thanks for your help and your awesome tool. |
21st January 2008, 18:36 | #2789 | Link | ||
I also demuxed the audio with evodemux and run it through delaycut. The frames (e-ac3) 33 to 41 are corrupted. Maybe the first seconds of the evo (original) is damaged/corrupted and they screw the whole file. |
21st January 2008, 19:05 | #2790 | Link |
how does the eac3to "speedup/slodown" feature work?does it stretch the intermediate wavs mono files(temporary encoded) or does it change the sample rate and re-sample to 44/48khz?is the result better than stretching the wavs mono files with an audio editor(like audition)?
21st January 2008, 19:12 | #2791 | Link | |
C:\Tools>eac3to file.evo -demux EVO, 1 video track, 1:16:47 1: VC-1, 1080p24 /1.001 Extracting primary video track... The VC-1 pulldown remover didn't receive the format information. Code:
C:\Tools>eac3to file.evo 1: file.vc1 EVO, 1 video track, 1:16:47 1: VC-1, 1080p24 /1.001 Extracting primary video track... The VC-1 pulldown remover didn't receive the format information. |
21st January 2008, 19:15 | #2792 | Link | |
21st January 2008, 19:15 | #2793 | Link | |
21st January 2008, 19:16 | #2794 | Link | |
A well working TS muxer would be quite lovely... |
21st January 2008, 19:20 | #2795 | Link | |
You're right, sorry.
Have you tried remuxing only the 2nd EVO to MKV? What happens then? |
21st January 2008, 19:21 | #2796 | Link | |
21st January 2008, 19:39 | #2797 | Link | |
(god, video/audio editing is trouble. But we wouldn't be here if we didn't like it. ) EDIT: 2nd evo (original & rebuilt with evodemux) results in 100% playable/seekable mkv with both haali and vmr9 renderers. Last edited by nautilus7; 21st January 2008 at 20:19. |
21st January 2008, 19:52 | #2798 | Link |
madshi, i cleaned the million dollar baby audio track and tried to process it with eac3to. The libav decoder crashed and probably this caused eac3to to crash too. I believe that shouldn't happen. Bug report
21st January 2008, 20:00 | #2799 | Link | |
21st January 2008, 20:14 | #2800 | Link | |
eac3to |
