12th August 2015, 12:35 | #1641 | Link | |
Professional Code Monkey
12th August 2015, 16:00 | #1642 | Link | |
And thanks jackoneill and HolyWu for your help. Well I have learn a valuable lesson that I should install updates of OS in time. |
12th August 2015, 21:13 | #1643 | Link | |
The cult of personality
Traceback (most recent call last): File "<pyshell#0>", line 1, in <module> import vapoursynth as vs ImportError: DLL load failed: The specified procedure could not be found. I am using windows 7 32 bit (the one I tried this on) and have a dedicated server running windows 7 64 bit (didn't try it on it yet). |
20th August 2015, 19:07 | #1644 | Link | |
unsigned int
This is a 32 bit Windows 7, yes? Which version of VapourSynth did you install? Does the same thing happen with r27 and this r28-test1? What about r26? Did you change anything at all in the installer, like the destination path? Can you verify that vspipe.exe, vsscript.dll, vapoursynth.dll (both copies), vapoursynth.pyd, and your Python installation are all 32 bit? Perhaps the Properties window tells you this. If not, Dependency Walker tells you, in the "CPU" column. Where is each of these located? While you're there, Dependency Walker can tell you if your copy of vsscript.dll has the function that the error message is complaining about. Does this KB2533623 magically fix everything, if it's not installed already?
Buy me a "coffee" and/or hire me to write code! Last edited by jackoneill; 20th August 2015 at 19:11. |
20th August 2015, 19:37 | #1645 | Link | |
this script worked well: Code:
import sys import vapoursynth as vs core = vs.get_core() #core.std.LoadPlugin(r'D:\plugins32\ffms2.dll') a = core.ffms2.Source(r'C:/video.mkv') a = core.f3kdb.F3kdb(a, y=49, output_depth=10, dither_algo=2) a.set_output() About your questions, here are my answers: 1- I run Windows 7 32-bit. (My dedicated server Windows 7 60-bit, but didn't try r28 on it yet. Probably it will work) 2- Now it is r28. previously official r27. Didn't try anything else. 3- As I said above, loading native plugins now works well. The other problem of Wobbly didn't change. didn't try 26. 4- Did not change anything. 5- Hmm... vsscript.dll is located in system32. In properties window of vspipe.exe, it shows the options of Windows XP which indicates it is 32-bit (unless this info is wrong). Python is 32-bit. Could not check the .dll files, but as I said above, it ran a script very well... So they must be 32-bit. |
21st August 2015, 22:18 | #1648 | Link |
I've tested the exact same VS-R28 on Windows 7 x64-bit (server), but it turns out it has the same problem.
it gives back: Code:
Failed to evaluate the script: Python exception: No attribute with the name ffms2 exists. Did you mistype a plugin namespace? Traceback (most recent call last): File "vapoursynth.pyx", line 1467, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:24719) File "PATH\Untitled.vpy", line 4, in <module> v = core.ffms2.Source(PATH/[SS] Dragon Ball 1-28 (Son Gokū Arc)(DVD.AAC)/[SS] DB - 01 (DVD.AAC)[68AED4FF].mkv') File "vapoursynth.pyx", line 1088, in vapoursynth.Core.__getattr__ (src\cython\vapoursynth.c:18921) AttributeError: No attribute with the name ffms2 exists. Did you mistype a plugin namespace? Code:
import sys import vapoursynth as vs core = vs.get_core() v = core.ffms2.Source(PATH/[SS] Dragon Ball 1-28 (Son Gokū Arc)(DVD.AAC)/[SS] DB - 01 (DVD.AAC)[68AED4FF].mkv') v.set_output() |
21st August 2015, 22:36 | #1649 | Link |
unsigned int
Install https://support.microsoft.com/en-us/kb/2533623 and try again.
Buy me a "coffee" and/or hire me to write code! |
22nd August 2015, 02:48 | #1650 | Link | |
22nd August 2015, 03:50 | #1651 | Link |
I'd like to run some speed comarisions with AVS, can you tell me the best method (fair)? I am using x264 right now but for avs it is just ffvideosource and feed the script directly into x264. However, for VS there is the vspipe stuff which is an extra... So the comparision is not fair I think.
22nd August 2015, 12:34 | #1652 | Link |
I have used x264-32bit-8bit-tmod to do some comparison...
Settings: 10-bit SD source (24 min) x264 with no options [Defaults] script: ffms2 source + f3kdb Result: vs : fps=81.42 - duration=0:06:06 avs: fps=78.19 - duration=0:06:21 x264 tried vsimport but failed, it tried avisource and succeeded. I wonder why? Is there any faults in this method of comparison? I ask because I got different file size in both methods. Last edited by ~ VEGETA ~; 22nd August 2015 at 12:40. |
22nd August 2015, 23:15 | #1653 | Link | ||
Error FontConfig
Hi, in Vapoursynth R27-R28 when I want to use subtitles, mark this error
import vapoursynth as vs core = vs.get_core( ) outClip = core.std.BlankClip( width=1280, height=720, format=vs.YUV420P8, length=10, fpsnum=24000, fpsden=1001, color=[255, 127, 127] ) subs = core.assvapour.AssRender( outClip, file="video.ass" ) subs[0] = core.resize.Bicubic( subs[0], format=vs.YUV420P8 ) outClip = core.std.MaskedMerge(outClip, subs[0], subs[1]) outClip.set_output( ) Code:
[Script Info] ; Script generated by Aegisub 3.2.0 ; http://www.aegisub.org/ Title: Default Aegisub file ScriptType: v4.00+ WrapStyle: 0 ScaledBorderAndShadow: yes YCbCr Matrix: None PlayResX: 1280 PlayResY: 720 [Aegisub Project Garbage] Last Style Storage: Default Video File: ?dummy:23.976000:40000:1280:720:215:215:215:c Video AR Value: 1.777778 Video Zoom Percent: 0.531944 Active Line: 2 [V4+ Styles] Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding Style: Default,Arial,50,&H00FFFFFF,&H000000FF,&H00000000,&H00000000,0,0,0,0,100,100,0,0,1,4,0,5,10,10,10,1 [Events] Format: Layer, Start, End, Style, Name, MarginL, MarginR, MarginV, Effect, Text Dialogue: 0,0:00:00.00,0:00:00.39,Default,,0,0,0,,{\move(235,70,135,640,0,375)}move1 Dialogue: 0,0:00:00.00,0:00:00.39,Default,,0,0,0,,{\t(\fscx75\fscy75\bord3)\move(630,70,530,640,0,375)}move2 Dialogue: 0,0:00:00.00,0:00:00.39,Default,,0,0,0,,{\org(235,70)\pos(1125,70)\t(\frz-40\fscx125\fscy125\bord5)}move3 Quote:
29th August 2015, 18:35 | #1655 | Link |
Hello Myrsloik,
Windows-1252 covered characters ä, ü and ö in source filenames cause an exception. https://en.wikipedia.org/wiki/Windows-1252 Code:
Python exception: 'utf-8' codec can't decode byte 0xe4 in position 192: invalid continuation byte Traceback (most recent call last): File "vapoursynth.pyx", line 1466, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:24692) UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe4 in position 192: invalid continuation byte clip = core.ffms2.Source(source = r'D:\Temp\Encoding\häh.mp4', cachefile = r'D:\Temp\Encoding\häh temp files\häh.ffindex')
29th August 2015, 20:22 | #1657 | Link |
produces a different error:
Python exception: invalid character in identifier (häh_Source.vpy, line 1) Traceback (most recent call last): File "vapoursynth.pyx", line 1466, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:24705) File "D:\Temp\Encoding\häh temp files\häh_Source.vpy", line 1 import vapoursynth as vs ^ SyntaxError: invalid character in identifier clip = core.ffms2.Source(source = r'D:\Temp\Encoding\häh.mp4', cachefile = r'D:\Temp\Encoding\häh temp files\häh.ffindex')
29th August 2015, 22:20 | #1659 | Link |
Angel of Night
That's odd, python can read source files with a BOM just fine, so the same script will work on the command-line. VS should probably trap this exception in vpy_evaluateScript and retry with script.decode('utf-8-sig'). (And perhaps the user's default locale, but discouraging the use of code pages as much as possible in every form is probably wise.)
29th August 2015, 22:28 | #1660 | Link | |
speed, vaporware, vapoursynth |
