Old 27th June 2008, 13:51   #1961  |  Link
arrirc
Aminei
arrirc's Avatar
Originally Posted by stax View Post
It's crashing trying to minimize a external application, what external application runs when this happens? I've uploaded a beta trying to fix it but since it's not clear what's causing it I can't promise much.
Thank you very much Stax.
I believe the application was Firefox 'cause thats the only program that was running while I was using StaxRip.
Now may I request your attention to a doubt that I have? I have recently converted a Video which was ripped on my HDD, to MP4-X.264 combination. First I tried the profile under Constant Quality> ASP Q2 eq (crf) and next time I have used High Quality> Slow CRF 22.
For the same movie, which is BW, the first profile yielded a file of 1.8GB in size (approx) and the second profile resulted a much smaller file size (about 900 MB). While using these profiles, in both cases, the "compressibility check" option did not appear.
Is this size difference Normal?
arrirc is offline
Old 27th June 2008, 15:19   #1962  |  Link
stax76
stax76's Avatar
In the x264 dialog, press the F1 key and work through the guides, what you are most interested is CRF Mode. CRF 22 gives you a good balance between filesize and quality, CRF 18 gives extreme quality/filesize.
stax76 is offline
Old 27th June 2008, 15:39   #1963  |  Link
arrirc
Aminei
arrirc's Avatar
Thank you Stax, I shall let you know in a day or two.
So the 900MB file is good enough as a archive/backup, and so is the "High Quality> Slow CRF 22" profile- right?
arrirc is offline
Old 27th June 2008, 16:47   #1964  |  Link
stax76
stax76's Avatar
It's well balanced assuming you don't use a resize filter.
stax76 is offline
Old 27th June 2008, 18:52   #1965  |  Link
arrirc
Aminei
arrirc's Avatar
I did not have to resize in the first case, but I did resize in the second case, I am not in front my own PC, so I can't recall the exact WxH, but most probably the W=702! What's wrong with the resize? If I encode taking 720x480 or 720x576, will the file sizes be considerably larger?
Now a little off topic: I must admit that I am greatly impressed with your software and you mostly. Your promptness in responding to even flimsy/ silly issues that we newbies bring forward is commendable. Please accept my heartfelt gratitude. Thank You!
Now playing: Cliff Richard - True Love Ways
via FoxyTunes
arrirc is offline
Old 28th June 2008, 11:12   #1966  |  Link
stax76
stax76's Avatar
@arric
You can use the same CRF value for any image size, for small image sizes I would probably lower the CRF value in order to improve the quality. I appreciate your gratitude!
@all
If you want to help testing the beta, this is the current status:
* Some new MKV features added
* Tooltip added to tray icon showing console output
* Preparers can define which formats to be used and which not
* Various aspect ratio fixes and improvements
* VirtualDub updated to 1.8.1
* DGAVCDec updated to 1.0.0a24
* Many fixes and Improvements regarding various source formats
* Pass through encoder improved to handle not only previously encoded project but also source files
* Since the pass through encoder was improved StaxRip can now be used to (batch) remux source files.
* MediaInfo updated to version 0.7.7.2, it fixes reading aspect ratio from anamorphic avi source files
* Some fixes and improvements picking up audio files
* Added MP4 demuxing, improved MKV demuxing
* Added support for more then one IDX (vobsub) file
* Added support to reorder IDX (vobsub) subtitles
* DGAVCDec was updated to version 1.00a23
* Various setup fixes and improvements
* Many useful directories added to the main menu
* A couple of improved tooltips
* Fixed two bugs with adding jobs from a second StaxRip instance
* New command to play a sound file
stax76 is offline
Old 28th June 2008, 17:35   #1967  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
Hey Stax whats with the 3.5GB VB Script in the out folder...
My Installer's ||
Ajax_Undone is offline
Old 28th June 2008, 17:57   #1968  |  Link
stax76
stax76's Avatar
I've absolute no idea what happened, maybe I can see something if you upload the diagnostic file (Help / Make Bug Report) using 2shared.com or mediafire.com. StaxRip shouldn't create any files with the extension VB, this extension is used for Visual Basic source code files which are typically only few KB. It has almost the same size as the VOB file, really strange issue.
stax76 is offline
Old 28th June 2008, 22:51   #1969  |  Link
Ajax_Undone
Thats what I figured
I will upload later tonight am to busy right now...
*Edit* LOL Ok it was my fault I put the other VOB file into the same directory as 1.vob opon moving it I must have accidentally Deleted the O from VOB...
So 2.vb is really 2.vob...
Any how thanx for caring... But I figured it out while trying to find the 2nd vob...
My Installer's ||
Old 29th June 2008, 13:57   #1970  |  Link
weaver4
I am getting an error dialog saying "mp4 muxing failed". But I look the movie and it looks complete. Here is the log file:
Muxing
"C:\Documents and Settings\Trey Weaver\Local Settings\Application Data\StaxRip\Applications\MP4Box\MP4Box.exe" -fps 23.976 -add "D:\aa-Rips\MainMovie\mymovie\VIDEO_TS\mymovie.zsxq24-ipt_EncoderOutput.264:name=Video" -add "D:\aa-Rips\MainMovie\mymovie\VIDEO_TS\VTS_01_1 01 en-English 3_2ch 384Kbps DELAY -43ms_AudioOutput_AudioOutput.mp4:lang=eng:name=English" -add "D:\aa-Rips\MainMovie\mymovie\VIDEO_TS\VTS_01_1.idx#1" -new "J:\Movies\Movies-iPod\mymovie.zsxq24-ipt.mp4"
AVC-H264 import - frame size 320 x 128 at 23.976 FPS
Import results: 144464 samples - Slices: 1400 I 64324 P 78740 B - 1 SEI - 1293 IDR
Stream uses B-slice references - max frame delay 2
IsoMedia import - track ID 1 - Audio (SR 48000 - 2 channels)
VobSub import - subpicture stream 'eng'
Saving J:\Movies\Movies-iPod\mymovie.zsxq24-ipt.mp4: 0.500 secs Interleaving
Muxing Statistics
Start: 3:09:20 AM
End: 3:10:48 AM
Duration: 00:01:28
Speed: 1642 fps
Error
mp4 muxing failed
weaver4 is offline
Old 29th June 2008, 14:46   #1971  |  Link
stax76
stax76's Avatar
@Ajax_Undone
VOB files should better have the original filename like it's stored on the DVD (VTS_0?_?.VOB), applications can then check if there is corresponding IFO file and enable extra features with information taken from the IFO file.
@weaver4
What looks most suspiciously here is '*_AudioOutput_AudioOutput.mp4', with a common workflow StaxRip should not create such a filename. Did you do anything special?
stax76 is offline
Old 29th June 2008, 19:00   #1972  |  Link
weaver4
@weaver4
The only special thing I did was use a Template that I made.
But I looked and there was already a filed called: VTS_01_1 01 en-English 3_2ch 384Kbps DELAY -43ms_AudioOutput.mp4 in the directory that was made a few months ago.
The files do play properly.
weaver4 is offline
Old 30th June 2008, 12:17   #1973  |  Link
Danisan
Danisan's Avatar
StaxRip + ColorMatrix = crash
Hi!
I edited the filter profiles and added a new line under "[Misc]"
ColorMatrix = ColorMatrix(hints=true)
When I add ColorMatrix and use it under filters it always crashes when i proceed to the next step. It doesn't matter if I add it before loading a source or after. What am I doing wrong?
Danisan is offline
Old 30th June 2008, 14:56   #1974  |  Link
stax76
stax76's Avatar
@weaver4
Did it happen only once or does it happen all the time?
@Danisan
Please try a new beta and post the error message if there is any.
stax76 is offline
Old 30th June 2008, 17:57   #1975  |  Link
Danisan
Danisan's Avatar
@Danisan
Tried the new beta, doesn't crash anymore.
Danisan is offline
Old 3rd July 2008, 21:39   #1976  |  Link
Ajax_Undone
@Ajax_Undone
Its all good 1.vob and 2.vob are to different Videos I was not going to merge them... Any how Happy day
My Installer's ||
Old 7th July 2008, 17:44   #1977  |  Link
RickA
Greets Stax,
Great program you have here! I am sorry that I overlooked it some months ago. Thanks for your work on this. :-)
Cheers,
Rick
Rene: Could you not just wound him a little bit?
Hans: Well now, with a 25 pound shell that is not easy.
'Allo 'Allo
RickA is offline
Old 7th July 2008, 18:12   #1978  |  Link
weaver4
@weaver4
It happens all the time. Every single mp4 encode.
weaver4 is offline
Old 7th July 2008, 18:25   #1979  |  Link
stax76
stax76's Avatar
@RickA
Thanks for the words of appreciation.
Please upload diagnostic files generated by the latest beta, I should be able to find the problem then.
stax76 is offline
Old 9th July 2008, 02:15   #1980  |  Link
weaver4
Here is the diagnostic files.
http://www.mediafire.com/?xjwnjtcpmlx
BTW: I am muxing to a remotely mapped drive if that makes any difference.
weaver4 is offline
gui, h.264, h.265, hevc, mkv, x264, x265
