Old 15th August 2019, 20:08   #3501  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
R47.2 released. You should definitely update if you use a previous R47 version since it fixes the merge bug introduced when converting everything to intrinsics.
Myrsloik is offline   Reply With Quote
Old 22nd August 2019, 22:13   #3502  |  Link
chipxtreme
When I go to update I get Python 3.7 (64 bit) is installed for the current user only. Run the installer again and select "Install for me only" or install Python for all users.
I only have one user on my PC and when I installed Python I selected install for all users. What am I doing wrong?
chipxtreme is offline   Reply With Quote
Old 23rd August 2019, 19:10   #3503  |  Link
Myrsloik
Myrsloik's Avatar
Update from which version? Does it actually work if you select to install for the current user only?
Do you have any registry entries in HKEY_LOCAL_MACHINE\SOFTWARE\Python\PythonCore\3.7?
Old 23rd August 2019, 20:51   #3504  |  Link
chipxtreme
I uninstalled previous version and have since deleted it so not sure which version I had previously. I don't have any registry entries there?
Old 23rd August 2019, 21:04   #3505  |  Link
Myrsloik
Myrsloik's Avatar
Then you've most likely installed python only for the current user...
Old 24th August 2019, 03:12   #3506  |  Link
cyaoeu
Originally Posted by Boulder View Post
The only easy way to make it work was to use the folder which VSRepo uses (%appdata%\Roaming\Python\Python37\site-packages). I've had Python installed in that mentioned directory under Program Files for a long time now but I don't know why it stopped working now.
Thanks! A bit strange that it's %appdata%\Roaming\Python\Python37\site-packages and not %appdata%\Roaming\Python\Python37\site-packages\vapoursynth ...
cyaoeu is offline   Reply With Quote
Old 24th August 2019, 09:51   #3507  |  Link
chipxtreme
Install for all users is selected by default and I didn't unselect it.
Old 25th August 2019, 10:30   #3508  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by Stephen R. Savage View Post
Optimized VSynth build for Expr: https://www.sendspace.com/file/xleugj
Benefits of Exprt build:
  • Higher framerate in Exprt-intensive scripts
  • Higher framerate in MaskTools-intensive scripts
  • Lower electricity bill
  • Lower CPU temperature
As a reminder: you need to replace vapoursynth.dll both in the installation path AND in the python module directory (where vapoursynth*.pyd is located)
Typically:
C:\Program Files\VapourSynth\core
AND
C:\Program Files\Python37\Lib\site-packages
Go test this so it can be included in the next official release. And test the MVToolz optimizations too.
Old 26th August 2019, 21:27   #3509  |  Link
lansing
Did the image reader plugin got removed in the newer version? I couldn't call it in vs editor.
Old 26th August 2019, 21:34   #3510  |  Link
Myrsloik
Myrsloik's Avatar
It's not included in the installer so maybe you don't have it...
Old 26th August 2019, 21:54   #3511  |  Link
lansing
What package is it in now? The vs documentation still listed it as included plugin from the installer.
Old 27th August 2019, 10:19   #3512  |  Link
ChaosKing
Optimised VSynth build for Expr: https://www.sendspace.com/file/xleugj
Here are some numbers:
Tested like this
PS D:\> vspipe.exe -p -e 5000 D:\del.vpy .
on a Ryzen 2600, 16GB ram, DVD 720x480 clip
Vinverse seems to consist only of Expr+MakeDiff and therefore has the biggest speedup of ~22%
https://github.com/HomeOfVapourSynth...sfunc.py#L2375
import havsfunc as haf
clip=haf.DeHalo_alpha(clip)
clip=haf.FineDehalo(clip)
# new build
Output 5001 frames in 16.87 seconds (296.39 fps)
Output 5001 frames in 16.73 seconds (298.98 fps)
Output 5001 frames in 16.84 seconds (296.98 fps)
# old build
Output 5001 frames in 17.04 seconds (293.43 fps)
Output 5001 frames in 17.07 seconds (292.99 fps)
Output 5001 frames in 17.04 seconds (293.51 fps)
clip=haf.srestore(clip)
# new build
Output 5001 frames in 35.41 seconds (141.24 fps)
Output 5001 frames in 35.12 seconds (142.42 fps)
Output 5001 frames in 35.74 seconds (139.94 fps)
# old build
Output 5001 frames in 35.20 seconds (142.07 fps)
Output 5001 frames in 35.24 seconds (141.91 fps)
Output 5001 frames in 35.09 seconds (142.53 fps)
clip=haf.SmoothLevels(clip)
# new build
Output 5001 frames in 10.41 seconds (480.28 fps)
Output 5001 frames in 10.34 seconds (483.86 fps)
Output 5001 frames in 10.33 seconds (484.30 fps)
# old build
Output 5001 frames in 10.66 seconds (469.29 fps)
Output 5001 frames in 10.64 seconds (469.96 fps)
Output 5001 frames in 10.66 seconds (468.97 fps)
clip=haf.Vinverse2(clip)
# new build
Output 5001 frames in 5.12 seconds (977.57 fps)
Output 5001 frames in 5.17 seconds (967.26 fps)
Output 5001 frames in 5.13 seconds (974.39 fps)
# old build
Output 5001 frames in 5.85 seconds (855.08 fps)
Output 5001 frames in 5.86 seconds (853.31 fps)
Output 5001 frames in 5.86 seconds (853.19 fps)
Old 27th August 2019, 17:13   #3513  |  Link
lansing
I have notice a new problem with Python 3.7.4 installer that's affecting vs installer. When I'm doing a clean install, if I choose "install now" in python installer, the default installation path would be something like "users\username\appdata\roaming\...", and the default installation path for the vs installer would be "users\username\appdata\local\programs\vapoursynth". But if I choose "custom installation" in python installer, its installation path would be changed to "c:\program files\python37", and the vs installer would also be changed to "c:\program files\vapoursynth".
Old 31st August 2019, 06:23   #3514  |  Link
Selur
Selur's Avatar
Is there an alternative to AutoAdjust for Vapoursynth?
Old 31st August 2019, 17:52   #3515  |  Link
Myrsloik
Myrsloik's Avatar
Not that I know of. Avisynth compatiblity should work though.
Old 31st August 2019, 18:21   #3516  |  Link
Selur
Selur's Avatar
Only on Windows, or should this also work on Linux and I simply don't know how to get it working?
Old 6th September 2019, 19:59   #3517  |  Link
feisty2
I'm Siri
feisty2's Avatar
why is vsscript.dll required to be placed in the same folder with vspipe.exe for the new release?
feisty2 is offline   Reply With Quote
Old 6th September 2019, 20:17   #3518  |  Link
Myrsloik
Myrsloik's Avatar
I stopped putting a copy of vsscript.dll in the system directory in R46. Putting things into the system directory is bad.
Changing the vsscript api to match the style of the rest of vs so importing it becomes trivial is on my todo list and will fix it. Some day.
Old 10th September 2019, 15:56   #3519  |  Link
Jukus
Is there a detailed user guide? Of course, I am happy to use QTGMC and other plugins, but there is very little knowledge and information.
Jukus is offline   Reply With Quote
Old 10th September 2019, 18:53   #3520  |  Link
jackoneill
unsigned int
jackoneill's Avatar
There is some documentation: http://www.vapoursynth.com/doc/
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
speed, vaporware, vapoursynth
