11th July 2009, 21:19 | #3881 | Link |
I don't know if this helps or not, but I tried running death race thru again after last error report (- Error in attempt to multiplex: MUX_00293.meta
- This is not an EBML file (id=0/440786851 [21:01:40] - Failed to build structure, aborted.) This time it made it to clip 62 and I got the GUI error. As the GUI error happened right before it started encoding clip 62, I restarted BDRB and did the rest of the movie, no problem. I burned it to BD-RE and it played - but no sound cuz I had set BDRB to keep the HD audio for BD25, which I guess my receiver can't decode. So I tried another run thru BDRB, the whole movie went thru with no problem (changing the one setting re: HD audio). Reason I am letting you know is 1st run got an error, second run got an error, third run (without HD audio) ran thru without a hitch. Saphire199 |
11th July 2009, 21:27 | #3882 | Link | |
11th July 2009, 22:40 | #3883 | Link |
Just did G Torino with fast encode to BD25 and it only took 2hr and 20min! It looks good so far. I am now doing a long encode to make a comparison, but from 14 hours to 2.33 hours? WOAH!
Still can't get Step Brothers backed up. What a pain that one is. |
12th July 2009, 01:54 | #3885 | Link |
@jdobbs and/or anyone who has successfully backed up Die Hard 2 Die Harder to BD-25, keeping DTS HD Master Audio.
I have completed backing up the Die Hard movies to BD-25, full movie, keep HD audio. Disc 1, (Die Hard), disc 3 ( With A Vengeance) and disc 4 ( Live Free or Die Hard), have turned out absolutely perfect, all with DTS HD Master audio kept, and look and sound great. Disc 2, Die Hard 2 Die Harder has been interesting, to say the least. I have now tried with BD-RBV02302, BD-RBV02402, and BD-RBV02501, and all experience the same results. The full movie backup, keeping the DTS HD Master Audio, plays only with silence on my Sony BDP-BX1, no audio heard. Also, my receiver only says stereo when the movie plays and there is only silence. When I play the other three movies, the receiver says DTS HD Master, and audio is heard. So I try a movie only backup to BD-25, and also keep the HD audio, and now it plays normal, audio is heard, and the receiver says DTS HD Master. Why BD-RB will work in movie only mode but not in full backup for this movie is a mystery. I have backed up about 25 blu-rays to full movie, BD-25, keeping HD Audio, and never experienced this before. (The audio plays and is heard on the computer with PowerDVD 7.3 and MPC for the full movie back up, just not on the stand alone.) Though I can't say for sure this is a bug with BD-RB, the conclusion that a movie only works when a full backup will not does leave a question. |
12th July 2009, 02:58 | #3886 | Link |
Man, trying to predict the size of a CRF encode is tough. I've been trying everything to get an accurate prediction. I gather the quants, I weigh them based on value, I adjust everything based upon complexity information in the stats file...
I just can't seem to get an accurate prediction. It's usually in the neighborhood, but still has occasional "WTF?" results. |
12th July 2009, 03:29 | #3887 | Link | |
12th July 2009, 04:52 | #3888 | Link |
Furious, you posted this in a thread
"the small m2ts it's because it's only 1 frame long and avisynth won't accept it. You can get around that error by setting the minimum m2ts size to encode at 150mb" Just wanted to know where you are adjusting this, where do you adjust the minimum m2ts size? And I apologize this is not a bug, but was in this thread to begin with. saphire199 |
12th July 2009, 05:34 | #3889 | Link |
@jdobbs
Although you've indicated nothing to the contrary regarding my two previous posts, I just thought I'd ask to make certain: We ARE supposed to be able to use the "One-pass (Experimental") option for "movie-only", aren't we? |
12th July 2009, 05:37 | #3890 | Link | |
I went into SETUP and checked that ENGLISH was the only language selkected, and made sure it was the only sub-title there too. When I look in the STREAM window, it shows 12 sections, titled VID_xxxxxxx and inside each one is an audio section titled AUD_001, AC3, Stereo, English There is also a subtitle folder under each. So, I cannot see any HD audio formats in there to un-select. |
12th July 2009, 07:22 | #3891 | Link |
Confirmed. I have been experimenting myself. Indeed the sensisitivity ("gain") of 'delta file size' vs 'delta crf' can change a lot from source to source. I remember an example where a change in crf from 21.6 to 21.5 stepped up the file size unexpectedly, while for another source a change from 22 to 21 made the file size to increase by few % only.
That's why I think if any prediction method produces something like 80%+ of the target size in reasonable time, we should be happy. |
12th July 2009, 07:45 | #3892 | Link | |
12th July 2009, 07:51 | #3893 | Link |
I haven't been able to use 0.25.01 because Avira is going absolutely ballistic detecting the TR/Crypt.XPACK.Gen trojan, and although it is probably a false positive and poses low risk, it still contiuously comes up with the warning over and over again.... I can't set Avira to ignore it.
Any ideas JD? what could Avira be detecting as suspicious script over and over again?
MBK |
12th July 2009, 10:36 | #3895 | Link | |
In the change log it is mentioned... "Added a "HIGH-SPEED" option to the "SETTINGS/ENCODER SETTINGS" menu. It is visible/recommended for BD-25 encoding only. The quality on BD-5/9 will suffer greatly if this option is used (via hidden setting). When used with one-pass CRF mode on BD-25 it can result in a very fast yet excellent quality backup of most discs." Thus, if I understand well: it can be used with or without single pass encoding. Am I right? |
12th July 2009, 10:41 | #3896 | Link | |
Webmaster
I still use the normal 2 pass at high quality |
12th July 2009, 11:12 | #3897 | Link |
On BD9 the Extras are encoded with crf in the range of 25 ... 30. While the picture quality is still quite ok for the Extras in my opinion, I noticed sometimes an annoying GOP pumping. It looks as if this pumping can be reduced by reducing ipratio and pbratio, like --ipratio 1.1 --pbratio 1.2.
It's not a bug, but perhaps something to be considered for future BD-RB release. Maybe more tests are needed? |
12th July 2009, 12:59 | #3900 | Link | |
