2nd December 2009, 10:33 | #9601 | Link |
I think I found bug.
eac3to 00001.m2ts 1: chapters.txt 3: audio1.m4a -no2ndpass 6: audio2.m4a -quality=0.6 -no2ndpass 9: english.sup As result 1st m4a file is ok and 2nd is unreadable, although is not empty. No problem occurs if only one track is recoded at a time.
8th December 2009, 03:04 | #9603 | Link |
To convert wma audio, in wmv container, to ac3 you can try several methods:
- Foobar and Aften - dshow2wav and pipe the output to Aften. - AviSynth methods (Soundout, BeHappy, bepipe, wavi) with DirectshowSource decoder. For more detailed explanation please open a new thread.
9th December 2009, 01:22 | #9605 | Link | |
Unavailable
b66pak wrote:
1) copy the Windows Media Audio stream to a standalone ASF file (*.wma) with AsfBin ; 2a) convert to a .WAV file via Avisynth + BassAudioSource() ; 2b) OR... playback the intermediate WMA file with Winamp's Disk Writer plugin. So far, it's worked fine for stereo Windows Media Audio, I still haven't found problematic multichannel WMAs on which I should test this workaround. Last edited by Midzuki; 9th December 2009 at 01:24. |
13th December 2009, 02:05 | #9611 | Link |
Given we are seeing advances in Filters supporting HD codec playback (eg FFDSHOW can now decode most and is working at bitstreaming)....is it worth transcoding the Audio or just Remux the Original Audio when using MKV containers?
13th December 2009, 10:19 | #9613 | Link |
Derek Prestegard IRL
IMO, most stuff can safely be transcoded to AAC with perfect transparency. I do this most of the time.
If AC3 is the best quality audio source on a given movie, then I just keep it. Why reinvent the wheel? If a movie has an incredibly good audio track, or is a musical performance, then I either keep it as-is (if it's TrueHD), or just transcode to FLAC. Of course, I don't have a fancy receiver, or even a 5.1ch system, so I don't mind terribly Headphones suit me just fine! ~MiSfit
These are all my personal statements, not those of my employer :) |
14th December 2009, 08:06 | #9614 | Link |
eac3to 3.17 bug - hangs in a loop forever
There is a situation, which I've hit a few times, that causes eac3to to hang in a loop of some sort, forever.
It hits a bad section of the video, and if it is bad enough, it will not get through it, nor will it error out. This is what is on the screen when it happens: Code:
a03 0:43:17 The source file seems to be damaged (transport error indicated). v01 0:43:17 The source file seems to be damaged (transport error indicated). a05 0:43:17 The source file seems to be damaged (transport error indicated). a04 0:43:17 The source file seems to be damaged (transport error indicated). a03 0:43:17 The source file seems to be damaged (discontinuity). v01 0:43:17 The source file seems to be damaged (discontinuity). a05 0:43:17 The source file seems to be damaged (discontinuity). a04 0:43:17 The source file seems to be damaged (discontinuity). a03 0:43:17 The source file seems to be damaged (discontinuity). v01 0:43:17 The source file seems to be damaged (discontinuity). a05 0:43:17 The source file seems to be damaged (discontinuity). a04 0:43:17 The source file seems to be damaged (discontinuity). v01 0:43:17 The source file seems to be damaged (discontinuity). a05 This track is not clean. a03 This track is not clean. a04 This track is not clean. An update: I was able to take what was completed and finish the job. I then looked at the output and the real nasty damage is at 58:00 minutes. There was no error output placed onto the screen, eac3to just went into a loop and hung at that point in the file. Last edited by MrVideo; 14th December 2009 at 08:33. Reason: UPDATE |
16th December 2009, 17:36 | #9615 | Link |
I have a little issue whereby the encode i have done is just a little bit (i would say 100meg or so) big to fit on a dvd9 disc, i know i could use 2 dvd5s but was thinking it would be easier to just drop the rate of the ac3, i have the ac3 on the drive (used tsmuxer to remove true-hd part) so its sitting as a 640kbps ac3 file.
To use eac3to i would just do eac3to gran.torino.640.ac3 gran.torino.448.ac3 -448 is that correct? or would people suggest i copy the true-hd file from the bluray disc and use ac3 to do the lot manually skipping tsmuxer down converting to ac3?
The Internet: where men are men, women are men, and children are FBI Agents |
16th December 2009, 18:35 | #9617 | Link |
Thought as much, so its just the line above i need? or do i need to add the frame rate as well?
Does this program still require external decoders to do its thing or is it all done by eac3to?
The Internet: where men are men, women are men, and children are FBI Agents Last edited by Carpo; 16th December 2009 at 21:04. |
16th December 2009, 22:19 | #9618 | Link |
The line above would work. For TrueHD, replace the source file name with the TrueHD track. You don't have to worry about any kind of 'rates' unless you're changing the video.
eac3to can decode TrueHD and it can encode AC3 without any additional extras. Last edited by Snowknight26; 16th December 2009 at 22:58. |
16th December 2009, 22:36 | #9619 | Link |
thanks - i have to change the rate on the ac3 otherwise i cant get the backup i made to fit on a dvd9 - its slightly oversized, if i drop the rate from 640 to 448 it should fit nicely
eac3to |
