25th August 2018, 19:52 | #15981 | Link |
v1.23.0 (FINAL)
Added: Better queue management Added: support for commandline switches in EncodingServer.exe (/minimize , /port , /node , /affinity , /priority , /x264-opencl-device and /knlmeanscl-opencl-device) Example: EncodingServer.exe /minimize /port 2000 /node 2 /affinity AAAA /priority low /x264-opencl-device 0 /knlmeanscl-opencl-device 1 EncodingServer will start in tray and start listening using port 2000. Encoding task will be assigned to NUMA node 2 with affinity mask for CPU1,CPU3,CPU5,CPU7,CPU9,CPU11,CPU13,CPU15 in low priority. Futhermore x264 opencl will be set for first device and KNLMeansCL filter for second device. Added: Support fot 3rd audio stream Added: Preffered audio language option Added: HDR to SDR conversion directly in script (no bottleneck if used with prefetch) Added: Automatic pre-indexing of all audio streams after demuxing Added: support for PRORES as input format. Changed: WatchFolder Mode now adds first unlocked file to queue instead of waiting for first detected file in folder to be unlocked Fixed: Crashing in EncodingServer when other instance was being closed. EncodigServer also starts much faster than before. Fixed: Various bugs reported since last major version Optimal configuration for Ryzen Threadripper 2990WX (4 NUMA nodes)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 25th August 2018 at 19:54. |
26th August 2018, 04:52 | #15982 | Link | |
I downloaded the new full install, from Mediafire. Certainly a lot of the "tool's" have been updated This program is getting away from being simple... You're going to have to post a user instruction guide.. OK, so that NUMA stuff means nothing to me, is it possible to use this with older CPU's ?? eg:- X series XEON's, or i7's. Well done, can't wait to give it a whirl. |
26th August 2018, 15:25 | #15984 | Link |
Yes but in weird way. Set /x264-opencl-device to some incorrect value (non existing device index).
x264 should automatically switch to full software mode.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 26th August 2018 at 15:30. |
26th August 2018, 17:17 | #15985 | Link |
So I discovered recently that if I encode my movies in [HIGH 5.2] UHD, Progressive my Plex server doesn't like it. Takes forever to load movies and in many cases won't play the picture. If I go down to [HIGH 4.0] FHD, Progressive everything works perfectly.
26th August 2018, 17:22 | #15986 | Link |
So now you know why I set HIGH 4.0 as default encoding profile.
27th August 2018, 11:52 | #15988 | Link |
Is your system configured as multiple-numa nodes? For example. Do you have multi socket mainboard or at least own Threadripper 1950 (2 NUMA) or Threadripper 2990wx (4 NUMA)?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th August 2018 at 11:56. |
27th August 2018, 12:00 | #15989 | Link | |
I do have several dual cpu Tyan & Supermicro X5680 & X5690 Xeon's systems. Doubt I'll ever be able to afford an awesome Threadripper system, way too pricey |
27th August 2018, 12:04 | #15990 | Link |
Check in Task Manager.
https://www.sqlpassion.at/archive/20...des-do-i-have/
27th August 2018, 12:12 | #15991 | Link | |
Also, is this anything to do with Hyper V / VM's ?? |
27th August 2018, 12:15 | #15992 | Link | |
27th August 2018, 12:31 | #15994 | Link |
Click performance tab and then
If you do not have this option then it means that your system is not configured in multiple numa nodes. Try this on those old xeons.
27th August 2018, 12:52 | #15996 | Link |
check also
coreinfo.exe -n
27th August 2018, 13:06 | #15997 | Link | |
I have however found that I can enable NUMA in the bios settings of most of the SMC motherboards So I will check that out, when I can, and go from there. Thanks again More questions to follow, I'm sure..... |
27th August 2018, 13:12 | #15998 | Link | |
In UMA mode instead of /node you can use /affinity to achieve the same separation.
and then
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th August 2018 at 13:18. |
27th August 2018, 15:17 | #15999 | Link | |
Are the asterisk's the core count ?? So I did a **-c ** command, and it stated "No NUMA nodes", which this laptop would not have. I'm guessing I'll get more nodes on the "old xeon's", once I've enabled NUMA in the BIOS....correct ?? |
27th August 2018, 15:19 | #16000 | Link | |
* = logical processor aka thread
