Old 3rd October 2011, 20:34   #41  |  Link
pbelkner
Originally Posted by kerimcem View Post
Can this plugin work with normal (non-lossless) mp3 files? Can you enable it with non-lossless mp3 files also?
Don't understand the question.
non-lossless == lossy should work. At least with my normal (non-lossless == lossy) MP3s it really does.
pbelkner is offline   Reply With Quote
Old 3rd October 2011, 20:50   #42  |  Link
naoan
Originally Posted by pbelkner View Post
What do you mean?
  • "Force Seek" should work with FLAC as well as with MP3.
  • "Prefer Float" should only affect MP3 (and other lossy codecs,) i.e. definitely not FLAC.
I mean prefer float checkbox works and there's no longer hotter sounds if I disable it.
With xmplay force seek works with mp3 files but not with anything else (flac, ogg, mkv, webm).
Wait, I just tried unchecking "sox decoder" and now seeking works with everything.
naoan is offline   Reply With Quote
Old 3rd October 2011, 20:54   #43  |  Link
kerimcem
when i delete in_mp3.dll, mp3 files dont work. don't it need to play mp3 files when i delete in_mp3.dll?
kerimcem is offline   Reply With Quote
Old 3rd October 2011, 20:54   #44  |  Link
pirlouy
_
Originally Posted by naoan View Post
I don't know what's going on inside though, I trust my own ears and music.
You should know our own brain is not trustable, placebo effect !
Anyway I would not like to "hijack" this thread, but Wasapi is not that needed with Windows 7. DirectSound is enough.
For upsampling, I don't know a lot of things, but I don't see how you can say it sounds better (I also use Sox Foobar2000 plugin without knowing really why)...
Old 3rd October 2011, 20:59   #45  |  Link
pbelkner
Yes, of course, you REALLY should uncheck this one. It's a relict from acient FFmpeg times where the FFmpeg FLAC demuxer was really slow.
I should remove this option with the next release.
Old 3rd October 2011, 21:02   #46  |  Link
pbelkner
You should better go to HA forum where I had enough trouble with TOS #8 people like you and was close to be banned.
Old 3rd October 2011, 21:07   #47  |  Link
pbelkner
Don't forget to add MP3 to FFSox's file extensions in configuration.
Also there's no need to remove "in_mp3.dll", just remove MP3 from it's file extensions in configuration.
Old 3rd October 2011, 21:22   #48  |  Link
naoan
Thanks for the insult, I'll enjoy my placebo. What's your audio setup btw?
@pbelkner
I see, thanks again!
Old 3rd October 2011, 21:28   #49  |  Link
kerimcem
when i do it, mp3 files are not playing.additionally,in preferences, "mp3 decoder" field is locked.i tried with two pc's..win7+winamp5.62
Old 3rd October 2011, 21:49   #50  |  Link
pbelkner
That's the key to the answer.
For license reasons MP3 is not distributed with FFSoX. You have to upgrade to full FFmpeg as described here: "http://in-ffsox.sourceforge.net/#installation" (only "http://ffmpeg.zeranoe.com/builds/win32/shared/" works.)
Old 3rd October 2011, 22:48   #51  |  Link
kerimcem
mp3 not work
and Unicode/UTF-8-character corrupt
Old 4th October 2011, 03:52   #52  |  Link
pbelkner
mp3 not work
I'm missing MP3 in the list of extensions.
UTF-8 is not supported yet.
Old 4th October 2011, 07:41   #53  |  Link
Milardo
Thanks for releasing the version with forced seeking. It's not really working too well with my .amr files but I can look forward to future versions.
Milardo is offline   Reply With Quote
Old 4th October 2011, 11:45   #54  |  Link
kerimcem
mp3 files worked! can you add utf-8 support soon?
Old 4th October 2011, 18:29   #55  |  Link
pirlouy
_
I can't; I'm banned.
And they are indeed not opened.
There's no insult. :/
It's just that we are fooled by our brain for several things, especially when it's time to compare audio quality.
What do you mean by audio setup ? Hardware ? I have JMLab speakers with Emotiva processor + Emotiva Amp.
But I let you use WASAPI without problem.
Old 5th October 2011, 12:22   #56  |  Link
pbelkner
BTW: According to my impression the traffic at HA forum has slowed down dramatically since summer, as also noted by others "http://www.hydrogenaudio.org/forums/index.php?showtopic=90740":
My perception is that HA used be much more active than it is now. Am I wrong?
Old 5th October 2011, 12:49   #57  |  Link
pbelkner
I have this planned for a long time. But most likely it will take some other time.
Old 5th October 2011, 13:31   #58  |  Link
kerimcem
waiting ( ç, ı, ü, ğ, ö, ş) turkish characters looking bad
Old 7th October 2011, 23:17   #59  |  Link
kerimcem
bug..
I can't change ID3 tags although song stopped.
Old 8th October 2011, 22:41   #60  |  Link
pbelkner
bug..
It's not a bug, tagging is simply not implemented yet.
