22nd June 2005, 17:36 | #21 | Link |
Avisynth Developer
@LigH,
You mean you actually like cascaded scrollable windows. Try swiping the text out of an inner window when it exceeds the size of the outer window, you can't! Try swiping all the text out of scrollable window, you can't. You have to do it in pieces this leads to transcription errors (same line twice/line missing) IanB |
22nd June 2005, 17:45 | #22 | Link |
I can - in two different possible ways:
a) Start the selection by dragging the mouse over the text from the top left, hold the left mouse button, and use the scroll wheel until the text went down far enough to complete the selection. b) Quote the text, and copy out of the quoted source. (I don't use the WYSIWYG editor.) |
22nd June 2005, 18:11 | #23 | Link | ||
Avisynth Developer
IanB |
22nd June 2005, 18:17 | #24 | Link | |
BTW: The WYSIWYG editor does not work in Opera 7.5x, anyway... |
22nd June 2005, 18:58 | #25 | Link | |
Solaris: burnt by the Sun
works for me everytime hmm it was working two days ago... |
22nd June 2005, 19:01 | #26 | Link | |
24th June 2005, 18:47 | #27 | Link |
I think the current situation (no horizontal scrollbars) is an improvement, but all I really wanted was for the CODE window to scale to the width of the page and *then* use a scrollbar if necessary.
Im running at 1600x1200 and that is wide enough for most CODE posts. But the really wide ones should scroll I would think. However I will defer to the developers in their choice of scrollbars. No scrollbars is better than the previous tiny code window. |
24th June 2005, 19:20 | #28 | Link |
did anyone tried to save page as text ... (with code in it)
anyone tried browsing with lynx ... only links can dump html (with code) to text AND render it properly ... Ecample =========== from links --------------- Code: function Cdeint(clip clp, clip output, int mode, float n) { ###### PREPARATION ###### global noisel = default(n,0) ord = clp.getparity() ? 1 : 0 tmpp = isyv12(clp) ? clp.leakkernelbob(order=ord, sharp=false, twoway=false, threshold=7).duplicateframe(0) : ============ from ffox --------------- Code: function Cdeint(clip clp, clip output, int mode, float n) { ###### PREPARATION ###### global noisel = default(n,0) ord = clp.getparity() ? 1 : 0 tmpp = isyv12(clp) ? clp.leakkernelbob(order=ord, sharp=false, twoway=false, threshold=7).duplicateframe(0) : \ clp.leakkernelbob(order=ord, sharp=false, twoway=false, threshold=7).duplicateframe(0).ConvertToYV12() one = tmpp two = tmpp.unfilter(-74,-74) three = tmpp.BilinearResize(480,240) global testclip = (mode==1 ? one : (mode==3 ? three : two)) ###### FRAMES FOR BLENDPARAMETERS ###### global combing_n0 = testclip.selecteven() global combing_n1 = testclip.selectodd() global combing_n2 = ---------------- Am I missing something? Bye |
27th June 2005, 03:46 | #29 | Link |
Avisynth Developer
Dear all,
Thanks for the many helpful hints, however none work in all cases. Bottom line is in the new vBulletin [ code ] et el is stuffed, previously I had no problem interacting efficiently with the interface, even crappy old Netscape 4 under unix didn't have a problem. Scrollable windows within scrollable windows is a really bad idea, no two browsers seem to handle this case consistantly, hence my heartfelt plea to totally avoid any vestige of scroll bars around a code window. I really appreciate the work Swede has done in getting us this far. I continue to live in hope. IanB |
