26th February 2010, 22:28 | #10941 | Link | |
Anyway, let's hope they merge ffmpeg-mt soon with the main branch. |
26th February 2010, 23:01 | #10942 | Link | |
MPC-HC Project Manager
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
27th February 2010, 01:23 | #10945 | Link | |
Kid for Today
here's why audioholics ppl prefer stepped attenuators: http://diyaudio.co.kr/wwwboard1/data/board1/compare.pdf http://www.dact.com/html/attenuator_data_sheet.html http://www.bursonaudio.com/hp_volume_control.htm I know the Burson ppl quite well...when they say that stepless pots are evil, I very much trust them. and the top of the line ALPS pots cost +$300...a cheapo analog stepless pot is junk...many cheap headphones amps have major stereo imbalance issues at low volume. thanks! but I'm allergic to anything newer than XP, it makes my eyes bleed for some reason. Last edited by leeperry; 27th February 2010 at 06:26. |
27th February 2010, 04:13 | #10946 | Link |
If you're worried about the quality of a voltage divider (noise from tiny thermal shifts in resistors and any possible minute non-linearity caused by that) then what's going in the the rest of the circuits in a sound system should give you nightmares.
27th February 2010, 16:13 | #10947 | Link | |
Media Control author
I spent (and lost) a lot of time to merge the old and new sources. I'd rather think that it is a better idea to take a fresh new start with the last code, and why not from ffmpeg directly. But this is a big work because : 1/ several filters use mplayer library to do some resize (resize filter, subtitles filter,...) => TODO : replace mplayer by ffmpeg 2/ one defined other pixel formats : FF_CSP* for ffdshow, PIX_FMT* for ffmpeg, and IMG_FMT* for mplayer. So rework is necessary => TODO : replace the colorspace conversions where IMG_FMT* are used with PIX_FMT* 3/ Haruhiko's patch for MT resize We miss Haruhiko ... This was not expected and I am not ready to do this right now, more urgent stuff to do (on Media Control). If Tal's patch is enough for now, we can carry on with it until some better rework is done on resize libraries. From my point of view HD audio is tabilized for now, just some special stuff is needed for xonar users. About DXVA : alpha blending to be done |
28th February 2010, 19:09 | #10950 | Link | |
diff --git a/swscale_template.c b/swscale_template.c index bbd9a1f..45e0ca5 100644 --- a/swscale_template.c +++ b/swscale_template.c @@ -2497,7 +2497,7 @@ static inline void RENAME(hcscale_fast)(SwsContext *c, int16_t *dst, /* GCC 3.3 makes MPlayer crash on IA-32 machines when using "g" operand here, which is needed to support GCC 4.0. */ #if ARCH_X86_64 && AV_GCC_VERSION_AT_LEAST(3,4) - :: "m" (src1), "m" (dst), "g" (dstWidth), "m" (xInc_shr16), "m" (xInc_mask), + :: "m" (src1), "m" (dst), "g" ((x86_reg)dstWidth), "m" (xInc_shr16), "m" (xInc_mask), #else :: "m" (src1), "m" (dst), "m" (dstWidth), "m" (xInc_shr16), "m" (xInc_mask), #endif (probably because it will cause problems with some compilers, but works ok with mingw64 4.4.3, though, so I don't give a damn) I'm not at all familiar with the swscale code, so I'm not sure if that is a completely valid patch, but you might want to evaluate it and try to push it forward if it seems ok. Also, I have no idea if there are other problems still. Last edited by Maccara; 28th February 2010 at 19:12. |
28th February 2010, 19:40 | #10951 | Link |
<The VFW Sheep of Death>
I was talking about audio delay. I realize negative video delay would be awkward. The audio delay settings cannot accept negative values.
Recommended all-in-one stop for x264/GCC needs on Windows: Komisar x264 builds! |
28th February 2010, 21:43 | #10952 | Link |
I have a big problem with all the latest SVN builds. I have an MKV which keeps going out of sync with the audio using all the latest SVN's. I reinstalled an icl11 build and it plays fine. But everything icl10 or generic available on the downloads page goes out of sync.
The build I have that works and I cannot remember where I downloaded it from is ffdshow_rev3195_20100110_sse_icl11.exe Everything since does not playback the video in sync with the audio correctly on this particular file. I can't upload a clip of it because I can't figure out how to save a small section of a 6-7GB MKV file (It's 1080P). Any ideas how to proceed? EDIT: I just installed build 3200 icl10 and that works fine. But builds 3274 and 3291 have the audio sync issue. Last edited by oddball; 28th February 2010 at 22:01. |
28th February 2010, 22:04 | #10953 | Link |
3292 now lets me use bluray subs with madVR and overlay! Great work (has still a few bugs though). But resizing is giving me a green picture with EVR, EVR-CP, madVR, and overlay (didn't test with others).
Regarding sub bugs, I have crashes or odd sub colors with stripped movie-only bluray structures (in ISO), but it doesn't seem to happen with straight bluray discs (and I assume rips too). With those though, sometimes the subs flicker when appearing/disappearing (specifically, happens with The Box US version). With bluray rips to mkv, the subs don't show sometimes after seeking. Disabling/enabling subs in ffdshow seems to fix it. Also, this seems to happen with MPC-HC's sub renderer as well, sometimes there are two subs onscreen, one for instance for the background and the other for the main dialogue, with independent timings. In this case, only one would show and the second one will only appear when the first one is out. The commercial bluray players show both appearing and disappearing at different times, overlapping. EDIT: went back to 3287 and the resize green picture problem is gone, it seems to be introduced with 3292. Anyone else having it (or not)? Last edited by Andy o; 28th February 2010 at 22:40. |
28th February 2010, 22:31 | #10954 | Link |
This may help indicate the problem with the audios sync issue (Or maybe not). BTW it's DTS audio not AC3.
http://pastebin.org/99104 EDIT: I've found out where the issue lies. Deblocking. If I tick 'skip deblocking always' the audio stays in sync! Last edited by oddball; 28th February 2010 at 22:36. |
28th February 2010, 22:57 | #10956 | Link |
I have the same crash with blu ray subtitle with rgb32 or yuy2 with rev 3292 as with 3287 and I don't use dxva.
http://sourceforge.net/tracker/index...41&atid=867360 Last edited by ikarad; 28th February 2010 at 23:05. |
28th February 2010, 23:08 | #10957 | Link | |
If you have a multi-core CPU, then use ffmpeg-mt instead of libavcodec for H.264. That should help improve decoding performance.
MPC-HC 2.2.1 |
28th February 2010, 23:50 | #10958 | Link | |
1st March 2010, 05:24 | #10959 | Link |
3291 32bit does not properly decode mpeg2 4:2:2 with libmpeg2. Chroma looks like max green, like a cheap night vision scope.
Reclusive fart. Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers |
