Old 26th June 2017, 15:39   #2201  |  Link
stax76
stax76's Avatar
@Natty
I can add more options but in order to make it more manageable I'm refactoring a lot code which might result in new bugs and reset settings.
@Ma
I have a automated test that is checking for common problems and compares my code file against the help console output of x265, nvenc, qsvenc and vceenc, theoretically staxrip is in sync 100%, there are some small issues sometimes but generally the CLI interface and documentation of most encoders are fantastic.
https://github.com/stax76/staxrip/bl...mmands.vb#L349
Old 26th June 2017, 16:28   #2202  |  Link
craigpro
stax76 - how do I batch resize a folder please? I have a folder of 1080p content which I want to resize to 720p. Thank you.
craigpro is offline   Reply With Quote
Old 26th June 2017, 16:47   #2203  |  Link
Ma
Originally Posted by stax76 View Post
I have a automated test that is checking for common problems and compares my code file against the help console output of x265 [...]
I see, so the error messages:
x265.exe: unknown option -- analysis-file
x265.exe: unknown option -- refine-level
are from StaxRip. Impressive!
I just remind that:
old option name ==> new option name
--analysis-mode ==> --analysis-reuse-mode
--analysis-file ==> --analysis-reuse-file
--refine-level ==> --analysis-reuse-level
From ver. 2.4+85 up to 2.4+87 doesn't work 2-pass encoding (we are waiting for a patch).
Ma is offline   Reply With Quote
Old 26th June 2017, 18:32   #2204  |  Link
stax76
stax76's Avatar
I think the newest test build has everything changed correctly but I'll double check it when the patch is here.
https://github.com/stax76/staxrip/bl...265Enc.vb#L790
https://github.com/stax76/staxrip/bl...265Enc.vb#L976
Old 26th June 2017, 21:51   #2205  |  Link
stax76
stax76's Avatar
hey, can delete temp file/folder delete the files permanently? as the temp folder can be as much as 40 G.B. mere moving to recycle bin doesnt save disk space. thanks.
I've forgotten there is already a setting under: Tools > Settings > System > Use recycle bin...
In the next build I move both to the settings as menu:
Disabled
Recycle Bin
Permanent
It's simple I believe, first you setup your empty project and then you add the source files in file batch mode, it then creates a job for every source file.
https://www.dropbox.com/s/gpr2yhowox...axRip.png?dl=0
Old 26th June 2017, 22:33   #2206  |  Link
Natty
Noob
oh renamed commands were causing those issues. a lot of modifications in x265 lately. and thanks a ton for ur avx2 builds.
Natty is offline   Reply With Quote
Old 26th June 2017, 22:36   #2207  |  Link
Natty
Noob
Disabled
Recycle Bin
Permanent
perfect . thanks
Old 27th June 2017, 21:13   #2208  |  Link
suspiciousBob
It should work with the build from today.
Thank you for the fix; staxrip has taken every audio i have thrown at it and processed it as expected. great stuff
Another small bug (in 1.5.0.0 at least); it seems that staxrip can't burn in .sup subtitles (don't understand why, but fair enough). In tools > advanced > hardcoded subs, the extension filter has *.sup (and others) in the list but when a .sup file is selected stax throws "only idx, srt and ass file types are supported" error dialog.
suspiciousBob is offline   Reply With Quote
Old 27th June 2017, 21:29   #2209  |  Link
stax76
stax76's Avatar
It could probably be more intuitive and more clear, unfortunately AviSynth has no sup filter, only VapourSynth. At the moment I cannot change it as I'm trying to implement parallel audio processing, the code quality of this area is a total mess.
Old 27th June 2017, 23:26   #2210  |  Link
gonca
Suptitle
gonca is offline   Reply With Quote
Old 28th June 2017, 07:48   #2211  |  Link
NikosD
Hello Frank.
A new QSVEncC v2.70 is available: (with a few new options and bug fixes)
https://onedrive.live.com/?id=6BDD43...DD4375AC8933C6
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 28th June 2017, 13:21   #2212  |  Link
ABDO
Hi Frank
just want to thank you for your great and hard work in staxrip ، and we strongly appreciate that
thank you very mush 😍👍
ABDO is offline   Reply With Quote
Old 28th June 2017, 22:46   #2213  |  Link
alter4
Excuse me guys, might be stupid question but I am newbie to StaxRip. Is recent "unstable" version really unstable? I like cutting edge software and what to try recent version if it is "beta" and not "alpha" quality.
alter4 is offline   Reply With Quote
Old 29th June 2017, 07:08   #2214  |  Link
burfadel
Seems for me Staxrip is preventing the monitor to turn off after the 5 minutes I have it set to. Not standby, just monitor off. Using knlmeanscl, but was never an issue before with earlier builds. Using latest test build, but was happening with the previous one as well.
Old 29th June 2017, 10:31   #2215  |  Link
stax76
stax76's Avatar
@gonca
As far as I know there isn't a AviSynth+ x64 compatible sup filter that is working in a .NET client app. There is a filter from somebody who also worked on a player but it's discontinued and don't work in StaxRip.
I'm getting:
D3D9Device: Failed CreateDeviceEx: -2005530516.
Failed to initialize HW Device. : null pointer.
Failed to CreateHWDevice. : null pointer.
QSVEncC.exe finished with error!
2.66 is working, maybe my driver is old, in device manager it shows as: 21.20.16.4534
@ABDO
You're welcome.
Some are more stable than others, unless you want x265 2pass encoding the last test build should be fine. One issue the stable release for instance has is with mp4box muxing.
I've not changed the code since it was added. I've changed a flag now and tested it successfully afterwards (without knlmeanscl), new flag is called PowerRequestExecutionRequired, old was PowerRequestSystemRequired.
Old 29th June 2017, 11:10   #2216  |  Link
burfadel
After some playing around it seems to be fine now! Must be one of those little glitches in Windows because of the use of the video card with knlmeanscl.
Old 29th June 2017, 11:25   #2217  |  Link
NikosD
My Haswell Core i3 works fine using latest 15.40 drivers which is 4624 (compatible with Broadwell/ Haswell)
Take a look here:
https://downloadcenter.intel.com/product/81497
For Skylake/ Kabylake latest 15.45 drivers you can download 4678 version from here:
https://downloadcenter.intel.com/pro...D-Graphics-630
Old 29th June 2017, 11:48   #2218  |  Link
stax76
stax76's Avatar
Thanks for the link, with the new driver neither worked, after a second look at the error:
I remembered there are related options so I tried --d3d11 and this works.
Old 29th June 2017, 11:59   #2219  |  Link
NikosD
Ah OK.
I have my only GPU (iGPU) connected directly to the monitor, so D3D9 always works fine.
I think you need the latest driver/API and Kabylake for some new features of 2.70 to work, anyway.
Old 29th June 2017, 13:35   #2220  |  Link
JohnLai
Dear stax76,
Where did the 'fixed bitrate' option at Project Options go?
JohnLai is offline   Reply With Quote
