15th September 2011, 18:11 | #9781 | Link | |
I do own a Samsung Galaxy Tab 10.1 though, which is Tegra 2, but i didn't try playing something over HDMI yet.
15th September 2011, 18:18 | #9782 | Link |
I wonder if this only works for the EVR renderer or is Renderer Agnostic counting DWM frames ?
http://forum.doom9.org/showthread.php?t=162540 Though im really unhappy with the Playback Quality (could be though Silverlight 5 debug code) this stuttering is strange doesn't experience that with Adobes Player on GT1 Hmm still not smooth in Fullscreen with Silverlight 4 very strange (the movements are totally hacked up i wonder what happens if i turn Aero off)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 15th September 2011 at 18:38. |
15th September 2011, 18:44 | #9783 | Link |
can you add 3D Vision support, please. There is no free Renderer that can shutter the 3d vision. The commercial software (Stereoscopic player, Powerdvd,..) does not work outside of their software. I want to use it with MPC OR Mediaportal (in future). Last edited by MaxMan23; 15th September 2011 at 18:47. |
16th September 2011, 05:04 | #9786 | Link |
Also the DSP Decoder itself isn't as powerfull as the Desktop Core one but with Tegra 3 this gonna change fundamentally and partly most probably also with Kepler, after the Boxeebox disaster and the smack from Intel being more performant with their Atom SOC and the same Decoder that is in current GT1/2s which is still beating Nvidia performance wise even their newer update VP5.
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 16th September 2011 at 05:14. |
16th September 2011, 11:44 | #9787 | Link |
Is it possible to disable the very annoying win7 notification when aero is disabled? Since I set madvr to do so I get that darn ballon every time I go fullscreen, and it even prevents exclusive mode. (I don't want to disable all, the others are mostly useful)
16th September 2011, 22:54 | #9790 | Link |
Slowly we get the Info how WDDM evolved and in which direction http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx
http://msdn.microsoft.com/en-us/wind...dware/br259098 Finally we see more stages of Preemption
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 16th September 2011 at 23:39. |
17th September 2011, 09:30 | #9792 | Link |
Satsuki'S Softs Maker
Hello.
thanks for this great renderer, it's to my mind the best video renderer. i often use my own gui to config my video filter (some media files have differents config files ...) but i don't understand how the madvr setting works in the windows registry. the only options of the madvr renderer i would like to enable/disable often is the decoding options because on some hd file on my low power computer i need to enable it. so here is my question: is there any way to enable/disable the decoding options of madvr without launch madvr (with regedit or command line ?) thnaks a lot and keep the good work, madvr is the best ^^ |
17th September 2011, 14:15 | #9793 | Link | |
_
Or just hopes ? :-) In fact, Windows Seven (or XP) are quite good for video playback (especially when compared to limited all-in-one hardware stuff). From what I've read, the difficult part comes from accessing GPU stuff (drivers, language, etc.) so it should still be difficult with Windows 8... |
17th September 2011, 18:05 | #9794 | Link |
madVR With Non-ringing Lanczos?
madshi, is there any chance you could implement your optimized algorithm to provide Lanczos scaling without ringing into madVR? You could call the option madLanczos
As discussed here I believe the consensus was that nnedi3 was superior but your algorithm is obviously far superior to regular Lanczos. Thank you for all your great works. |
17th September 2011, 18:48 | #9795 | Link |
Random fact:
Sandy Bridge GT2 is 5 times faster than a Radeon X1600XT at madVR rendering. Needed to plug in that ancient card because it has analog video capture input. Was going to watch some movies while recording old tapes. Didn't work so well... =) |
18th September 2011, 09:46 | #9797 | Link |
reporting an issue here of madvr with norton IS 2012.i installed norton IS 2012 & immediately started getting a very unusual problem with madvr.some videos(anime mkv with .ass subs,avc/x264 codec) start fine but after playing for 20-30 sec renderer queue & backbuffer queue started getting empty with only 0-1 value & no. of frames dropped starts increasing steadily(observation using ctrl+J).i tried pot player latest stable version & MPC-HC latest released & both displayed this same problem.nothing was changed on system(laptop C2D 2.00GHz,radeon 4570)after installing norton 2012.tried different madvr versions(0.54,0.73,0.74) & all have this same problem.i uninstalled norton IS 2012 & installed 2011 version & everything went back to normal as it was before installing norton 2012.
18th September 2011, 18:33 | #9798 | Link |
hey everyone i was hoping that you could help me im having problem when i try to play a fullscreen video with madVR and MPC-HC. After a few seconds i it crashes and i get this error from windows:
Problem signature: Problem Event Name: BEX Application Name: mpc-hc.exe Application Version: 1.5.2.3456 Application Timestamp: 4e29d332 Fault Module Name: madVR.ax Fault Module Version: 0.74.0.0 Fault Module Timestamp: 4e516bc2 Exception Offset: 0003231a Exception Code: c000000d Exception Data: 00000000 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: cfd3 Additional Information 2: cfd39af6f2554026609aee2812317e49 Additional Information 3: ba1d Additional Information 4: ba1d1af66b681e7b15d51afc345f34da |
18th September 2011, 20:00 | #9799 | Link | |
Wonder why isn't it included already, since its madshi's creation. |
18th September 2011, 23:40 | #9800 | Link | |
