Old 7th June 2011, 05:39   #12161  |  Link
Capsbackup
There appears to be a problem with the english or any subtitles being forced on with no option to turn them off through the menu or through the remote. I am using BD-RBV03803 to make a full backup of True Blood season 3. I have tried two different times now, with the same results. Subtitles are always on regardless if the subtitle set up page says they are off. There is no way to turn them off.
The original does not display this same behavior. I have not had this happen on any other title, so perhaps True Blood Season 3 is unique... damn vampires!
Capsbackup is offline   Reply With Quote
Old 7th June 2011, 08:25   #12162  |  Link
apophis906
Originally Posted by shon3i View Post
I agree, but from this point it's completely irrelevant since quality will not drop (reencoding will not affect that much since bitrate can be up 256kbps and eac3 encoding is efficient as much ac3 is), and it's secondary audio, who cares anyway. Reinserting is not good idea (there is ton of PES/DTS extensions,flags, ...) and tsmuxer support eac3, but you maybe success, you may need more samples ?
The problem from my understanding is that reencoding would make the audio useless. The dts-express track has metadate inside of it that controls the volume of the secondary track as well as the main track and the mixing of the tracks together. Once you decode the audio you would loose that metadata and would then have no way for the player to know how to set the two audio tracks. Could end up with both tracks playing and full volume the whole time. This is from the DTS site.
To ensure that the audio mix comes out perfectly, DTS-HD employs an innovative feature called Dynamic Mixing. When the movie or concert creators encode the Secondary or Sub audio, they include meta-data that will dynamically mix that audio with the primary audio. With Dynamic Mixing, you’ll continually have the correct sound balance — just as the producers intended.
apophis906 is offline   Reply With Quote
Old 7th June 2011, 11:35   #12163  |  Link
PurpleMan
Yes, but typically the ISO is created by the same (or similar) program that writes it.
If you know (or can find out) how it needs to be done, maybe we can seek the help of ImgBurn's author to implement a feature that can write an ISO with mulit-referenced blocks.
Just an idea.
PurpleMan is offline   Reply With Quote
Old 7th June 2011, 14:50   #12164  |  Link
jdobbs
Not sure what could cause something like this. The subtitles are simply extracted and then remuxed with TSMUXER. There really is no processing done that could change the behaviour (except when resizing).
Website: www.jdobbs.net
Old 7th June 2011, 15:17   #12165  |  Link
Capsbackup
No resizing, kept full 1080P. This set does not allow turning subtitles on / off by the remote subtitle button while the episode is playing. ( message pops up saying feature not allowed ) The only way to turn them on / off is through the languages button. By default they are off, but with the BD-RB backup they are always on, even though the setup says they are off!
EDIT:
If I select another language, then that language is displayed always, even though the subtitle selection button option says " None " for the subtitles to be displayed.
Old 7th June 2011, 15:26   #12166  |  Link
drmih
I had something very similar on 'the girl with the dragon tattoo' - I put it down to moving between Swedish and English soundtracks but I couldn't turn off the english subtitles - never got to the bottom of it and forgot to raise it.
drmih is offline   Reply With Quote
Old 7th June 2011, 15:50   #12167  |  Link
Capsbackup
I do not have this problem with The Girl With The Dragon tatoo. The english subtitles start on by default, but I can turn them off with the remote.
Old 7th June 2011, 17:09   #12168  |  Link
jdobbs
EDIT:
Are you ripping with AnyDVD HD? Any settings selected that might change the commands?
Old 7th June 2011, 17:13   #12169  |  Link
Winenut
BD Rebuilder exceeding 40 mbps on some titles
I apologize if I posted this in the wrong spot, but I could not find any post specifically dealing with this problem.
I've been using BD Rebuilder for quite some time, and I must say it's a great tool and very reliable. I've encountered very few problems...and the results are often amazing.
But very recently I encountered some issues with a couple of Blu-Ray discs (where the movie is in the 38-39GB range). These both were shot in a soft look, which appears to cause some issues and results in VERY HIGH bit rates even when compressed down to a BD25. In particular is AI (Artificial Intelligence), where I've noticed that BD Rebuilder has a number of sequences where the re-encoded bitrate exceeds the original (which was already high). Generally these are in the low 40 mbps range, which is above the Blu-Ray standard.
Interesting these high bitrate sections playback ok on my Sony BX-37. However, generally each time there is a bitrate spike it's followed by scene using a lower bit rate...and quite often when this occurs, the video freezes for 1-2 seconds and resumes. This only happens when played on my BX-37 (which is update to date with regard to firmware). Since this only happens for the two films where BD Rebuilder pushed the bitrate above 40, and does not occur for any other film I've re-encoded with BD Rebuilder, I'm thinking it's related to that excessively high bitrate.
Many of these high bit rate scenes are low-contrast without obvious reason for the high bitrate...except that they are complex video scenes with low-contract and that semi-frosted look that some film makers are striving for.
Except for the freezing, the end result look great. In fact, the re-encode is slightly sharper with less noise.
Now I've tried all the possible settings (High Speed, Good, Better, High Quality, and Highest Quality)...and this is one movie where the highest encoding actually makes it better without introducing DNR artifacts and without adding additional softness or reducing the color, or shifting the color.
All resulted in at least some freezing, with the Highest Quality setting introducing the most...mainly because it introduced the most high bitrate spikes.
So my question is...is there a way or and option to limit the maximum bitrate to under 40 mbps?
Note than when I compressed down to a BD5 (which still looks ok), the playback appeared without any freezing. Which tends to imply the problem is the high bit rate...
Winenut is offline   Reply With Quote
Old 7th June 2011, 17:19   #12170  |  Link
jdobbs
How are you determining that the bitrate is above 40Mbs? BD Rebuilder already has code that limits the average bitrate in the command line -- and the maximum (--vbv-maxrate) is always set to 35Mbs or below (occasionally the combined audio bitrate drives it lower).
If you're seeing spikes above 40Mbs, I'd have to believe there may be some glitch in X264's limiting algorithm. A player should be able to handle spikes through it's buffering, but they have to be very short.
Old 7th June 2011, 17:45   #12171  |  Link
Capsbackup
Yes I am ripping with AnyDVD HD, and I have not changed any rip settings. The original rip on my hard drive works properly with TMT3 and PowerDVD. The original Blu-ray disc plays properly as well on my Sony S360 and BX1.
The BD-RE of the BD-RB backup has the subtitles on all the time regardless of playing back on my S360, BX1 or Power DVD and TMT3.
I always burn to disc for the ultimate test of standalone playback. I became suspicious when the software playback had the subtitles on all the time. So this reporting is only after confirming that as well as exhausting all other reasons on my end!
I have tried two different Blu-ray titles after this problem, ripping them with AnyDVD HD with no changes, doing full backups with BD-RBV03803, and I cannot repeat this issue. So it seams to be related to True Blood S3 D1. I have not tried discs 2-5 yet, but I will and let you know if this happens on these discs too.
Old 8th June 2011, 02:20   #12172  |  Link
juardis
The Pacific Disc 3
Hi all, very useful forum. Did a search on Pacific, got this thread as a hit, and, well, it's a bazillion pages. I spent some time looking through it but as you can imagine, no luck. So anyway...
Trying to back up my Blu disc set of The Pacific. No problems with Discs 1, 2, and 4 so far, but Disc 3 is stumping me. I'm selecting BD-R since that's what I'm backing up to but the file size after BD Builder is a couple hundred sectors larger than the BD-R. I've tried custom size, but same problem. I really don't want to go to DVD DL so what's the trick to forcing a couple hundred sectors off this rebuild?
Particulars:
BDRebuilder ver 38.03 beta
ImgBurn v2.5.5.0 reports file size as 12,283,158 sectors and BD-R as 12,281,442 sectors.
Tried to backup anyway, ran out of space, backup failed.
Any suggestions?
juardis is offline   Reply With Quote
Old 8th June 2011, 02:38   #12173  |  Link
jdobbs
Particulars:
Any suggestions?
Do you have the log for that encode? It would also be helpful to see the INF file. It's more important to find the cause of the oversize and fix it than to simply post a tweak to make it fit.
Old 8th June 2011, 02:39   #12174  |  Link
Capsbackup
@jdobbs;
I can confirm the exact same problem with disc 2 of True Blood Season 3.
Old 8th June 2011, 02:43   #12175  |  Link
jdobbs
@jdobbs;
Can you post your INI so I can test it with the same settings? Ughh... I really hate vampire movies. Zombies are so much more fun. Why couldn't you have found the problem in "Shaun of the Dead" or "Zombieland"? Hmmm -- maybe I should try "The Pacific Disc 3" instead...
Old 8th June 2011, 02:57   #12176  |  Link
Capsbackup
I never watched either of those two movies, not my favorite either. True Blood is for my daughter, she's the fan.
This last test was done at quickest setting to BD5 for DVD+RW testing so bitrates will be quite low. The first test was to BD9, but I since have run this latest test, so I don't have that INI.
[HTML][Options]
MIN_M2TS_SIZE=100
KEEP_MBTREE=1
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=0
QUICK_EXTRAS=0
TARGET_SIZE=8250
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DEINTERLACE=1
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=0
REMOVE_WORKFILES=0
FULL_AVCHD=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=4500
REMOVE_OUTPUT=0
OPEN_GOP=1
USE_FILTERS=0
MOVIE_ONLY_LOOP=1
BDMV_CERT_ONLY=1
USE_LAVF=0
IVTC_PULLDOWN=1
VERSION=0.38.0.3
ASSUME_DVD_PAL=0
SD_TO_1080=0
CONVERT_WIDE=0
AUTO_BLANK=0
[Paths]
SOURCE_PATH=G:\BD RIPS\TRUE_BLOOD_S3_D2\
WORKING_PATH=G:\TRUE_BLOOD_S3_D2 BDRB\[/HTML]
[HTML][Status]
LABEL=TRUE_BLOOD_S3_D2
VERSION=v0.38.03 (beta)
SOURCE_SIZE=44628144006
SOURCE_VIDEO_SIZE=44560041984
TARGET_SIZE=4718592000
REDUCTION=.104364578015205
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
QUICK=0
ENCODE_STEP=0
COMPLETED=63
REBUILD_COMPLETE=1
[00000]
AUDIO=
PGS=
M2TS_TARGET=4101859
VIDEO2=0
V2MBRATE=0
RATE=2032
NSIZE=4257792
FLINK=-1
MLINK=-1
[00001]
AUDIO=1
PGS=
M2TS_TARGET=20836313
VIDEO2=0
V2MBRATE=0
RATE=2563
NSTART=27000000
NEND=29128320
NSIZE=19857408
FLINK=0
MLINK=0
[00002]
AUDIO=100000
PGS=111111111000
M2TS_TARGET=1314871692
VIDEO2=50852230.0420168
V2MBRATE=7000
RATE=1627
NSTART=27000000
NEND=186285600
NSIZE=1294147584
FLINK=0
MLINK=0
[00003]
AUDIO=
PGS=
M2TS_TARGET=3206
VIDEO2=0
V2MBRATE=0
RATE=200
NSTART=27000000
NEND=27043168
NSIZE=12288
FLINK=0
MLINK=0
[00004]
AUDIO=1
PGS=
M2TS_TARGET=13044898
VIDEO2=0
V2MBRATE=0
RATE=1241
NSTART=27000000
NEND=29231604
NSIZE=12711936
FLINK=0
MLINK=0
[00005]
AUDIO=1
PGS=
M2TS_TARGET=8905849
VIDEO2=0
V2MBRATE=0
RATE=1252
NSTART=27000000
NEND=28514638
NSIZE=8792064
FLINK=0
MLINK=0
[00006]
AUDIO=1
PGS=
M2TS_TARGET=3731236
VIDEO2=0
V2MBRATE=0
RATE=1366
NSTART=27000000
NEND=27598723
NSIZE=4159488
FLINK=0
MLINK=0
[00007]
AUDIO=1
PGS=
M2TS_TARGET=6303153
VIDEO2=0
V2MBRATE=0
RATE=1283
NSTART=27000000
NEND=28054803
NSIZE=6395904
FLINK=0
MLINK=0
[00008]
AUDIO=1
PGS=11111
M2TS_TARGET=31449078
VIDEO2=0
V2MBRATE=0
RATE=1339
NSTART=27000000
NEND=32579949
NSIZE=26947584
FLINK=0
MLINK=0
[00009]
AUDIO=1
PGS=
M2TS_TARGET=5690792
VIDEO2=0
V2MBRATE=0
RATE=1401
NSTART=27000000
NEND=27900000
NSIZE=5013504
FLINK=0
MLINK=0
[00010]
AUDIO=1
PGS=
M2TS_TARGET=5695280
VIDEO2=0
V2MBRATE=0
RATE=1402
NSTART=27000000
NEND=27900000
NSIZE=5044224
FLINK=0
MLINK=0
[00011]
AUDIO=1
PGS=
M2TS_TARGET=4175598
VIDEO2=0
V2MBRATE=0
RATE=1315
NSTART=27000000
NEND=27686936
NSIZE=4343808
FLINK=0
MLINK=0
[00012]
AUDIO=1
PGS=
M2TS_TARGET=3100279
VIDEO2=0
V2MBRATE=0
RATE=1193
NSTART=27000000
NEND=27542417
NSIZE=3366912
FLINK=0
MLINK=0
[00013]
AUDIO=1
PGS=11111
M2TS_TARGET=30543040
VIDEO2=0
V2MBRATE=0
RATE=1291
NSTART=27000000
NEND=32403523
NSIZE=26118144
FLINK=0
MLINK=0
[00015]
AUDIO=1
PGS=
M2TS_TARGET=3420246
VIDEO2=0
V2MBRATE=0
RATE=1241
NSTART=27000000
NEND=27584640
NSIZE=4030464
FLINK=0
MLINK=0
[00018]
AUDIO=
PGS=
M2TS_TARGET=2271187
VIDEO2=0
V2MBRATE=0
RATE=804
NSTART=27000000
NEND=27944068
NSIZE=2660352
FLINK=0
MLINK=0
[00019]
AUDIO=1
PGS=
M2TS_TARGET=5693357
VIDEO2=0
V2MBRATE=0
RATE=1402
NSTART=27000000
NEND=27900000
NSIZE=5001216
FLINK=0
MLINK=0
[00020]
AUDIO=
PGS=
M2TS_TARGET=9997198
VIDEO2=0
V2MBRATE=0
RATE=303
NSTART=27000000
NEND=38034148
NSIZE=12208128
FLINK=0
MLINK=0
[00027]
AUDIO=100000
PGS=111111111000
M2TS_TARGET=1170805212
VIDEO2=65418151.2605042
V2MBRATE=7000
RATE=1485
NSTART=27000000
NEND=174569295
NSIZE=1155606528
FLINK=0
MLINK=0
[00028]
AUDIO=1
PGS=11111
M2TS_TARGET=11965090
VIDEO2=0
V2MBRATE=0
RATE=1288
NSTART=27000000
NEND=29115238
NSIZE=9621504
FLINK=0
MLINK=0
[00029]
AUDIO=1
PGS=11111
M2TS_TARGET=9716346
VIDEO2=0
V2MBRATE=0
RATE=1439
NSTART=27000000
NEND=28676049
NSIZE=8423424
FLINK=0
MLINK=0
[00030]
AUDIO=1
PGS=
M2TS_TARGET=5030980
VIDEO2=0
V2MBRATE=0
RATE=1316
NSTART=27000000
NEND=27827702
NSIZE=5142528
FLINK=0
MLINK=0
[00031]
AUDIO=1
PGS=
M2TS_TARGET=18102168
VIDEO2=0
V2MBRATE=0
RATE=1231
NSTART=27000000
NEND=30113735
NSIZE=17221632
FLINK=0
MLINK=0
[00032]
AUDIO=1
PGS=11111
M2TS_TARGET=9685567
VIDEO2=0
V2MBRATE=0
RATE=1406
NSTART=27000000
NEND=28668542
NSIZE=8361984
FLINK=0
MLINK=0
[00033]
AUDIO=1
PGS=11111
M2TS_TARGET=9708651
VIDEO2=0
V2MBRATE=0
RATE=1404
NSTART=27000000
NEND=28672295
NSIZE=8300544
FLINK=0
MLINK=0
[00034]
AUDIO=1
PGS=11111
M2TS_TARGET=9665689
VIDEO2=0
V2MBRATE=0
RATE=1447
NSTART=27000000
NEND=28668542
NSIZE=8183808
FLINK=0
MLINK=0
[00035]
AUDIO=1
PGS=11111
M2TS_TARGET=9688773
VIDEO2=0
V2MBRATE=0
RATE=1431
NSTART=27000000
NEND=28670418
NSIZE=8435712
FLINK=0
MLINK=0
[00036]
AUDIO=1
PGS=11111
M2TS_TARGET=9687491
VIDEO2=0
V2MBRATE=0
RATE=1406
NSTART=27000000
NEND=28668542
NSIZE=8546304
FLINK=0
MLINK=0
[00037]
AUDIO=1
PGS=11111
M2TS_TARGET=9634911
VIDEO2=0
V2MBRATE=0
RATE=1506
NSTART=27000000
NEND=28668542
NSIZE=7809024
FLINK=0
MLINK=0
[00038]
AUDIO=1
PGS=11111
M2TS_TARGET=9702239
VIDEO2=0
V2MBRATE=0
RATE=1366
NSTART=27000000
NEND=28668542
NSIZE=8294400
FLINK=0
MLINK=0
[00039]
AUDIO=1
PGS=11111
M2TS_TARGET=9704162
VIDEO2=0
V2MBRATE=0
RATE=1396
NSTART=27000000
NEND=28670418
NSIZE=8712192
FLINK=0
MLINK=0
[00040]
AUDIO=1
PGS=11111
M2TS_TARGET=12342125
VIDEO2=0
V2MBRATE=0
RATE=1441
NSTART=27000000
NEND=29130253
NSIZE=11218944
FLINK=0
MLINK=0
[00041]
AUDIO=1
PGS=11111
M2TS_TARGET=12292751
VIDEO2=0
V2MBRATE=0
RATE=1428
NSTART=27000000
NEND=29120868
NSIZE=10758144
FLINK=0
MLINK=0
[00042]
AUDIO=1
PGS=11111
M2TS_TARGET=77233181
VIDEO2=0
V2MBRATE=0
RATE=1301
NSTART=27000000
NEND=40239476
NSIZE=65961984
FLINK=0
MLINK=0
[00043]
AUDIO=1
PGS=11111
M2TS_TARGET=15923316
VIDEO2=0
V2MBRATE=0
RATE=1478
NSTART=27000000
NEND=29755252
NSIZE=14419968
FLINK=0
MLINK=0
[00044]
AUDIO=1
PGS=11111
M2TS_TARGET=24084713
VIDEO2=0
V2MBRATE=0
RATE=1387
NSTART=27000000
NEND=31146017
NSIZE=21295104
FLINK=0
MLINK=0
[00045]
AUDIO=1
PGS=11111
M2TS_TARGET=26606615
VIDEO2=0
V2MBRATE=0
RATE=1429
NSTART=27000000
NEND=31590836
NSIZE=23494656
FLINK=0
MLINK=0
[00046]
AUDIO=1
PGS=11111
M2TS_TARGET=24192437
VIDEO2=0
V2MBRATE=0
RATE=1394
NSTART=27000000
NEND=31166662
NSIZE=20754432
FLINK=0
MLINK=0
[00047]
AUDIO=1
PGS=11111
M2TS_TARGET=24016744
VIDEO2=0
V2MBRATE=0
RATE=1420
NSTART=27000000
NEND=31142263
NSIZE=21178368
FLINK=0
MLINK=0
[00048]
AUDIO=1
PGS=11111
M2TS_TARGET=24042393
VIDEO2=0
V2MBRATE=0
RATE=1400
NSTART=27000000
NEND=31142263
NSIZE=21614592
FLINK=0
MLINK=0
[00049]
AUDIO=1
PGS=11111
M2TS_TARGET=12265820
VIDEO2=0
V2MBRATE=0
RATE=1510
NSTART=27000000
NEND=29124622
NSIZE=10450944
FLINK=0
MLINK=0
[00050]
AUDIO=1
PGS=11111
M2TS_TARGET=26552753
VIDEO2=0
V2MBRATE=0
RATE=1472
NSTART=27000000
NEND=31592713
NSIZE=22554624
FLINK=0
MLINK=0
[00051]
AUDIO=1
PGS=11111
M2TS_TARGET=26695103
VIDEO2=0
V2MBRATE=0
RATE=1376
NSTART=27000000
NEND=31592713
NSIZE=22659072
FLINK=0
MLINK=0
[00052]
AUDIO=1
PGS=11111
M2TS_TARGET=26618798
VIDEO2=0
V2MBRATE=0
RATE=1471
NSTART=27000000
NEND=31603974
NSIZE=22837248
FLINK=0
MLINK=0
[00053]
AUDIO=1
PGS=11111
M2TS_TARGET=26641882
VIDEO2=0
V2MBRATE=0
RATE=1413
NSTART=27000000
NEND=31592713
NSIZE=23808000
FLINK=0
MLINK=0
[00054]
AUDIO=1
PGS=11111
M2TS_TARGET=31847273
VIDEO2=0
V2MBRATE=0
RATE=1406
NSTART=27000000
NEND=32489859
NSIZE=27082752
FLINK=0
MLINK=0
[00055]
AUDIO=1
PGS=11111
M2TS_TARGET=31056654
VIDEO2=0
V2MBRATE=0
RATE=1296
NSTART=27000000
NEND=32495490
NSIZE=26425344
FLINK=0
MLINK=0
[00056]
AUDIO=1000
PGS=111111111000
M2TS_TARGET=1188820174
VIDEO2=57202741.5966387
V2MBRATE=7000
RATE=1493
NSTART=27000000
NEND=178284960
NSIZE=1173817344
FLINK=0
MLINK=0
[00057]
AUDIO=
PGS=
M2TS_TARGET=4101217
VIDEO2=0
V2MBRATE=0
RATE=2031
NSTART=27000000
NEND=27673798
NSIZE=4208640
FLINK=0
MLINK=0
[00059]
AUDIO=1
PGS=
M2TS_TARGET=5626670
VIDEO2=0
V2MBRATE=0
RATE=1305
NSTART=27000000
NEND=27930930
NSIZE=5412864
FLINK=0
MLINK=0
[00061]
AUDIO=
PGS=
M2TS_TARGET=4102500
VIDEO2=0
V2MBRATE=0
RATE=2032
NSTART=27000000
NEND=27673798
NSIZE=4288512
FLINK=0
MLINK=0
[00062]
AUDIO=
PGS=
M2TS_TARGET=4102500
VIDEO2=0
V2MBRATE=0
RATE=2032
NSTART=27000000
NEND=27673798
NSIZE=4270080
FLINK=0
MLINK=0
[00065]
AUDIO=1
PGS=11111
M2TS_TARGET=28468707
VIDEO2=0
V2MBRATE=0
RATE=1324
NSTART=27000000
NEND=32048793
NSIZE=24545280
FLINK=0
MLINK=0
[00068]
AUDIO=1
PGS=11111
M2TS_TARGET=60682114
VIDEO2=0
V2MBRATE=0
RATE=1242
NSTART=27000000
NEND=37707572
NSIZE=52058112
FLINK=0
MLINK=0
[00069]
AUDIO=1
PGS=11111
M2TS_TARGET=21858411
VIDEO2=0
V2MBRATE=0
RATE=1507
NSTART=27000000
NEND=30915161
NSIZE=18683904
FLINK=0
MLINK=0
[00070]
AUDIO=1
PGS=11111
M2TS_TARGET=28475760
VIDEO2=0
V2MBRATE=0
RATE=1317
NSTART=27000000
NEND=32045040
NSIZE=24416256
FLINK=0
MLINK=0
[00071]
AUDIO=1
PGS=11111
M2TS_TARGET=9470119
VIDEO2=0
V2MBRATE=0
RATE=1225
NSTART=27000000
NEND=28668542
NSIZE=8017920
FLINK=0
MLINK=0
[00072]
AUDIO=1
PGS=11111
M2TS_TARGET=46257961
VIDEO2=0
V2MBRATE=0
RATE=1303
NSTART=27000000
NEND=35188805
NSIZE=40464384
FLINK=0
MLINK=0
[00073]
AUDIO=1
PGS=11111
M2TS_TARGET=33947256
VIDEO2=0
V2MBRATE=0
RATE=1308
NSTART=27000000
NEND=33013507
NSIZE=28452864
FLINK=0
MLINK=0
[00074]
AUDIO=1
PGS=11111
M2TS_TARGET=17037749
VIDEO2=0
V2MBRATE=0
RATE=1294
NSTART=27000000
NEND=30016138
NSIZE=14751744
FLINK=0
MLINK=0
[00075]
AUDIO=
PGS=
M2TS_TARGET=641
VIDEO2=0
V2MBRATE=0
RATE=200
NSTART=27000000
NEND=27043168
NSIZE=12288
FLINK=0
MLINK=0
[00076]
AUDIO=
PGS=
M2TS_TARGET=4098011
VIDEO2=0
V2MBRATE=0
RATE=2030
NSTART=27000000
NEND=27673798
NSIZE=4270080
FLINK=0
MLINK=0
[00077]
AUDIO=
PGS=
M2TS_TARGET=4096088
VIDEO2=0
V2MBRATE=0
RATE=2029
NSTART=27000000
NEND=27673798
NSIZE=4220928
FLINK=0
MLINK=0[/HTML]
Old 8th June 2011, 18:20   #12177  |  Link
worknstiff
Hey everyone, I know this has probably been discussed before but I can't remember the answer or maybe there is a new recomendation now for tne newest version. I have some concert BD disks that I am backing up and they are mostly 1080i VC-1 29.97 video. I noticed that these files have the little asterick " ** " indicator in the stream section but when it shows the source in the log section while processing the "**" are not shown. What is the best method to keep the BD_RB output smooth like the original, without judders or smearing? Does BD_Rebuilder leave the output still interlaced like the original if you take out the checkmark from "use DEINTERLACER on interlaced sources? Also while we are on this subject what about the use "IVCT sources with 3.2 pulldown? What is the very best solution for 1080i output for NTSC 29.97?
PS: thanks, dobbs for this great program, when I get over paying for the new computer I will be sure to send another donation. I think I wore out the old one with BD_RB, LOL!
worknstiff is offline   Reply With Quote
Old 8th June 2011, 18:22   #12178  |  Link
omegaman7
omegaman7's Avatar
I didn't know it was possible to wear a computer out like that LOL! My 2001 HP is still kicking, and I worked it like a dog, with dvd shrink, dr. divx, etc.
omegaman7 is offline   Reply With Quote
Old 8th June 2011, 20:57   #12179  |  Link
jdobbs
You don't want to do IVTC on that source -- because the "**" indicates that it is hybrid. So BD-RB won't do IVTC unless you force it (see IVTC_SELECTION in HIDDENOPTS.TXT). Hybrid means that there are parts that use pulldown and other parts that are true interlaced. Normally for interlaced or hybrid sources I do no filtering and reencode it as interlaced. If, though, you plan to do much playback on a computer I would recommend you select "use DEINTERLACER". For a hybrid source I would also set DEINTERLACER_TYPE=3 in the INI file. That will tell BD-RB to use SmoothDeinterlace().
Old 8th June 2011, 22:05   #12180  |  Link
sandrino3867
[23:38:36] BD Rebuilder v0.38.03 (beta)
- Source: BEAN.1997.1080P.BLU-RAY.CEE.VC-1.DTS-HD.MA.5.1-RFW
- Input BD size: 29,06 GB
- Approximate total content: [02:02:24.670]
- Target BD size: 23,83 GB
- Windows Version: 5.1 [2600]
- Auto Quality: Good (Very Fast), ABR
[23:38:36] PHASE ONE, Encoding
- [23:38:36] Extracting A/V streams [VID_00011]
- [23:38:59] Reencoding: VID_00011 (1 of 3)
- [23:38:59] Collecting video information
- Source Video: MPEG-4 (AVC), 720x480
- Rate/Length: 29,970fps, 37.020 frames
- Bitrate: 6.400 Kbs
- [23:38:59] Reencoding: VID_00011, Pass 1 of 1
- [23:44:40] Video Encode complete
- [23:44:40] Reencoding audio tracks (if req'd)
- [23:44:40] Multiplexing M2TS
- [23:45:06] Extracting A/V streams [VID_50132]
- [23:45:09] Reencoding: VID_50132 (2 of 3)
- [23:45:09] Collecting video information
- Rate/Length: 29,970fps, 6.810 frames
- Bitrate: 4.049 Kbs
- [23:45:09] Reencoding: VID_50132, Pass 1 of 1
- [23:46:04] Video Encode complete
- [23:46:04] Reencoding audio tracks (if req'd)
- [23:46:04] Multiplexing M2TS
- [23:46:08] Extracting A/V streams [VID_50133]
- [23:54:49] Reencoding: VID_50133 (3 of 3)
- [23:54:49] Collecting video information
- Source Video: VC-1, 1920x1080
- Rate/Length: 23,976fps, 128.448 frames
- Bitrate: 28.142 Kbs
- [23:54:49] Reencoding: VID_50133, Pass 1 of 1
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.38.03 (beta)
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3326, Ok
[23:54:52] - Failed video encode, aborted
sandrino3867 is offline   Reply With Quote
