Old 20th January 2020, 18:04   #29201  |  Link
jdobbs
Originally Posted by videoh View Post
CUDA refers to the GPU multiprocessors (cores) and the infrastructure to utilize them. NVDec (previously called CUVID) and NVEnc are separate engines on the GPU that implement video decoding and encoding, respectively. CUDA is certainly not obsolete. And CUVID was not replaced, merely renamed.
Thanks for the clarification.
Website: www.jdobbs.net
Old 20th January 2020, 20:11   #29202  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by zamengo View Post
Encoding with cuda cores have a issues, the final result is a 2176p file, not 2160p.
References?
Old 20th January 2020, 21:11   #29203  |  Link
prologic
Originally Posted by MrVideo View Post
References?
I have done around 70% of all 4k uhd releases , using cuda ..
And everyone , still the same
3840 x 2160 pixels..
It takes around 15mins on my geforce gtx 1070 card , to make then fit on a BD50 ..I also use BD Rebuilder , to Alter the build of the disc as well , resulting in resizing a lot less .
prologic is offline   Reply With Quote
Old 20th January 2020, 23:41   #29204  |  Link
Sharc
…. My (still unresearched) plan was to use FFMPEG for NVENC encoding.
You may also want to take a look at rigaya's NVEncC. It is continually developed and well documented.
https://github.com/rigaya/NVEnc/releases
https://github.com/rigaya/NVEnc/blob..._Options.en.md
Old 21st January 2020, 01:38   #29205  |  Link
jdobbs
Thanks! This looks great.
Old 21st January 2020, 03:19   #29206  |  Link
MrVideo
MrVideo's Avatar
What program?
Old 21st January 2020, 03:51   #29207  |  Link
zamengo
References?
https://devtalk.nvidia.com/default/t...-of-3840x2176/
zamengo is offline   Reply With Quote
Old 21st January 2020, 07:32   #29208  |  Link
prologic
What program?
I use DVDFAB
Old 21st January 2020, 12:24   #29209  |  Link
zamengo
I use DVDFAB
Open playlist on tsmuxer, you will figure out 2176p.
This is incompatible with Xbox One S and X player.
Old 21st January 2020, 15:17   #29210  |  Link
MrVideo
MrVideo's Avatar
Based on the reference, it looks like 2176 is it, period. The hardware is only 32x32. Sounds like Xbox needs to get it right. It is the same issue with 1080. It is encoded to 1088 (16x16) and set to display at 1080.
Old 21st January 2020, 19:34   #29211  |  Link
LowDead
Elit Amans
Yes, tsmuxer reports 2176p, but mediainfo says 2160p... after reading the discussion at nvidia I would trust tsmuxer. BUT it's an old discussion and in the end they say the Turing (for those who don't know: GTX1660, 2060, 2070, 2080 etc...) cards have HW capabilities of 8x8 and 16x16. So off to buy a new gfx card then
Anyway, even though an dvdfab encode have 2176p, I believe they have gotten around the problem with green screen on the XB and also works flawlessly for most others. So what I'm saying, not to get too much OT, is that jdobbs can also fix these problems when/if they occur with bdrb.
//LD
LowDead is offline   Reply With Quote
Old 21st January 2020, 19:37   #29212  |  Link
cartman0208
I did my testing with Staxrip, which makes use of NVEncC.
cartman0208 is offline   Reply With Quote
Old 23rd January 2020, 16:00   #29213  |  Link
jdobbs
BD Rebuilder v0.61.05
I have updated the first post of this thread with a link to the most recent version of BD-RB (v0.61.05). Changes for this release:
- Corrected an issue that could result in
  blocky or distorted display during FF or
  REW on full backups.
- Fixed an issue in which an imported source
  (very rarely) might not have its frame rate
  detected by MEDIAINFO.
- Added an "*" to the "HEVC" callout of the
  stream display for sources that have HDR and
  "**" for those that also have Dolby Vision.
- Changed the setting for adjustment/scan of
  MKV during import.  Should have been off by
  default instead of on.
- Updated prediction routines for CRF encodes
  to more accurately predict UHD output when
  CRF is selected.  Still needs testing.
- Updated TSMUXER4K to a more recent nightly
  release.
- Other minor corrections and cosmetic fixes.
Old 23rd January 2020, 23:17   #29214  |  Link
FilipeAmadeuO
@jdobbs
The “Corrected an issue that could result in blocky or distorted display during FF or REW on full backups.”
was a TSmuxer ou BdRebuilder bug ?
Because with this last version the problem is fixed. And now UHD backup is perfect.
But before I had same issue using only Tsmuxer.
Now subtitles/audio in GUI replacement is what I miss
FilipeAmadeuO is offline   Reply With Quote
Old 27th January 2020, 13:49   #29215  |  Link
jdobbs
Originally Posted by FilipeAmadeuO View Post
@jdobbs
The one mentioned in the log was a BD Rebuilder bug. Not sure if there was another bug fixed in TSMUXER. If so, I wasn't aware of it.
Old 27th January 2020, 17:32   #29216  |  Link
Michi
BD-RB encodes 4K import without HDR in HDR. I tested this with a x264 4K mkv file.
Since 61.05 BD-RB uses higher bitrates than 35Mbit on UHD rebuilds. Is this normal?
For me this is a feature and not a bug.
Michi is offline   Reply With Quote
Old 27th January 2020, 19:01   #29217  |  Link
jdobbs
Yes. I originally left it at the maximum for a standard BD while I was testing it (to be safe). But, after some testing, I've now increased it since a UHD BD-25/50 has a higher maximum bitrate.
Just remember, though, that this is just the maximum bitrate (associated with peaks). The actual bitrate for VBR is typically much lower (unless the source is small enough that it reaches the maximum with the selected target).
Old 31st January 2020, 11:56   #29218  |  Link
Priapismic
Done.
Priapismic is offline   Reply With Quote
Old 31st January 2020, 20:34   #29219  |  Link
Michi
The crf encoded files are to big and the second pass crashed:
[01.31.20] BD Rebuilder v0.61.05
[14:14:12] Source:  DER_WILDE_PAZIFIK
  - Input BD size: 24,30 GB
  - Approximate total content: [00:56:24.305]
  - Target BD size: 8,01 GB
  - Windows Version: 6.2 [9200]
  - Quality: Highest (Very Slow), CRF
  - Decoding/Frame serving: FFMPEG
  - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[14:14:12] PHASE ONE, Encoding
 - [14:14:12] Processing: VID_00002 (1 of 3)
 - [14:14:12] Extracting A/V streams [VID_00002]
 - [14:14:19] Reencoding video [VID_00002]
   - Source Video: HEVC, 3840x2160
   - Rate/Length: 23,976fps, 888 frames
 - [14:14:19] Performing CRF Prediction...
   - Analyzing 20,70 30,95 32,15 31,55 31,25 31,10 31,03 31,06 31,08 31,07 31,07 31,07 31,07 31,07 31,07 31,07 31,07 31,07 31,07 31,07 [31,07]
 - [14:17:41] Encoding using constant rate factor.
 - [14:20:15] Video Encode complete
 - [14:20:15] Processing audio tracks
   - Track 4352 (deu): Keeping original audio
 - [14:20:15] Multiplexing M2TS
 - [14:20:19] Processing: VID_00003 (2 of 3)
 - [14:20:19] Extracting A/V streams [VID_00003]
 - [14:24:17] Reencoding video [VID_00003]
   - Rate/Length: 23,976fps, 75.083 frames
 - [14:24:17] Performing CRF Prediction...
   - Analyzing 20,70 22,70 21,70 21,20 20,95 20,83 20,76 20,73 20,72 20,72 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 [20,73]
 - [15:26:16] Encoding using constant rate factor.
   - Performing size-correcting second pass...
[20:19:03] - Failed video encode, aborted
Old 31st January 2020, 23:22   #29220  |  Link
jdobbs
Wow. I'm really confused as to how it could get caught using the same CRF value that many times during prediction??? I'll look at it.
Can you post your REBUILDER.INI file?
