Old 27th June 2017, 18:28   #201  |  Link
nalor
Originally Posted by markfilipak View Post
Unfortunately, that's not true.
I'm in the U.S. I can't run DVDFab. All it says is "Sorry, the current disc is protected by AACS." So I have no choice other than to get the VUK manually. Now, I can run MakeMKV -- see the attachment. The MakeMKV log contains the 'discid' (=0xF76764136A8AFD3A999FF1299D4B6044FE90483A), and I find it in the dump of 'makemkvcon64.exe', but where's the VUK? Does anything "few bytes later" look like a VUK to you? How about "few bytes" before? You see, I don't know what I'm looking for other than it is 16 bytes (and it probably isn't populated with a bunch of zeros).
Would you like to take a look at 'makemkvcon64.DMP' to maybe get lucky? It's 578 M-bytes.
I'd really like to support AACS Updater, but this obstacle is pretty much a show stopper.
Regards,
Mark.
Why isn't it possible to run DVDfab in the US? Never thought that it might be a problem... (at least not a technical one).
And the only way to find out if there's something useable in the makemkv dump is by using a disc where you already know the vuk and so you know what you're looking for.
When I initially tried all bluray applications I found on the internet the only one that keeps the vuk easily readable in memory has been DVDfab - but things might have changed in the meantime.
In case DVDfab is really not useable for you I don't know how I could help you...
nalor is offline   Reply With Quote
Old 27th June 2017, 18:59   #202  |  Link
candela
There is no VUK in MakeMKV dumps, don't waste your time. Try using a proxy for DVDFab
candela is offline   Reply With Quote
Old 27th June 2017, 22:48   #203  |  Link
spotter
I run DVDFab in the US all the time without a problem and without any special tricks.
spotter is offline   Reply With Quote
Old 30th June 2017, 23:59   #204  |  Link
Jdogzz
FindVUK Dump Error
Below is the log for my attempt to get a VUK. It has been working all morning up until this disc.
2017-06-30 15:49:01 # 152252 #  ----------- FindVUK 1.02 -----------
2017-06-30 15:49:01 # 152258 # Operating System: Windows 10
2017-06-30 15:49:01 # 152289 # SettingsFile: >C:\Users\myusername\Downloads\FindVUK_1.02\config\FindVUK.ini<
2017-06-30 15:49:01 # 152309 # Current BufferSize 80 x 300 - ScreenSize 80 x 25
2017-06-30 15:49:01 # 152314 # Requested BufferSize 120 x 300 - ScreenSize 120 x 50
2017-06-30 15:49:01 # 152319 # Max. ScreenSize 240 x 88
2017-06-30 15:49:01 # 152324 # Final New Values - BufferSize 120 x 300 - ScreenSize 120 x 50 - Resize >1<
2017-06-30 15:49:01 # 152328 # M1 - New BufferSize 120 x 300
2017-06-30 15:49:01 # 152333 # Mx2 - New ScreenSize 120 x 50
2017-06-30 15:49:01 # 152347 # Couldn't read PasskeyLogDir from registry - take the info from the ini file
2017-06-30 15:49:01 # 152353 # Information! MediaPlayer MainApp is not valid! ><
2017-06-30 15:49:01 # 152359 # Information! DVDfab MainApp is not valid! ><
2017-06-30 15:49:01 # 152380 # Passkey is preferred and available!
2017-06-30 15:49:01 # 152386 # Passkey-MainFile:     >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2017-06-30 15:49:01 # 152391 # Passkey-LogFile:      >C:\Users\myusername\Documents\DVDFab Passkey\Log\passkey_internal.log<
2017-06-30 15:49:01 # 152396 # KEYDB-Path:           >C:\Users\myusername\AppData\Roaming\aacs\<
2017-06-30 15:49:01 # 152402 # KEYDB-Backup-Path:    >C:\Users\myusername\Downloads\FindVUK_1.02\VUKbackup\<
2017-06-30 15:49:01 # 152408 # ProcDumpFile:         >C:\Users\myusername\Downloads\FindVUK_1.02\tool\procdump.exe<
2017-06-30 15:49:01 # 152414 #  --- PART 1 --- GET VUK ---
2017-06-30 15:49:01 # 152425 # Please make sure Passkey is enabled!
2017-06-30 15:49:03 # 154657 # Untested DVDfab App Version found >9.2.0.6<
2017-06-30 15:49:03 # 154662 # Value set in ini file will be used for 'Folder2DiscID'
2017-06-30 15:49:03 # 154667 # Value set in ini file will be used for 'Folder2VUK'
2017-06-30 15:49:03 # 154672 # Offset Folder2DiscId >0x114< - Folder2Vuk >0x173<
2017-06-30 15:49:25 # 177164 # #############################################################################
2017-06-30 15:49:25 # 177172 #  ----------- FindVUK 1.02 -----------
2017-06-30 15:49:25 # 177179 # Operating System: Windows 10
2017-06-30 15:49:25 # 177184 # SettingsFile: >C:\Users\myusername\Downloads\FindVUK_1.02\config\FindVUK.ini<
2017-06-30 15:49:25 # 177196 # Current BufferSize 80 x 300 - ScreenSize 80 x 25
2017-06-30 15:49:25 # 177201 # Requested BufferSize 120 x 300 - ScreenSize 120 x 50
2017-06-30 15:49:25 # 177206 # Max. ScreenSize 240 x 88
2017-06-30 15:49:25 # 177210 # Final New Values - BufferSize 120 x 300 - ScreenSize 120 x 50 - Resize >1<
2017-06-30 15:49:25 # 177215 # M1 - New BufferSize 120 x 300
2017-06-30 15:49:25 # 177221 # Mx2 - New ScreenSize 120 x 50
2017-06-30 15:49:25 # 177234 # Couldn't read PasskeyLogDir from registry - take the info from the ini file
2017-06-30 15:49:25 # 177241 # Information! MediaPlayer MainApp is not valid! ><
2017-06-30 15:49:26 # 177247 # Information! DVDfab MainApp is not valid! ><
2017-06-30 15:49:26 # 177264 # Passkey is preferred and available!
2017-06-30 15:49:26 # 177269 # Passkey-MainFile:     >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2017-06-30 15:49:26 # 177274 # Passkey-LogFile:      >C:\Users\myusername\Documents\DVDFab Passkey\Log\passkey_internal.log<
2017-06-30 15:49:26 # 177280 # KEYDB-Path:           >C:\Users\myusername\AppData\Roaming\aacs\<
2017-06-30 15:49:26 # 177285 # KEYDB-Backup-Path:    >C:\Users\myusername\Downloads\FindVUK_1.02\VUKbackup\<
2017-06-30 15:49:26 # 177291 # ProcDumpFile:         >C:\Users\myusername\Downloads\FindVUK_1.02\tool\procdump.exe<
2017-06-30 15:49:26 # 177297 #  --- PART 1 --- GET VUK ---
2017-06-30 15:49:26 # 177308 # No running application process discovered
2017-06-30 15:49:26 # 177313 #  >> Start it now >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2017-06-30 15:49:28 # 180208 # Untested DVDfab App Version found >9.2.0.6<
2017-06-30 15:49:28 # 180213 # Value set in ini file will be used for 'Folder2DiscID'
2017-06-30 15:49:28 # 180218 # Value set in ini file will be used for 'Folder2VUK'
2017-06-30 15:49:28 # 180223 # Offset Folder2DiscId >0x114< - Folder2Vuk >0x173<
2017-06-30 15:49:33 # 184803 # Drive opened
2017-06-30 15:49:33 # 184809 # DiscType detected >Blu-ray BDMV<
2017-06-30 15:49:33 # 184816 # Volume Label detected >AMAZING_SPIDERMAN<
2017-06-30 15:49:33 # 184822 # DriveLetter detected >D<
2017-06-30 15:49:34 # 185536 # Detected CopyProtections AACS >1< BD+ >0<
2017-06-30 15:49:42 # 193631 # DiscID found >BEF7D426F926398B33D1BF7E7F5181061B8B3374<
2017-06-30 15:49:43 # 194751 # Passkey got VUK - create memdump now!
2017-06-30 15:49:44 # 195501 #  DUMP >>>
2017-06-30 15:49:44 # 195509 #  DUMP >>> ProcDump v9.0 - Sysinternals process dump utility
2017-06-30 15:49:44 # 195515 #  DUMP >>> Copyright (C) 2009-2017 Mark Russinovich and Andrew Richards
2017-06-30 15:49:44 # 195521 #  DUMP >>> Sysinternals - www.sysinternals.com
2017-06-30 15:49:44 # 195528 #  DUMP >>>
2017-06-30 15:49:44 # 195535 #  DUMP >>> [15:49:44] Dump 1 initiated: C:\Users\myusername\Downloads\FindVUK_1.02\dump\BEF7D426F926398B33D1BF7E7F5181061B8B3374_AMAZING_S7412ERMAN.dmp
2017-06-30 15:49:44 # 196147 #  DUMP >>> [15:49:44] Dump 1 writing: Estimated dump file size is 122 MB.
2017-06-30 15:49:49 # 200296 #  DUMP >>> [15:49:49] Dump 1 complete: 122 MB written in 4.8 seconds
2017-06-30 15:49:49 # 200604 #  DUMP >>> [15:49:49] Waiting for dump to complete...
2017-06-30 15:49:49 # 200812 #  DUMP >>> [15:49:49] Dump count reached.
2017-06-30 15:49:49 # 200817 #  DUMP >>>
2017-06-30 15:49:49 # 200923 # ERROR!! Dumpsize invalid >-1< - Exitcode >1< - Dump failed! - Program >C:\Users\myusername\Downloads\FindVUK_1.02\tool\procdump.exe< Parameter > -ma -o DVDFabPasskey.exe "C:\Users\myusername\Downloads\FindVUK_1.02\dump\BEF7D426F926398B33D1BF7E7F5181061B8B3374_AMAZING_SPIDERMAN.dmp"<
2017-06-30 15:49:49 # 200929 # Error during process memory dump - please report in the doom9 forum!
2017-06-30 15:49:49 # 200936 # ERROR! Couldn't create memory dump! Exit application!
2017-06-30 15:49:49 # 200948 # CloseAtTheEnd is active, close Passkey now
Jdogzz is offline   Reply With Quote
Old 1st July 2017, 00:16   #205  |  Link
Jdogzz
FindVUK Dump Error
Two more dump errors:
2017-06-30 16:08:38 # 1330339 #  ----------- FindVUK 1.02 -----------
2017-06-30 16:08:38 # 1330346 # Operating System: Windows 10
2017-06-30 16:08:38 # 1330351 # SettingsFile: >C:\Users\myusername\Downloads\FindVUK_1.02\config\FindVUK.ini<
2017-06-30 16:08:38 # 1330366 # Current BufferSize 80 x 300 - ScreenSize 80 x 25
2017-06-30 16:08:38 # 1330372 # Requested BufferSize 120 x 300 - ScreenSize 120 x 50
2017-06-30 16:08:38 # 1330378 # Max. ScreenSize 240 x 88
2017-06-30 16:08:38 # 1330385 # Final New Values - BufferSize 120 x 300 - ScreenSize 120 x 50 - Resize >1<
2017-06-30 16:08:38 # 1330392 # M1 - New BufferSize 120 x 300
2017-06-30 16:08:38 # 1330398 # Mx2 - New ScreenSize 120 x 50
2017-06-30 16:08:38 # 1330433 # Couldn't read PasskeyLogDir from registry - take the info from the ini file
2017-06-30 16:08:38 # 1330444 # Information! MediaPlayer MainApp is not valid! ><
2017-06-30 16:08:38 # 1330452 # Information! DVDfab MainApp is not valid! ><
2017-06-30 16:08:38 # 1330458 # Passkey is preferred and available!
2017-06-30 16:08:38 # 1330463 # Passkey-MainFile:     >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2017-06-30 16:08:38 # 1330468 # Passkey-LogFile:      >C:\Users\myusername\Documents\DVDFab Passkey\Log\passkey_internal.log<
2017-06-30 16:08:38 # 1330473 # KEYDB-Path:           >C:\Users\myusername\AppData\Roaming\aacs\<
2017-06-30 16:08:38 # 1330478 # KEYDB-Backup-Path:    >C:\Users\myusername\Downloads\FindVUK_1.02\VUKbackup\<
2017-06-30 16:08:38 # 1330483 # ProcDumpFile:         >C:\Users\myusername\Downloads\FindVUK_1.02\tool\procdump.exe<
2017-06-30 16:08:38 # 1330489 #  --- PART 1 --- GET VUK ---
2017-06-30 16:08:38 # 1330499 # No running application process discovered
2017-06-30 16:08:38 # 1330504 #  >> Start it now >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2017-06-30 16:08:41 # 1332839 # Untested DVDfab App Version found >9.2.0.6<
2017-06-30 16:08:41 # 1332845 # Value set in ini file will be used for 'Folder2DiscID'
2017-06-30 16:08:41 # 1332851 # Value set in ini file will be used for 'Folder2VUK'
2017-06-30 16:08:41 # 1332857 # Offset Folder2DiscId >0x114< - Folder2Vuk >0x173<
2017-06-30 16:08:49 # 1341557 # Drive opened
2017-06-30 16:08:49 # 1341566 # DiscType detected >Blu-ray BDMV<
2017-06-30 16:08:49 # 1341575 # Volume Label detected >The Amazing Spider-Man<
2017-06-30 16:08:51 # 1343402 # DriveLetter detected >D<
2017-06-30 16:08:53 # 1345631 # Detected CopyProtections AACS >1< BD+ >0<
2017-06-30 16:09:10 # 1362111 # DiscID found >C4D07F0A46D53D68C4F450E71F939921AC852536<
2017-06-30 16:09:11 # 1363533 # Passkey got VUK - create memdump now!
2017-06-30 16:09:11 # 1363640 #  DUMP >>>
2017-06-30 16:09:11 # 1363646 #  DUMP >>> ProcDump v9.0 - Sysinternals process dump utility
2017-06-30 16:09:11 # 1363653 #  DUMP >>> Copyright (C) 2009-2017 Mark Russinovich and Andrew Richards
2017-06-30 16:09:11 # 1363658 #  DUMP >>> Sysinternals - www.sysinternals.com
2017-06-30 16:09:11 # 1363664 #  DUMP >>>
2017-06-30 16:09:11 # 1363670 #  DUMP >>> [16:09:11] Dump 1 initiated: C:\Users\myusername\Downloads\FindVUK_1.02\dump\C4D07F0A46D53D68C4F450E71F939921AC852536_The_Amazing_S5508er-Man.dmp
2017-06-30 16:09:11 # 1363676 #  DUMP >>> [16:09:11] Dump 1 writing: Estimated dump file size is 126 MB.
2017-06-30 16:09:12 # 1363884 #  DUMP >>> [16:09:12] Dump 1 complete: 126 MB written in 0.2 seconds
2017-06-30 16:09:12 # 1364093 #  DUMP >>> [16:09:12] Dump count reached.
2017-06-30 16:09:12 # 1364099 #  DUMP >>>
2017-06-30 16:09:12 # 1364107 # ERROR!! Dumpsize invalid >-1< - Exitcode >1< - Dump failed! - Program >C:\Users\myusername\Downloads\FindVUK_1.02\tool\procdump.exe< Parameter > -ma -o DVDFabPasskey.exe "C:\Users\myusername\Downloads\FindVUK_1.02\dump\C4D07F0A46D53D68C4F450E71F939921AC852536_The_Amazing_Spider-Man.dmp"<
2017-06-30 16:09:12 # 1364114 # Error during process memory dump - please report in the doom9 forum!
2017-06-30 16:09:12 # 1364122 # ERROR! Couldn't create memory dump! Exit application!
2017-06-30 16:09:12 # 1364135 # CloseAtTheEnd is active, close Passkey now
2017-06-30 16:10:13 # 1425165 # #############################################################################
2017-06-30 16:10:13 # 1425173 #  ----------- FindVUK 1.02 -----------
2017-06-30 16:10:13 # 1425180 # Operating System: Windows 10
2017-06-30 16:10:13 # 1425186 # SettingsFile: >C:\Users\myusername\Downloads\FindVUK_1.02\config\FindVUK.ini<
2017-06-30 16:10:13 # 1425198 # Current BufferSize 80 x 300 - ScreenSize 80 x 25
2017-06-30 16:10:13 # 1425203 # Requested BufferSize 120 x 300 - ScreenSize 120 x 50
2017-06-30 16:10:13 # 1425207 # Max. ScreenSize 240 x 88
2017-06-30 16:10:13 # 1425213 # Final New Values - BufferSize 120 x 300 - ScreenSize 120 x 50 - Resize >1<
2017-06-30 16:10:13 # 1425217 # M1 - New BufferSize 120 x 300
2017-06-30 16:10:13 # 1425222 # Mx2 - New ScreenSize 120 x 50
2017-06-30 16:10:13 # 1425236 # Couldn't read PasskeyLogDir from registry - take the info from the ini file
2017-06-30 16:10:13 # 1425243 # Information! MediaPlayer MainApp is not valid! ><
2017-06-30 16:10:13 # 1425250 # Information! DVDfab MainApp is not valid! ><
2017-06-30 16:10:13 # 1425264 # Passkey is preferred and available!
2017-06-30 16:10:13 # 1425269 # Passkey-MainFile:     >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2017-06-30 16:10:13 # 1425275 # Passkey-LogFile:      >C:\Users\myusername\Documents\DVDFab Passkey\Log\passkey_internal.log<
2017-06-30 16:10:13 # 1425280 # KEYDB-Path:           >C:\Users\myusername\AppData\Roaming\aacs\<
2017-06-30 16:10:13 # 1425285 # KEYDB-Backup-Path:    >C:\Users\myusername\Downloads\FindVUK_1.02\VUKbackup\<
2017-06-30 16:10:13 # 1425291 # ProcDumpFile:         >C:\Users\myusername\Downloads\FindVUK_1.02\tool\procdump.exe<
2017-06-30 16:10:13 # 1425297 #  --- PART 1 --- GET VUK ---
2017-06-30 16:10:13 # 1425306 # No running application process discovered
2017-06-30 16:10:13 # 1425312 #  >> Start it now >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2017-06-30 16:10:16 # 1427918 # Untested DVDfab App Version found >9.2.0.6<
2017-06-30 16:10:16 # 1427924 # Value set in ini file will be used for 'Folder2DiscID'
2017-06-30 16:10:16 # 1427929 # Value set in ini file will be used for 'Folder2VUK'
2017-06-30 16:10:16 # 1427933 # Offset Folder2DiscId >0x114< - Folder2Vuk >0x173<
2017-06-30 16:10:50 # 1461995 # Drive opened
2017-06-30 16:10:50 # 1462002 # DiscType detected >Blu-ray BDMV<
2017-06-30 16:10:50 # 1462010 # Volume Label detected >The Amazing Spider-Man 2<
2017-06-30 16:10:50 # 1462119 # DriveLetter detected >D<
2017-06-30 16:10:51 # 1463538 # Detected CopyProtections AACS >1< BD+ >0<
2017-06-30 16:10:57 # 1469694 # DiscID found >DE3D6C9EF713E0507924DB9C35F0BF7EA258E958<
2017-06-30 16:10:59 # 1470915 # Passkey got VUK - create memdump now!
2017-06-30 16:10:59 # 1471022 #  DUMP >>>
2017-06-30 16:10:59 # 1471028 #  DUMP >>> ProcDump v9.0 - Sysinternals process dump utility
2017-06-30 16:10:59 # 1471034 #  DUMP >>> Copyright (C) 2009-2017 Mark Russinovich and Andrew Richards
2017-06-30 16:10:59 # 1471040 #  DUMP >>> Sysinternals - www.sysinternals.com
2017-06-30 16:10:59 # 1471047 #  DUMP >>>
2017-06-30 16:10:59 # 1471053 #  DUMP >>> [16:10:59] Dump 1 initiated: C:\Users\myusername\Downloads\FindVUK_1.02\dump\DE3D6C9EF713E0507924DB9C35F0BF7EA258E958_The_Amazing_S7844er-Man_2.dmp
2017-06-30 16:10:59 # 1471059 #  DUMP >>> [16:10:59] Dump 1 writing: Estimated dump file size is 123 MB.
2017-06-30 16:10:59 # 1471165 #  DUMP >>> [16:10:59] Dump 1 complete: 123 MB written in 0.2 seconds
2017-06-30 16:10:59 # 1471475 #  DUMP >>> [16:10:59] Dump count reached.
2017-06-30 16:10:59 # 1471480 #  DUMP >>>
2017-06-30 16:10:59 # 1471486 # ERROR!! Dumpsize invalid >-1< - Exitcode >1< - Dump failed! - Program >C:\Users\myusername\Downloads\FindVUK_1.02\tool\procdump.exe< Parameter > -ma -o DVDFabPasskey.exe "C:\Users\myusername\Downloads\FindVUK_1.02\dump\DE3D6C9EF713E0507924DB9C35F0BF7EA258E958_The_Amazing_Spider-Man_2.dmp"<
2017-06-30 16:10:59 # 1471491 # Error during process memory dump - please report in the doom9 forum!
2017-06-30 16:10:59 # 1471497 # ERROR! Couldn't create memory dump! Exit application!
2017-06-30 16:10:59 # 1471507 # CloseAtTheEnd is active, close Passkey now
Old 1st July 2017, 15:25   #206  |  Link
Jdogzz
Dumps Produced
My apologies, I read through some of the earlier replies and saw you need the dumps produced as well. Here is a folder on Mediafire for the dumps (there are some duplicates for the first error I reported) :
https://www.mediafire.com/folder/ciy...t/Failed_Dumps
Old 1st July 2017, 15:35   #207  |  Link
nalor
This is funny - FindVUK is stumbling across a new feature in procdump since release 8.2:
ProcDump Webpage
Filename:
Default dump filename: PROCESSNAME_YYMMDD_HHMMSS.dmp
The following substitutions are supported:
PROCESSNAME Process Name
PID Process ID
EXCEPTIONCODE Exception Code
HHMMSS Hour/Minute/Second
so whenever there's PID (like in sPIDerman) in the dump filename it get's replaced by the process-id of the process that is dumped ...
I cannot find a parameter to disable this behaviour, so I'll simply replace all 'pid' with 'pi_d' or something like this in the next release of FindVUK.
Short term solution: download an older release of procdump (a release before 8.2 - e.g. 8.0 is a good one)
Old 1st July 2017, 15:36   #208  |  Link
nalor
In this case it's not necessary - I noticed the weird filename used by procdump when I first read your post, but I've been clueless until I tried myself to create a dump with destination filename 'spiderman' and noticed that I can reproduce your problem quite easily
Old 2nd July 2017, 15:02   #209  |  Link
Jdogzz
Older ProcDump Version Works
@nalor: Your suggestion for using an older procdump executable worked, thanks!
PS: For anyone else having this problem (looks like @wuemura might have: https://forum.doom9.org/showthread.p...82#post1809782 ), it appears that MS, in their infinite wisdom because new versions of their products definitely will never lead to bugs, does not host old versions of their tools. I found a copy of version 8.0 on Internet Archive here: https://web.archive.org/web/20160708...s/Procdump.zip .
Old 13th July 2017, 22:04   #210  |  Link
LM2005
You are talking about a big organization, they are born sick.
However there is a Power tool called procdump v9.0, would that work. It was started by Mark Russinovich, who seemed to be a competent man.
https://technet.microsoft.com/en-us/.../dd996900.aspx I once used their forum and people there were helpfull.
LM2005 is offline   Reply With Quote
Old 22nd August 2017, 00:26   #211  |  Link
xplt
Hi nalor!
I think, I encountered a bug in FindVUK: a few days ago I re-installed Windows on a machine which I use to extract keys and I created a user with Cyrillic name (so, path to user files has both Latin and Cyrillic characters). And for some reason, FindVUK doesn't like Cyrillic for "DVDfab-LogFile" (and other files) while it is able to decode it for "KEYDB-Path". See the attached log.
xplt is offline   Reply With Quote
Old 22nd August 2017, 19:28   #212  |  Link
nalor
Please upload the logfile e.g. to tinyupload or paste it on pastebin.com
alternatively post the path incl. the cyrillic name here
thanks!
Old 23rd August 2017, 09:17   #213  |  Link
xplt
thanks!
Uploaded on pastebin.
Old 23rd August 2017, 10:09   #214  |  Link
nalor
Interesting, will try it tonight with your username.
Gesendet von meinem E5823 mit Tapatalk
Old 31st August 2017, 22:52   #215  |  Link
ErichV
Hi nalor,
Could you please add support for DVDFab Media Player 3.1.0.2 in the next FindVUK release?
Thank you very much for all your efforts! :-)
ErichV is offline   Reply With Quote
Old 1st September 2017, 21:04   #216  |  Link
nalor
Took a little bit longer than expected, but I've tried it with your username now and unfortunately it's not the fault of FindVUK.
The main problem is that DVDfab does not handle the special username properly and fails to write to it's default directory in the 'documents' folder inside the user directory >> in my case it created the logfile directly in the 'C:\Users' folder and as usually only the admin is allowed to write to this folder, I have to start DVDfab with admin rights to get it running.
You can specify the logpath in the ini file of FindVUK - so in my case I've changed it to 'C:\Users\DVDFab10\Log\dvdfab_internal.log' and it worked even with your username (but note that I had to start FindVUK also with admin-rights so it can start DVDfab with admin rights.. )
Finally it's working - but I don't think it's a good solution, better to use an easier username
Old 1st September 2017, 21:05   #217  |  Link
nalor
Originally Posted by ErichV View Post
Hi nalor,
Already implemented it a while ago - but as nobody complained I resigned to release it.
Will try to create a new release this weekend.
Old 2nd September 2017, 14:36   #218  |  Link
ErichV
Awesome, thanks a lot.
Old 3rd September 2017, 11:52   #219  |  Link
nalor
I'm sorry but I will not make it this weekend.
There's one new feature I'd like to finish before releasing a new version:
I'd like to create an alternative to Starbucks AACS-Database that is able to store all information we can get from the dumps and also is available more or less immediatly after upload.
But I'm still in the early stages of this project.. and don't think I can finish it today.
And another bad news: I noticed that beginning with Passkey 9.2.1.2 and DVDfab 10.0.4.9 the VUK is now encrypted in memory - so for the moment please use older releases to get valid VUKs.
(but there won't be solution for this in the next release as I don't know how to decrypt the VUK in the new releases ... )
But I'll add an error message in the next release telling you that the new releases are not supported any longer
Old 3rd September 2017, 19:07   #220  |  Link
m4tthi4s
Do you have more information? How did you find out that it is encrypted?
m4tthi4s is offline   Reply With Quote
