Old 3rd May 2011, 14:23   #2381  |  Link
SamuriHL
SamuriHL's Avatar
ROFLMAO! Thanks, Nev.
Old 3rd May 2011, 14:25   #2382  |  Link
CruNcher
CruNcher's Avatar
If the implementation of ffmpegs parser core continues @ this pace in no time MPC-HCs own core could be replaced and hopefully all MPC-HC splitter devs move on to improve lav splitter then abandoning the old native ones if someone like the potplayer guy would join in and provide his skining expertise (instead of doing his own thing) and a designer like jinsk8r his interface ideas jesus and ofcourse madshis renderer with DXVA support on top and Jans Shader work somehow combining those would also be awesome currently they contradict EVR vs Madshi (efficient Realtime enhancement)
It is about Time
Old 3rd May 2011, 14:26   #2383  |  Link
madshi
I suppose considering the short break i took in between, it really did only take one hour. Oh well, new feature!
Old 3rd May 2011, 14:30   #2384  |  Link
Sven75
This is my first post here, but I have been following this thread for some time now and I must say that I am very impressed by the progress that has been made and very thankful for this great piece of software!
Anyway, I have quite a few issues and questions but I will start with this clip here:
http://www.mediafire.com/?9p628p3yx7b3a6o
It is a very short Canopus DVC-Pro HD (CDVH) file (just as an example).
So far I have only found this specific DSFilter which can playback the clip:
http://www.mediafire.com/?bv82gz7n9754dz9
Right now, when using LAVSplitter it crashes Graphstudio, PowerPoint, etc. Current ffPlay is semi working and at least does not crash. Using the simple AVISplitter from quartz.dll it works as expected.
Nev, maybe you can have a look and maybe there is something you can do about it. Would be very much appreciated!
I know it is a fairly old format and not very common but as I am working in the medical congress field I get such old formats all the time and have to deal with it (in PowerPoint btw and without time to simply convert them to a different format).
FYI, I am on Win7 64 Bit and unfortunately I have to use the standard audio/video renderers as otherwise PowerPoint will have even more problems with playing videos.
Sven75 is offline   Reply With Quote
Old 3rd May 2011, 15:52   #2385  |  Link
nevcairiel
I fixed the crash with that DV video sample, thanks for reporting!
If you encountered any other bugs, just let me know.
Old 3rd May 2011, 16:04   #2386  |  Link
Sven75
Great - thanks a lot! I will glady report the other issues I find. One problem is though that a lot of the issues only occur in PowerPoint (especially 2010 is very picky) while Graphstudio and other players work flawlessly. This may or may not be PowerPoint's fault - but if it is, I can at least try to officially report a bug to MS.
Do you happen to have PowerPoint or the free viewer on one of your computers?
Old 3rd May 2011, 16:05   #2387  |  Link
nevcairiel
I have PowerPoint, but only 2007.
Old 3rd May 2011, 16:44   #2388  |  Link
jidelite
nevcairiel, like so many other I've been following your LAV filter work and wanted to say thank you! I was testing the LAV Audio bitstream capabilities with my GTS450 and my AVR says everything works as reported by others. I did have a question regarding the audio information supplied by LAV Splitter and Audio - when I play a 7.1 DTS-HD movie with MPC-HC (i.e. Tron Legacy) the Splitter says its a 5.1 movie (and the Kb/s are off) and the LAV AUDIO status tab says the number of channels is 6.
Is this the same kind of anomaly we get with ffdshow (I think I read your bitstreaming code is basically the same)?
jidelite
jidelite is offline   Reply With Quote
Old 3rd May 2011, 16:45   #2389  |  Link
nevcairiel
My bitstream code has nothing in common with ffdshow.
Anyhow, its currently not possible to figure out what exactly is in the DTS-HD frames, so it'll be limited to showing 6 channels. Not to worry, however, that does not influence bitstreaming at all!
Old 3rd May 2011, 16:48   #2390  |  Link
SamuriHL
SamuriHL's Avatar
Right, no one can parse the DTS-HD MA information, so, the information displayed isn't accurate.
Old 3rd May 2011, 16:52   #2391  |  Link
jidelite
Cool, Thanks guys !
jidleite
Old 3rd May 2011, 17:21   #2392  |  Link
CruNcher
CruNcher's Avatar
nev do you know if the libav/ffmpeg latm decoder supports error resilience ?
It is about Time
Old 3rd May 2011, 17:23   #2393  |  Link
madshi
Not true. eac3to can parse DTS-HD frames just fine. You can check out the BDInfo source code which was written based on information I provided. It's not as complete as what eac3to is doing, but it's good enough to extract the key information from DTS-HD streams.
Old 3rd May 2011, 17:28   #2394  |  Link
nevcairiel
I didn't mean it was "impossible" in general, just not with the tools i use, that is ffmpeg.
Its not like i really care, i just let ffmpeg figure out whats in there, and show what it tells me. The information is not crucial - a decoder capable of DTS-HD will figure it out from the bitstream, and bitstreaming does not pass that information anyway.
I don't feel like writing a parser for DTS-HD just for a display issue...
Old 3rd May 2011, 17:29   #2395  |  Link
n3w813
I'm having a weird issue with bitstreaming....
When I first play a video with DTS-MA, it bitstreams fine to my AVR. Right after when I try to play a video with just regular DTS, it tries to bitstream it as a DTS-MA track to my AVR (shows DTS Master Audio on the unit instead of DTS) and no sound comes out.
Can anyone else confirm this issue?
Thanks
n3w813 is offline   Reply With Quote
Old 3rd May 2011, 17:33   #2396  |  Link
nevcairiel
You have a stupid AVR then.
What i do when DTS-HD is activated, i pack every DTS into the DTS-HD wrapper (which is perfectly valid). This is even required for some sorts of DTS-ES, which would otherwise be lost, and just parsed as normal DTS - like it happens with ffdshow.
There are many types of DTS, and all are allowed to be wrapped into a DTS Type 4 (DTS-HD) package for HDMI transmission.
What happens if you play something else in between?
Old 3rd May 2011, 17:38   #2397  |  Link
CruNcher
CruNcher's Avatar
No audio http://www.mediafire.com/?1a9t7bnijxya48q
With cyb*** audio demuxer their is 8 seconds audio @ the end
PS: Lav Splitter + DivX AAC (Rovi/Mainconcept) works
It is about Time
Old 3rd May 2011, 17:41   #2398  |  Link
n3w813
Not sure, when I get home tonight, I'll try playing a DD track in between and see what happens.
My AVR is a Harman Kardon AVR254, shouldn't be that dumb right? I'll check to see if they have any firmware updates for the unit.
Old 3rd May 2011, 17:45   #2399  |  Link
nevcairiel
Just to make sure, with DTS-HD unchecked, it worked, right?
Which audio renderer are you using? If you're not using it already, try with ReClock - if you are, try without.
Also, NVIDIA or AMD? Which driver?
If all else fails, i can add some simple detection if there are HD frames in the stream, and if not fallback to "normal" DTS - and make that optional for people where its required.
Old 3rd May 2011, 18:11   #2400  |  Link
nevcairiel
@CruNcher:
You test all the weird MPEG-TS files - do you still have some H264 files that do NOT work when "Video Stream Parsing" is OFF?
