26th September 2012, 12:20 | #14181 | Link |
Software Developer
Madshi:
I believe (not sure) that most (all?) of the MadVR freezes when switching to a next track or when closing a player was due to FSE being active while terminating D3D. As you know, I wrote a work-around for this issue by instructing MadVR to exit FSE before I cleared the graph. The question is, do you really need to wait until D3D is fully cleared as you do in 0.83.x or is exiting FSE enough to maintain the same level of stability... If just existing FSE is enough, you may want to consider returning to the 0.82.5 exit function as it was much faster. If you don't feel comfortable with that, I'm sure some users would appreciate a 'Fast D3D Close' checkbox. 'dwTaskbarThumbnails 331 +7 TdwTaskbarThumbnails.DoUpdate' is updating the windows taskbar thumbnail buttons (the buttons that appear under the task bar thumbnail). I have no idea why it would trigger on a refresh rate change, I don't specifically call it in my code as far as I can tell... I only create the icons once and only update their image index depending on events such as play/pause and mute on/off. |
26th September 2012, 13:35 | #14183 | Link | ||
Kid for Today
Take a look at what the coder of foobar2000 tells to his users: http://www.hydrogenaudio.org/forums/...dpost&p=427970 Quote:
Haali is the same, he only cares about bug reports when BetaBoy shows the green. It's taking 250ms to close now, big deal Last edited by leeperry; 26th September 2012 at 13:40. |
26th September 2012, 14:36 | #14184 | Link | |||
26th September 2012, 14:37 | #14185 | Link |
madVR v0.82.5 released
http://madshi.net/madVR.zip Code:
* fixed: starting in exclusive mode, then switching to Overlay -> error * modified exclusive mode seekbar design slightly * madVR doesn't wait for full direct3d finalization, anymore * improved crash reporting reliability |
26th September 2012, 15:22 | #14186 | Link | |
Broadband Junkie
26th September 2012, 16:42 | #14187 | Link |
Black screen in FSE !
Madshi,
After disabling Aero when in full screen (checkbox checked), I ended up with a complete black screen when in FSE, while the sound kept playing. I if switched out off FSE, I got images again and they were "in sync" with the sound. So, - in overlay (windowed + full-screen) : image + sound OK - in FSE : black screen + sound kept playing. I didn't see any error messages (behind FSE ??). This bug was also there in 0.82.4. Here is the DEBUG LOG : http://www.mediafire.com/?npc9yieiv6d8u93 Update: It seems I can easily reproduce this. Even after complete quit and restarting the player, the problem is still there. Images in FSE can be restored by unchecking the "disable Aero ...." in Madvr settings. - MadVR v0.82.5 / Win7 SP1 auto update / i7-970 hexacore @3.9 / 24GB RAM 2000 Mhz / Nvidia GTX-570 / latest WHQL drivers (306.27) Last edited by Pat357; 26th September 2012 at 16:53. Reason: added title |
26th September 2012, 17:38 | #14189 | Link |
With v83.5, it doesn't show the D3D error and pause the video anymore from FSE to Overlay the first time, but now it fails to go back to FSE.
When I go in fullscreen again, I get "exclusive mode failed" in the OSD and when I check with ctrl+j, it says "fullscreen overlay mode". The madVR custom seekbar is there though. When it first launch directly in fullscreen, it says "fullscreen exclusive mode" like usual. Here's a debug log: http://www.mediafire.com/file/aqrdgcrw2n2l8df/madVR_log_SamKook_2012-09-26.rar Last edited by SamKook; 26th September 2012 at 17:41. |
26th September 2012, 17:52 | #14190 | Link |
Windows 8 RTM - madVR 0.83.5 dropped frame issues - Good with 0.82.5
Wanted to provide a little more detail to some performance issues I have seen with Windows 8.
Windows 8 RTM (64) Nvidia 560Ti Nvidia driver ver. 306.23 MPC-HC 1.6.4.6011 LAV Filters 0.51.3-53 madVR - Comparing 0.82.5 (with antiringing 6 updates) - 0.83.5 MKV Blu-Ray direct rip files tested - VC-1, VC-1i, H264, H264i material Problem: With 0.83.5 files begin and play correctly, but if you jump ahead or back a number of times all of a sudden frames start dropping, stuttering and it does not stop or correct after pausing. It is consistent. Go back to 0.82.5 and there are no problems. ... Cannot forward a log file or video sample because there is no crash or error indicated and have to move around a very large (20-40GB) file to see the issue. But it is consistent and always seen on this system and changing back to 0.82.5 always corrects the issue.
MPC-HC and MPC-BE (latest), MadVR 0.92.17, LAV 0.73.1 Intel NUC w_650 internal, Roku Ultra, Nvidia Shield, Apple TV 4K PLEX Server with QUADRO 2000 Windows 10 Pro (all latest updates) Last edited by blackjack12; 26th September 2012 at 18:10. |
26th September 2012, 18:06 | #14191 | Link | |
might just watch it on the TV downstairs, I just like to solve problems thanks for downloading my sample |
26th September 2012, 18:41 | #14192 | Link | |
26th September 2012, 19:50 | #14193 | Link | |
It's strange that when I click on Filters while viewing a still image, I see no source filter. However, in that filters list, there is an option which allows me to view Properties of the file (I am not sure if you referred to this filter). I have attached a file having the text from the Pin Info tab of that Properties window. Normally, when I play a video, I can see Lav Splitter Source as the Source Splitter. Please let me know if you need any more information. Last edited by omarank; 26th September 2012 at 19:59. |
26th September 2012, 20:19 | #14194 | Link |
Here is a picture during a big drop frame in FSE... no problem if I stay just in FS.
https://www.dropbox.com/s/ko26zqvp8ct0f0h/FSE.jpg I have also noticed that sometimes after few minutes in FSE it switch itself in FS |
26th September 2012, 21:55 | #14195 | Link |
Madshi,
When I try to past my yCMS settings in the foreseen "text-box", upon pressing the "Apply" or "OK" button, I get crash and an exception message like this : Code:
'0.42140' is not a valid floating point value. This makes that I can't make the calibration work atm : I'm forced to select another method to be able to press OK. The dissam looks like : Code:
005a9368 call -$199775 ($40fbf8) ; madStrings.RetTrimStr 005a936d mov eax, [ebp-$558] 005a9373 mov [ebp-$7c], eax 005a9376 mov edx, [$5c80e8] 005a937c mov eax, [ebp-$7c] 005a937f > call -$10ca5c ($49c928) ; SysUtils.StrToFloat 005a9384 fstp tbyte ptr [ebp-$90] 005a938a wait 005a938b fld tbyte ptr [ebp-$90] 005a9391 fstp qword ptr [ebp-$58] 005a9394 wait Complete crash-report : http://www.mediafire.com/?ow4p36klr55dxgt Last edited by Pat357; 27th September 2012 at 10:21. |
26th September 2012, 22:59 | #14196 | Link |
madshi, when you get to it please check if it's possible to make madvr work with the native Nvidia Rotation from the driver.
Basically how to reproduce the issue is to right-click Desktop, go to Nvidia Control Panel, Rotate Display, and pick e.g. Portrait (flipped). Then when playing with madvr the picture is just black, sound is ok. Thanks. |
27th September 2012, 01:10 | #14197 | Link |
Just letting you guys know...
Samsung S27A850T supports both 48Hz and 50Hz through Displayport at full 2560x1440. I'm on an Intel HD3000 BTW, surprised Intel actually allows custom refresh rates. |
27th September 2012, 01:43 | #14198 | Link | |
Kid for Today
it'd be great if someone created a thread for the mVR-related chit-chat coz I'm still in the market for a good bang/bucks flat screen myself....apparently to get killer native CR, the current market leader is Philips w/ the >5K:1 Philips 40PFL5507H for less than 600€. The firmware seems a far cry from what SONY offers(random black screens via HDMI), but the native CR kills and it does native 24p of course. I'm currently trying to resist really really hard Ideally I'd want something 27"-ish but these are usually PC monitors with sloppy onboard electronics and/or poor native CR, duh. |
27th September 2012, 03:15 | #14199 | Link |
Everyone using madVR needs to buy one of the 27" Korean monitors. I've been reading quite a bit about them and it seems like they really do what they say they do.
I'm about to buy this monitor: 27" S-IPS LED 2560 x 1440 Glossy LG Panel, overclockable up to 120Hz http://120hz.net/showthread.php?629-...le-Information |
27th September 2012, 06:54 | #14200 | Link |
@madshi
Can you please add the checkbox to turn off the wallpaper changer or it would be even beter if you could add a textbox which takes in any command line and executes it before and another textbox that executes a command line before exiting. Thanks! You are very appreciated madshi |
