11th January 2012, 14:39 | #8021 | Link | |
Sent from my Xoom using Tapatalk
11th January 2012, 19:14 | #8026 | Link |
i have a testing request to people using ATI cards. http://files.1f0.de/lavf/LAVFilters-...xva2-debug.zip Install that, set the configuration to use the DXVA2 decoder, and play a H264 file for a few seconds (preferably a 1920x1080 file to maximize the load) It will create a LAVVideo.txt log file on your desktop. Please paste that file to pastebin.com and link it here. Note that this version is probably unstable, definitely slow, and still a work in progress. Just want to know if the basic idea is going in the right direction. Thanks!
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 11th January 2012 at 19:19. |
11th January 2012, 19:18 | #8027 | Link |
Log for Radeon HD4670:
http://pastebin.com/Xnmfk3fg Log with 1920x1088 source: http://pastebin.com/HvyJm9st Last edited by fastplayer; 11th January 2012 at 19:23. Reason: Added log with higher load |
11th January 2012, 19:33 | #8028 | Link |
HD 5830 running latest 11.12 drivers
http://pastebin.com/AxLHTTp2 First impression, everything seems to be running smoothly and I get no frame drops/delays/glitches with MadVR. I verified that the GPU is changing to 400/900 gpu/mem speeds so that is the correct DXVA/2 UVD speeds. If you can get this running this would be E-mazing. If you need any more logs please let me know. I also have a 5450 I could test on if you need.
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S |
11th January 2012, 19:46 | #8029 | Link | |
1. "LAV Splitter v0.42 still doesn’t support segment linking yet, so playing series releases that have OP/ED as seperate video files won’t playback in each of the episodes" 2. "The 64-bit version is incompatible with madVR" 3. "Under “Internal Filters”, disable everything. You can leave some of the ones on the left active" 4. "Bonus: Adding ffdshow (Optional) ... Adding ffdshow will allow you to use its audio decoder (for filters + a more customizable mixer), ... Especially for older 480p and worse content (which isn’t likely to be encoded in AVC1), you can use the ffdshow deblocking or debanding filters to attempt to improve image quality this way." 5. "I recommend leaving this off unless you are having playback problems, because it prevents you from taking screenshots and makes the transition to fullscreen very ugly (It also messes up MPC-HC’s interface)" You obviously read enough to make a snarky, unhelpful reply... would it have been much more work to try to comprehend anything that was written there instead of just being a jerk? |
11th January 2012, 19:50 | #8030 | Link | |
Not sure why, but when i try to register LAVSplitter.ax, i got the failed to load module error. Registering video/audio decoders working, but when i try to play a video by using DXVA2, graphstudio crash. .44 working just fine.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 11th January 2012 at 19:58. |
11th January 2012, 19:53 | #8031 | Link |
HD 5850 Catalyst 11.12
http://pastebin.com/PVjAvU3u Running with madVR, queue filling up rather slowly, some drops depending on file, no artifacts. |
11th January 2012, 20:13 | #8032 | Link |
Mobility HD4650, Catalyst 12.1a preview, win7 x86
http://pastebin.com/a4eE3UX6 I'm so excited for this. Last edited by wanezhiling; 11th January 2012 at 20:15. |
11th January 2012, 20:31 | #8033 | Link |
Tested DXVA on my shiny new 7970, works very well. Good seeks, no corruption or dropped frames in the few 1080p files of mine.
I have also tested some 1080i streams and they working very well. One weirdness, with NV12 CPU use is at 0-1%, with RGB32 it goes to 15-20% on interlaced. http://pastebin.com/mYmTbaXQ Let me know if you want any other testing done.
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) |
11th January 2012, 20:33 | #8034 | Link |
The high CPU load on RGB is because its a debug build, its very slow.
I have enough tests btw, just wanted to see if it was working smoothly at all. Looking at those numbers, AMD definitely did something right with the 7970, the locking and copying time are nicely low.
11th January 2012, 20:34 | #8035 | Link |
Looks like everyone is doing all the testing already. Sweet. I have a 5870 I can test on later if you need more feedback. I'm running 12.1a preview, as well.
11th January 2012, 20:36 | #8036 | Link |
the clip you asked us to test last time, Test_clip_avc.1080i59.94.ac3.5.1.mkv also works without any issue with this build.
EDIT: MPEG2 and VC1 1080p also seem to work without issue and 10bit h264 crashes. I was hoping GCN was going to do good with this
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) Last edited by VipZ; 11th January 2012 at 20:44. |
11th January 2012, 21:32 | #8038 | Link | |
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 11th January 2012 at 21:34. |
