7th November 2005, 21:27 | #801 | Link |
Just to say I finally achieved to encod my wav file using BeLight, just by reinstalling the full package BeLight-0.22b8.exe from scratch.
There was probably some dll missing or mismatching during my first tests. Sorry for that. By the way, after my reinstall, I have no more display issue in the BeLight GUI (like reported by LoRd_MuldeR). Thanks. Marco |
7th November 2005, 23:27 | #804 | Link |
I've updated polish language file for BeLight. http://rapidshare.de/files/7328643/Polski.ini.html |
7th November 2005, 23:36 | #805 | Link | |
Works's fine. Thank's for your great job Kurt. Marco |
7th November 2005, 23:55 | #806 | Link |
Software Developer
Sorry Kurtnoise, but the problem (see screenshot) is still there even with the latest Build (BeLight-0.22beta_20051107.zip). I have deleted the INI file, but this didn't change anything...
@Marcovelo How did you solve the GUI problem? Last edited by LoRd_MuldeR; 7th November 2005 at 23:57. |
8th November 2005, 07:32 | #807 | Link |
Audiografix
Hello, I have the BeLight 0.2.2.0 beta 8. Itīs a fantastic tool for AAC but, when i move the mouse over the Batchwindow, the "DynamicComp" would be activate. But I donīt want the Dynamik Compr...
Thanks 7ven |
9th November 2005, 02:42 | #810 | Link |
XviD User
The latest daily build still has the issue wher Dynamic Compression is turned on when the mouse cursor hovers over the white queue box. Same issue as 7ven mentions above.
Edit- Also, the Belight process doesnt set its self to "idle" mode but the Besweet process does.
DFI NF4 SLI Expert | Opteron 165 CCBBE 0616 XPMW (9x325HTT=2.9Ghz) | 2x1GB G.Skill HZ (3-4-4-8-12-16-2T) | LG 62L DVD/CD | Geforce 7300GT | All SATA | Antec 650 Trio PSU | XP SP2 |
9th November 2005, 14:07 | #811 | Link | |
Swallowed in the Sea
ok, so I'll try to fix this issue asap.
but, Quote:
9th November 2005, 14:20 | #812 | Link |
XviD User
Options->Priority->Idle is set currently. Using the task manager I can see that Belight is in "Normal" mode and Besweet is actually in "Idle". Should Belight also be running at "Idle" priority?
9th November 2005, 15:49 | #814 | Link |
XviD User
Hmmm...but Belight is also consuming CPU cycles if you watch the task manager. Is it just for the gain cycle maybe?
