Old 16th September 2006, 03:31   #441  |  Link
Moitah
The problem was that it set the keyframe flag wrong for OpenDML index entries. The keyframe flag is a single bit inside the chunk size field, a stupid mistake in the code made it set several bits instead which messed up the chunk size field for non-keyframes.
I found another bug too, I guess you didn't see it because the second RIFF chunk in your AVI is pretty small, but it tried to fully read RIFF extension chunks into memory which usually will cause an out of memory exception.
Fixed version coming soon...
moitah.net
Moitah is offline   Reply With Quote
Old 16th September 2006, 09:22   #442  |  Link
ReinerSchweinlin
Thanx for keeping up the work on this excellent tool!
Old 16th September 2006, 11:02   #443  |  Link
rse
I found another bug too, I guess you didn't see it because the second RIFF chunk in your AVI is pretty small...
I was patient enough to watch the first 3 shown keyframes, but I didnīt test it to the end. (I suppose the second RIFF chunk to contain the part of the Video > 2GB?) It didnīt work anyways.
Thanks a lot!
My Site (German): videobasics.de
My Mediaplayer (German): rseplayer.rseweb.de
rse is offline   Reply With Quote
Old 17th September 2006, 01:53   #444  |  Link
Moitah
1.4.2 released.
moitah.net
Old 19th September 2006, 22:37   #445  |  Link
Sumsebiene
Ok i now answered my question which i had earlier in this thread by myself. Your tool really works ! Great job ! But it just worked with vlc-player for me. Media Player classic and windows media player same goes for winamp don't show the video file in 16:9. So i just changed to vlc player :O
Is this the same for you too ? Or with which media players should it work ?
Sumsebiene is offline   Reply With Quote
Old 19th September 2006, 23:05   #446  |  Link
Moitah
@Sumsebiene: It depends which DirectShow decoder you're using. It will work with XviD 1.1.0, and ffdshow if you have the "Use overlay mixer" and "Allow output format changes during playback" options checked ("Output" section in ffdshow config).
moitah.net
Old 20th September 2006, 11:48   #447  |  Link
Sumsebiene
ah big thx to you
Old 22nd September 2006, 10:15   #448  |  Link
Bear
I tried to add packed bitstream for some files, but I got this error message:
cannot pack a file with drop frames
How can I fix it?
Bear is offline   Reply With Quote
Old 9th October 2006, 09:57   #449  |  Link
altufaltu
I get following error with UnpackCL v1.2.1:
Loading: 73.7%Error: This is not a valid MPEG-4 video (startcode not found at beginning of frame).
The error got shifted to 74.3% when I made another .avi through VirtualDub (direct stream copy).
Please help me get rid of this error.
Thank you.
altufaltu is offline   Reply With Quote
Old 9th October 2006, 10:47   #450  |  Link
ReinerSchweinlin
Maybe your AVI-File needs re-indexing? Just a guess, but try loading it in VD with "extended options" in the "open video file" dialog. then chose re-index. Afterwards save it again usind "direct stream copy". Might help.
Old 9th October 2006, 22:49   #451  |  Link
Moitah
@Bear: There's not really anything you can do about it. I'll see if there's a better way to handle this for newer versions.
@altufaltu: The video is probably corrupt at that location. If you really need it unpacked, I think you're stuck with reencoding.
moitah.net
Old 10th October 2006, 08:44   #452  |  Link
altufaltu
Thanks for the help. I ran it through AVIFixed 2.0 b1 and now I get another error:
Loading: 98.5%Error: Too many VOPs in a frame.
Please help.
Old 10th October 2006, 11:57   #453  |  Link
Bear
I found the problem. I load the avi in virtualdub, I found some drop frame in the file, after I remove those drop frame, your program can pack the video without problem.
Is there any chance your program can handle drop frame as well?
Old 12th October 2006, 22:03   #454  |  Link
eXistenZ_69
@Moitah
I upgraded from MPEG4Modifier v1.3.4 to 1.4.2 a few days ago and noticed that unpacking the same avi in both versions results in files with different md5 checksums. The frame lists are identical though. Is this supposed to be like this? Has the non-OpenDML avi writing code been changed? Should I worry?
Kind regards,
eXistenZ_69
eXistenZ_69 is offline   Reply With Quote
Old 13th October 2006, 03:01   #455  |  Link
Moitah
@eXistenZ_69: The new AVI writing code is used all the time, not just for OpenDML, so it's normal for the files to be different than those written by previous versions. This is due to differences in the structure of the AVI files (padding or other small things) but the video/audio data are the same.
moitah.net
Old 13th October 2006, 18:47   #456  |  Link
eXistenZ_69
Ah ok. Hopefully there are no new bugs or player compatibility problems then...
Greetz,
eXistenZ_69
Old 19th October 2006, 13:13   #457  |  Link
jack3216
could you give me the link please to download MPEG4 Modifier v1.3.4
jack3216 is offline   Reply With Quote
Old 19th October 2006, 13:17   #458  |  Link
ReinerSchweinlin
check moitahīs sig
Old 19th October 2006, 17:59   #459  |  Link
jack3216
i have a video file which is not mpeg4 how can i convert it to use MPEG MODIFIER
Old 19th October 2006, 19:29   #460  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
If it's not mpeg4 you can't use it at all. You just re-encode with divx or xvid, setting the options correctly so that you don't need mpeg4 modifier afterward.
