27th July 2010, 09:09 | #41 | Link |
3 smaller bug fixes:
v0.29 (2010-07-27) . Fix small bug in ImgBurn Mode When Not Selecting Main Movie. v0.28 (2010-07-22) . Improve MPlayer hooking (and error trapping especially on VC1 video) v0.27 (2010-07-16) . Fixed tiny bug in tsMuxeR mode when selecting streams with only video. Showed as selected, treated as deselected. |
1st August 2010, 09:43 | #42 | Link |
New version 0.33 available.
v0.33 (2010-08-01) . tsMuxeR .Meta File Not Build Correctly When CLPI PIDs Where Out Of Order. example #9 German Version. Thanks To Sendmen For Noticing This. v0.32 (2010-07-31) . Version 0.9 Of Clown_BD MPLS Builder. *** Please Manually Delete OLD Version *** Thanks to mariner8611 for noticing these errors: - When MPLS file size smaller then CLPI file size, then times of 00:00:00.000 are used. - Display error on time differences which have the negative sign ("-" rather than "0") v0.31 (2010-07-30) . Don't call Clown_BD MPLS Builder When Creating Dummy Files With tsMuxeR. Thanks to mariner8611 for spotting this. v0.30 (2010-07-29) . Dummy MPLS not being built correctly. Thanks to mariner8611 for spotting this. |
10th August 2010, 07:52 | #43 | Link |
New version v0.35
v0.35 (2010-08-09) . The BDJO title District9 didn't work in ImgBurn mode. . Smaller & cosmestic changes. v0.34 (2010-08-01) . Added Mplayer Option -loop 0. Hopefully this will cure the none displaying of very short clips. . Hardcoded Don't Try To Call MPLAYER For Interlaced VC1 Movies. I Just Can't Get Mplayer To Respond, Even When It Crashes. . Added A Few Things To The .INI File. Mostly Are For Copy To HDD Mode: [Options] ConsoleWindowShow=N (Show DOS Box Y/N) ConsoleBufferHeight=1000 (Amount Of Space In DOS Box Buffer) DestinationPath=E:\ (Where The Copy To Hard Drive Will Be Saved) ISODestinationPath=F:\ (Where the ISO Will Be Saved) MainMovieTolerancePercent=15 (Highlight All MPLS As Main Movie Within (15%) Of The Longest MPLS) |
27th October 2010, 14:17 | #44 | Link |
v0.37 (2010-08-15) . Oopps, CORE Is Supposed To Be Optional. New Feature Was Always On. v0.36 (2010-08-15) . Added New Checkbox 'Core' To Extract SD Core From HD Audio Only (ie TrueHD->AC3 & DTS-MA->DTS) Not really recommended, but better than manually changing .meta file. I was wondering if anyone else has problems? |
14th November 2010, 20:14 | #45 | Link |
Does this program work with Blu-ray 3D discs?
I've got an ISO of Grand Canyon Adventure - River at Risk which shows as 24.0GB in Windows. When I try to use ImgBurn to burn it to a BD-R SL, ImgBurn says it is slightly too big. So I figured I would try this program and remove some of the opening studio logo movies that appear. But when I open the app and have it read the disc, without me unchecking anything, it shows that it is only at about 19.2GB (76.81%). So I am thinking that it is not handling the 3D streams correctly. Also, is there a way to have it just write an ISO file instead of burning it directly to disc? That way I could test it out before burning. Thanks! |
17th November 2010, 09:01 | #49 | Link | |
I haven't had a problem with burning Blu-ray 3D ISOs with ImgBurn, or building ISOs with ImgBurn from ripped Blu-ray 3D discs. |
17th November 2010, 09:12 | #50 | Link | |
3D disks have interleaving of files that needs to be supported by the software that creates the ISO. |
20th November 2010, 19:00 | #51 | Link |
v0.38 (2010-11-20) . Finally fixed problem with stand-alone players reported by: innersee http://forum.slysoft.com/showpost.php?p=276305&postcount=99 hoense http://forum.slysoft.com/showpost.php?p=277052&postcount=115 . Fix playback on Arcsoft TMT5 thanks to c627627 for the heads up http://forum.slysoft.com/showpost.php?p=287765&postcount=207 . Fix path to BDMV staying disabled after an invalid BDMV structure found . Allow all sub streams to be selected when tsMuxeR & CORE are checked
Blu-Ray Movie Only Copies : Clown_BD Blu-Ray Movie Only DVD Conversion : Clown_BD Blu-Ray Copies With Menus : Clown_BD BD Copier Last edited by mrr19121970; 25th November 2010 at 16:12. |
20th November 2010, 23:36 | #52 | Link |
Aging Video Hobbyist
I deleted the test setup that inspired my original comment, but I will look for another one and give 0.38 a try, yes. Whadja fix anyway? I do recall at one point that I'd actually copied an entire disc structure to hdd, and then pasted-in your dummy m2ts/mpls/clpi and that seemed to work, so I was puzzled why the BD I'd made with your tool didn't work, since it seemed to me it was doing exactly the same thing?
28th November 2010, 18:06 | #57 | Link |
v0.39 (2010-11-28) . Separate Audio and Subtitle languages for tsMuxeR auto select mode. Need these in INI: tsMuxeRLanguageSubs=English tsMuxeRLanguageAudio=English . Save Output_Format in INI as requested by c627627 http://forum.slysoft.com/showpost.php?p=287568&postcount=195 . Added feature to find/download MPlayer/tsMuxeR . Can now change output path in tsMuxeR mode in GUI . Open location of .BAT file in explorer |
5th December 2010, 15:56 | #58 | Link |
Hi Mrr, I have some questions and issues...
First, thanks for this nice software. Here is what I want to do. Keep the original menu and main movie only, with 2 audio tracks, I'm a french canadian but I like to have the original english track and the french track. I will burn the result to a BD-25, if it's too big I use BD Rebuilder. The issue I have is that if I use the TSMUXER option, to extract the data to my hard drive, it takes around 10 seconds then the window close automatically. It might be something with the batch file? What is weird, if I use IMGBURN and output it to an ISO, the ISO is fine, I burn it and get exactly what I want. Using the exact same option checked using TSMUXER, it does work. Since I need to pass it through BD Rebuilder when it's more than 25GB, I need the BDMV folder, an ISO doesn't work. If you can help me that would be appreciated. thanks. |
