14th May 2006, 04:14 | #42 | Link |
Mr. Sandman
0.2.3.2138. It's 5AM and im going to bed...
tomorrow i'll build it.
14th May 2006, 17:12 | #44 | Link | |
BeHappy/MeGUI developer
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
17th May 2006, 13:56 | #46 | Link |
Mr. Sandman
ok... some bugs im working to fix:
- when selecting avisynth input the 2-pass options should be disabled. - when vbr is selected the 2-pass options should be disabled. - when input folder is too long (for example "c:\documents and settings\username\documents\my music\artist folder\artist album\very long song name.wav"), when clicking on destination folder browser button and access violation occurs. also, what about this layout?
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 17th May 2006 at 14:48. |
17th May 2006, 16:33 | #48 | Link |
Mr. Sandman
ok, i need just to fix some issues then i'll publish the source.
17th May 2006, 18:36 | #49 | Link |
Life's clearer in 4K UHD
I keep finding the same anomaly with all the Nero GUI's I've tried so-far and don't know whether it's the GUI's or Nero's encoder that's causing it!
What I'm tying to do is generate an 6Ch AAC-HE encode at 128Kbps CBR from this 6Ch WAV source. Whenever I select the AAC HE option I obtain an encode with a sample rate of 48.0KHz not 24.0KHz. And If I select AAC v2 (which I'm assuming is AAC +PS), I don't obtain an encode at all Cheers
17th May 2006, 18:46 | #51 | Link | |
17th May 2006, 18:56 | #52 | Link |
Well, this is theoretically possible but in practice forbidden by the MPEG standard (because it would be impossible to predict the position of downmixed channel elements in old decoders)
However, fortunately, MPEG is working on a parametric multichannel solution (MPEG surround) |
17th May 2006, 19:06 | #53 | Link |
Thanks for the confirmation Ivan...
Simple NeroAACEnc GUI uses the term "HE v2", whereas MeGUI uses the term "HE-AAC+PS".... To be honest I was not sure what the option was supposed to be offering - ie: Parametric stereo or something new! Cheers
17th May 2006, 20:13 | #54 | Link | |
nobody's nobody
. avs2wav xx.avs has some bug in 44.1k(6ch) source but can output to wav with parameters (.SSRC(48000).SSRC(44100) is my temporary fix, it also requires msvc*70.dll in the path). . bepipe --script "import(^xx.avs^)" > xxx.wav can also write to a (temp) wav(redirecting). . using xx.avs for the input will be useful if you want some preprocessing with avisynth DSPs and methods. . both can be launched in the frontend to write a temporary wav to be used for 2 pass encoding for the nd cli encoder. . it may require a task sequenceng(temp wav write-> cli encode) using a command script or any proper method . these method require 3i + 1.5o of disk accessing overall, heavily resource taking. ...
u know everything in the end, or now if aligned... no right(x).right(y) pls. it's confusing... : phase-shift /Jun.2006 |
18th May 2006, 01:53 | #55 | Link |
Mr. Sandman
0.62
18.5.2006 - added: mp3 and ogg vorbis in "add files" dialog - modified: avisynth input thru bepipe enabled by default - fixed: tri-state code - re-organized controls on the main form sources: http://www.webalice.it/f.corriga/sng/sng_0.62src.7z i didnt fix the access violation with very long paths. also, has 2pass CBR any sense? Ivan said the 2pass mode works only for -br... and should i add the -ignorelength option?
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 18th May 2006 at 02:54. |
18th May 2006, 02:29 | #56 | Link |
DVD Magistrate
@imcold
thanks for the new 0.6.1 build at the start of this thread....nice icon!!!!!!! However, a bug has appeared now....if I choose an output directory, no matter what I browse to the GUI says it is invalid and defaults to the folder the source is in. Easy fix maybe? |
18th May 2006, 02:36 | #57 | Link |
Mr. Sandman
ehrr... sorry i didnt realize 0.61 was already posted...
changing version to 0.62... EDIT: done @imcold: i dont have the aac icon...
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 18th May 2006 at 02:55. |
