22nd March 2006, 14:59 | #821 | Link |
@flipflink
If you have Nero 6 installed it should find it and not ask, if you do not use AAC it should not ask because it's not needed so even after a quick code review I really don't know what's going on, please submit a bug report (in the main menu click Help/Send Bug Report) and tell me the exact message.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 22nd March 2006 at 15:02. |
22nd March 2006, 16:21 | #822 | Link | |
-Moat |
22nd March 2006, 19:00 | #824 | Link |
@agonia
It's not supported, how about using single CD or DVD?
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 22nd March 2006 at 19:04. |
22nd March 2006, 21:45 | #825 | Link |
TeMa=) team member
Location: Universe, Galaxy, Solar System, Earth, Russia, Moscow
Mp4box can split mp4's. There should be some tools for avi and mkv too...
I prefer one-large-file way though.
Without effort, you can't even pull a fish out of the pond. Without a pond you can't pull it out even with effort. |
23rd March 2006, 08:22 | #826 | Link | |
You can choose how to split : by size or duration It's possible to mux (video, audio, subtitles and chapters), split&join and extract! |
25th March 2006, 09:14 | #828 | Link |
For some reason, when I'm muxing an AC3 file with my project using staxrip, the audio gets cut off at the end of the file, but only when I encode on my laptop, my PC doesn't have any problems. On a 10-minute video, 1minute and 30s was cut off the end. AVIMux-GUI works fine, wondering if there's anything I can do about it.
25th March 2006, 17:01 | #829 | Link | |
FFmpeg fan
Hellfred |
25th March 2006, 19:05 | #830 | Link |
Can you give a brief explaination on when and how to use "PostProcessing mode" (now called Batch mode)? I use to encode several video during the night with almost the same parameters.can it be useful for me?
26th March 2006, 06:28 | #831 | Link |
Now it won't work on either computer, it cuts massive amounts of audio off of the end, a 21minute video yielded a 5minute ac3 file. This is extremely annoying and is the fault of ProjectX, for one, why is it necessary as vdubmod can demux ac3 files from mpeg2 streams, how do I set staxrip to use vdub to demux the mpeg2 stream instead of ProjectX? Or if I can fix ProjectX that will work as well, but what could be wrong with it, is my java version too old or something? Maybe too new?
J2RE SE v1.5.0_06 EDIT: I just disabled the ProjectX section of the performs, DGIndex automatically demuxes the AC3 audio anyway, what exactly is the point of ProjectX? Are there audio formats VDubMod and DGIndex won't demux? Last edited by DiJayy; 26th March 2006 at 07:22. |
26th March 2006, 07:53 | #832 | Link | ||
26th March 2006, 11:06 | #834 | Link |
@DiJayy
That means both, ProjectX and DGIndex fails on your stream, you can do the following things:
27th March 2006, 04:22 | #835 | Link |
i'm running into an odd problem with some avi files I'm trying to demux and convert to x264. The files in question will open up in virtualdub and then it comes up with an error saying failed to decompress frame 0. These are Xvid files and I have Xvid installed.. not sure what else to do at this point in time. Any suggestions?
27th March 2006, 09:36 | #836 | Link |
stax, just a suggestion also for your own site: on the support page you nicely mention all the supported formats for the output files. wouldnt it make sense to also mention all supported formats for the source files? or is there a legal reason not to do so?
greetings - heinz - |
27th March 2006, 09:47 | #837 | Link |
Hi Stax, once we talked about possibility of including
mp3 5.1 (Aud-X) format in your software. You requested a CLI exec. It has been prepared (big kudos to Dimzon for it). please follow the link: http://www.gotdotnet.com/workspaces/...4-b0999e8e223e and let me know if this is ok.
Aud-X MP3 5.1 Format |
27th March 2006, 11:42 | #838 | Link |
hoppla, i admit i am still trying things out (and wildly reading everything here in the forum), but this
does not look right, does it? encoding a WMV file into AVI, using strictly default seting of STAXRIP. worked fine, but ... - after two passes STAXRIP stops with the NEXT button telling me file already exists, wants to overwrite it, and starts entire process anew? and again, and again? shouldnt it somehow stop with a DONE mssg or similar? - worse: orginal file size 200MB, resulting AVi is 0MB! what have i done wrong, or where is my thinking wrong? greetings - heinz - Last edited by heinz57g; 27th March 2006 at 11:45. |
27th March 2006, 12:40 | #839 | Link | |||
@Zorrander
What happens if you open the files manually in VirtualDub? Quote:
@3dsnar I can add it, maybe you and dimzon can give me some tips in case there is no good documentation. Quote:
27th March 2006, 13:11 | #840 | Link | |
please follow this thread, and Dimzon or I will be able to help http://forum.doom9.org/showthread.php?t=109226 I think that if you download the project you will find information on the arguments used. Thank you.
gui, h.264, h.265, hevc, mkv, x264, x265 |
