10th April 2011, 16:01 | #81 | Link |
The artifacts don't come from DitherPost, the denoising stage is clearly the cause here... Try to keep a or h at its original value, or even both? I don't know exactly how these parameters affect the algorithm.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding |
10th April 2011, 19:49 | #82 | Link |
New Dither version (1.6), some important changes :
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding Last edited by cretindesalpes; 10th April 2011 at 20:01. |
10th April 2011, 22:40 | #83 | Link |
Great to see an update!
I have a question on the new utility functions. Would dither_convert_8_to_16 be able to replace the blank clip + stackvertical inside of gradfun3? Is there any other ways to improve gradfun3? I added a custom smoothgrad since I did not like the results of the orignal smoothgrad inside of the script (it was causing weird banding halos). |
10th April 2011, 23:43 | #84 | Link |
Yes, that's exactly what it does. But it's just a convenient way to write it in a script, it gives the same result and won't improve anything in GradFun3.
11th April 2011, 03:59 | #85 | Link |
I did a few dozen tests, tweaking sx,sy,bx,by,a and h, even removing MT(). None of them sort the artifact, furthermore I tried dither2pre to "gain" more accuracy but what I got were more artifacts, check the lineart. (h is quadrupled according.)
old-workflow dither1pre dither2pre Im gonna test dither 1.6 now so I can tell you. edit: same results
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 12th April 2011 at 04:53. |
11th April 2011, 08:45 | #86 | Link |
Thank you very much for testing and helping me to improve the functions. I'm going to rewrite Dither1Pre to make the "slices" overlap, you'll tell me if it works better when it's ready.
15th April 2011, 05:39 | #87 | Link |
to me "Dither+SmoothGrad" seems like the best option. i would like to use it but cant determine from the help file what exactly you used/did. if it helps i usually denoise using fft3dgpu/fft3dfilter and sharpen using LSFmod before debanding.
16th April 2011, 21:45 | #88 | Link |
Color banding and noise removal
im using a condensor mic to record samples, and theres a bit of noise in the background, i use audacity, but the noise removal algorithm isnt very good.
is there any software that does this better? thanks. _________________ God rest ye, little children; let nothing you affright, For Jesus Christ, your Saviour, was born this happy night; Along the hills of Galilee the white flocks sleeping lay, When Christ, the Child of Nazareth, was born on Christmas day. http://www.chung-sim.com/omron.3g3jv.html |
27th April 2011, 22:51 | #89 | Link | |
Dither upgraded to v1.7. Changes:
but replace DitherPost (mode=2) with SmoothGrad (radius=16, thr=0.25, elast=2).DitherPost ()
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding Last edited by cretindesalpes; 27th April 2011 at 23:27. |
29th April 2011, 12:52 | #91 | Link |
You probably have a DitherPost() too many. Also make sure you have the latest Dither version. A few default parameters have changed recently and I updated the script in the post #8 accordingly.
29th April 2011, 17:17 | #92 | Link |
This is what I use
FFT3DGpu (Sigma=1) DitherPost (mode=2) Function zzz_denoise (clip src, float "sigma", int "thr", bool "mask", int "sad") { sigma = Default (sigma, 16) thr = Default (thr, 5) mask = Default (mask, False) sad = Default (sad, 200) w = src.Width () h = src.Height () # Motion analysis super = MSuper (src) super_a = MSuper (src.TTempSmooth ().RemoveGrain (12)) fwd_vect_3 = super_a.MAnalyse (isb=false, delta=3, overlap=4) fwd_vect_2 = super_a.MAnalyse (isb=false, delta=2, overlap=4) fwd_vect_1 = super_a.MAnalyse (isb=false, delta=1, overlap=4) bck_vect_1 = super_a.MAnalyse (isb=true, delta=1, overlap=4) bck_vect_2 = super_a.MAnalyse (isb=true, delta=2, overlap=4) bck_vect_3 = super_a.MAnalyse (isb=true, delta=3, overlap=4) fwd_comp_2 = src.MCompensate (super, fwd_vect_2, thSAD=sad) fwd_comp_1 = src.MCompensate (super, fwd_vect_1, thSAD=sad) bck_comp_1 = src.MCompensate (super, bck_vect_1, thSAD=sad) bck_comp_2 = src.MCompensate (super, bck_vect_2, thSAD=sad) # Spatio-temporal denoising using modified dfttest c_dft = Interleave (fwd_comp_2, fwd_comp_1, src, bck_comp_1, bck_comp_2) c_dft = c_dft.dfttest (sigma=sigma, lsb=true) # Double height c_dft = c_dft.SelectEvery (5, 2) # Temporal-only denoising using modified MDegrain c_deg = src.MDegrain3 (super, bck_vect_1, fwd_vect_1, bck_vect_2, fwd_vect_2, bck_vect_3, fwd_vect_3, thSAD=sad, lsb=true) # Double height # Spatio-temporal denoising smoothes too much the details, # therefore we use pure temporal denoising on edges or detailed areas. edge_src = c_deg.Crop (0, 0, w, h) edge_mask = edge_src.mt_edge (mode="prewitt", thY1=thr, thY2=thr) edge_mask = edge_mask.mt_expand () edge_mask = StackVertical (edge_mask, edge_mask) # Double height c_hyb = mt_merge (c_dft, c_deg, edge_mask, luma=true, y=3, u=3, v=3) return (mask ? edge_mask.GreyScale () : c_hyb) } |
29th April 2011, 18:33 | #93 | Link |
Use zzz_denoise(). This function does almost all the job, with SmoothGrad. DitherPost only converts the 16-bit result into a regular 8-bit dithered clip.
zzz_denoise() SmoothGrad (radius=16, thr=0.25, elast=2) DitherPost () Code:
FFT3DGpu (Sigma=1) GradFun3 () Code:
Dither2Pre (flt="FFT3DGpu(Sigma=4)") SmoothGrad (radius=16, thr=0.25, elast=2) DitherPost ()
30th April 2011, 09:53 | #95 | Link |
Yes, use GradFun3 to deband only.
3rd May 2011, 19:07 | #97 | Link |
cretin, the error I was having was caused by MT inside dither1pre. I had to change splitvertical to true also to make it aware dither was changing the size.
On a note, before this I tried stacked=false and it gave me temporal artifacts. Finally after an afternoon battle it seems this code is what it works, no problems for encoding either. Code:
MT("""Dither1Pre(flt="tnlmeans()",stacked=true)""",2,2,true) DitherPost(stacked=true,prot=false)
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
10th May 2011, 21:54 | #98 | Link |
cretindesalpes can you check your mod16 of Mvtools?
Looks like all (latest mvtools-2.5.11.2-mod16a.zip and previous) version have some bug with tsadc. tsadc always == tsad. you can check it if you made big tsad (about 600 or more) and try low tsadc. UV channel will be bad on original mvtools-2.5.11.2 all work well. thanx! |
11th May 2011, 08:03 | #99 | Link |
Indeed there was a bug, thanks for the report. I'll release a fixed version soon.
11th May 2011, 22:10 | #100 | Link |
Dither 1.7.1 update. Changes:
color banding, deblocking, noise reduction |
