1st August 2008, 03:08 | #1261 | Link |
ffdshow
Well, actually, I used ffmpegsource the first time around, but that was before I realized CoreAVC was at fault :P (at least I think that's the case... it might be something else, but ffdshow works and CoreAVC doesn't) |
1st August 2008, 03:09 | #1262 | Link |
@rebkell
I'm not optimistic about solving this for you. It appears that the TS cutter is orphaning frames from their required SPS/PPS's. I'm not surprised that a naive TS cutter would do that. I'm sorry to say it, but it's not my problem if another application generates an insane stream. You could mention this to the authors and see if they are interested in doing anything about it. When I get my unit and need to edit streams, I'll write a proper AVC TS cutter. Last edited by Guest; 1st August 2008 at 03:22. |
1st August 2008, 03:20 | #1263 | Link |
Version 1.0.0 alpha 32
* Support Hauppage HD PVR streams generated with no IDRs (default configuration). You must enable the option "Treat I as IDR". Delete your previous INI file!
http://neuron2.net/dgavcdec/dgavcdec.html And, oops, I forgot to bump the DGA file version, so please re-create your projects. Last edited by Guest; 1st August 2008 at 03:24. |
1st August 2008, 03:35 | #1264 | Link |
@Comatose
The Hauppage stream you provided is 1280x720p 59.94. When you capture 1920x1080, is the AVC stream field encoded? Do you have a sample for me, please? EDIT: I found some samples. They are PAFF TFF. The great news is that libavcodec handles them just fine and does not generate the famous artifacts for some PAFF encodings! Last edited by Guest; 1st August 2008 at 03:54. |
1st August 2008, 05:05 | #1266 | Link | |
Until then, I'll try to figure out an alternative solution, or just store all my recordings uncut. |
2nd August 2008, 12:35 | #1269 | Link | ||
Since you're asking things of me, can I ask you to help close out the issue you raised: Quote:
2nd August 2008, 18:49 | #1273 | Link |
I have a question about the avs template and the command line interface. I haven't been using the avs template, but I plan to in the future, but I will want to use it with the command line and I didn't see any way to specify the template file. I'm figuring I'll probably only have two or three templates that I'll use, but was wondering if there is a way to specify a template file to create the avs when running the indexer from the command line?
If I missed it in the docs, I apologize. |
2nd August 2008, 18:58 | #1274 | Link |
Pain and suffering
H.264-2007-11 updated spec AR issue
Illegal aspect ratio.... or not.
(As i just reported to dvbviewer aswell off topic: http://www.dvbviewer.info/forum/inde...howtopic=28515) Here is the error: Here are the specs: http://www.itu.int/rec/dologin_pub.a...F-E&type=items Here is a sample: http://files.x264.nl/luxe_tv_hd_ar_4x3_or_16x9.ts After clicking Yes: DGAVCIndex.exe crashes: AppName: dgavcindex.exe AppVer: 1.0.0.0 ModName: libavcodec.dll ModVer: 0.0.0.0 Offset: 000b657d (off topic again: Upcoming CoreAVC has this issue fixed Sorry for the 2 unrelated offtopics... but the more people know, the less redundant reports will be made, edit if needed!) |
2nd August 2008, 22:05 | #1276 | Link |
It doesn't crash for me in alpha 33 after dismissing the errors, but I'll fix it. The spec was updated to add two more aspect ratios and all the decoders have to be revised accordingly.
2nd August 2008, 22:07 | #1277 | Link |
Uhm, reporting back ;_; It doesn't seem to be working too well :x (talking about the sample I gave you before)
Last time I only tried seeking the HD PVR ts in DGAVCIndex, which was fine, but there's something weird with the output ;_; Using a certain scene as reference, the scene started at frame 573 (9.560s in) with DGAVCIndex and at frame 601 (10.027s in, I seeked frame by frame from frame 0) with ffmpegsource. The audio is not in sync with the video produced by using AVCSource() on the DGA, but it is with the FFMpegSource video. DGAVCIndex specifies a -12ms delay when demuxing the audio, but the difference is larger than 12ms. I'm uploading a 41MB sample with about 2000 frames (from frame 0). edit: http://www.mediafire.com/?giik5lq05y7 Note that when the first scene after the logos starts, the audio is silent but once it starts it should be pretty obvious what the audio should sync to (the boots). Last edited by Comatose; 2nd August 2008 at 22:38. |
3rd August 2008, 14:12 | #1278 | Link |
You haven't given me your entire process. I need your script and I need to know what the final format is and how you played it.
Here is what I did. I made a project with DGAVCIndex a33, demuxing the aac audio. Then I converted the audio to WAV using: faad -o out.wav sample2.aac Then I made this script: vid=AVCSource("sample2.dga") aud=WAVSource("out.wav").delayaudio(-0.012) audiodub(vid,aud) Now, a) I play sample2.ts directly in VLC 0.8.6c, and b) I play the script in BSPlayer. The result is that the sync is identical between the two. Thus I cannot duplicate any issue. Regarding ffmpegsource(), did you notice that the first 30 frames were garbage? Last edited by Guest; 3rd August 2008 at 14:29. |
3rd August 2008, 14:56 | #1279 | Link |
hello, i noticed there is some changes in PAFF decoding http://svn.mplayerhq.hu/ffmpeg/trunk...odec/?view=log
i want to try compile libavcodec.dll from latest ffmpeg svn, but i need to change some version string (libavcodec.txt), so DGAVCIndex accepts libavcodec.dll. Can you guide me how to do this change, please? |
3rd August 2008, 15:02 | #1280 | Link |
I'm working on that myself right now.
I need to diff my lavc tree against the old version I used to get you the lavc diffs I made. But it won't help you because I haven't released the DGAVCIndex code that checks the version number. And it would be a bad situation if you made different lavc dll's with the same version number. Be patient for a few days. Upgrading lavc is my top priority right now. |
