11th May 2014, 09:45 | #42 | Link |
@TurboPascal7
I noticed that the order parameter in SangNom2 has a different mapping than the original SangNom. Is that how you intended to be? The options are just inverted: Code:
SangNom: SangNom2: 0 - bottom field 0 - both* 1 - top field 1 - top field 2 - both* 2 - bottom field *Both fields are kept but DoubleWeave() must be called beforehand line 612 - required Line 616 - width |
11th July 2014, 22:37 | #44 | Link |
Is there any particular reason everytime I try to use MAA2 it says
There is no function named "SangNom2" (MAA2.avsi, line85) (MAA2.avsi, line57) I know I have Sangnom2.dll installed correctly and everything it needs to run. It works on my friends computer and my other laptop but wont work on this computer. EDIT: It turns out it was Microsoft Visual C++ (x86) was needed in order to use the newer 0.35 version of MAA2 with Sangnom2. Last edited by killerteengohan; 12th July 2014 at 23:20. |
11th June 2016, 10:01 | #45 | Link |
Still hasn't been updated. Is it not called fturn any more in Avisynth+? I get an error if it's called. Saw a previous post with a user having a similar issue and stating that turn worked fine, so I renamed all instances to just turn and it's working but unsure if that's correct.
11th June 2016, 10:26 | #46 | Link | |
15th August 2023, 05:45 | #47 | Link |
SangNom2 0.6.1
Throw error if YUV420 height is not mod4. |
