16th June 2019, 17:17 | #541 | Link |
I have never seen rigaya posting the source code only.
He always releases binaries too.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
19th June 2019, 22:19 | #543 | Link |
Hello, today I updated windows to version 1903 and since then I have a problem with KNLMeansCL. I also use QTGMC as a very good denoiser and now it doesn't work. Nothing but update I did.
The KNLMeansCL.dll in the folder is and the path in the script is also correct. Don't know where the problem is? Thank you. |
19th June 2019, 22:27 | #544 | Link |
Noob
install gpu drivers
install c++ pack maybe from here https://github.com/abbodi1406/vcredist/releases if it still doesn't work, delete this file staxrip/apps/plugins/knlmeans/knlmeans.dll |
19th June 2019, 22:30 | #545 | Link | |
Card: GT 1030 Driver: 26.21.14.3064
20th June 2019, 16:28 | #546 | Link | |
Then I thought it might cause an old gpu driver - I had 399.24, I got an Asus Strix 1080Ti. After installing the latest version of 430.86 KNLMeans works as before. Thank you both for your advice! |
21st June 2019, 20:17 | #547 | Link |
Really hope I'm asking in the right place. Sorry if this isn't the spot, please just tell me where to go.
I wanted to ask if anyone can verify I did this right before spending weeks or months doing this wrong. Is it possible to look at my sample and log to make sure I encoded this 1080p copy from a 4K source correctly and that the HDR info was converted to SDR correctly? This is just one chapter from the movie and I ran tests for that last 24 hours using different filters because I wanted a light degrain and I didn't have much experience with filters. I made 12 different copies each with different filters but I think this one might be the one I like best. Did HDR convert correctly? Does anyone recommend a different filter than KNLMeansCL Medium? StaxRip : 2.0.2.3 Windows : Windows 10 Pro 1903 104 MB chapter 1 file here: https://www58.zippyshare.com/v/pTNgOOPo/file.html Log file: https://www70.zippyshare.com/v/6n2NkxGO/file.html MediaInfo from result:https://www31.zippyshare.com/v/I5VsTDT5/file.html |
21st June 2019, 20:27 | #548 | Link | ||
21st June 2019, 20:47 | #550 | Link | |
I don't see DGDecNV as an option so I assume its something I have to download and add? Is it downloaded from here? http://rationalqm.us/dgdecnv/dgdecnv.html |
21st June 2019, 20:57 | #551 | Link |
Useful n00b
That's correct for DGDecNV and DGDenoise. For DGHDRtoSDR go here:
http://rationalqm.us/hdr/ DGDecNV requires a donation. DGHDRtoSDR is freeware. If you use the latter stand-alone then you will need a source filter that delivers high bit depth. DGSource() is the natural choice (part of DGDecNV). Last edited by videoh; 21st June 2019 at 20:59. |
21st June 2019, 21:15 | #552 | Link | |
GPU is GTX1060 Last edited by MrBrownCow; 21st June 2019 at 21:21. |
23rd June 2019, 16:36 | #554 | Link |
@MrBrownCow
The filter menu can be customized by selecting 'Profiles' in the menu, the format is INI/TOML like, you would add something like this: Code:
[Noise] DGDenoise = DGDenoise() Code:
[Filter category] Filter name | sub menu = LoadPlugin("DLL path") Filter()
24th June 2019, 02:34 | #555 | Link | |
Thank you stax76. I added the following under the [Noise] section but I'm not sure if I did this right. Code:
[Noise] DGHDRtoSDR | sub menu = LoadPlugin("C:\StaxRip-x64-2.0.2.3-test\Apps\DGHDRtoSDR_1.12\DGHDRtoSDR.dll") DGDHDRtoSDR() DGDenoise = DGDenoise() |
24th June 2019, 03:23 | #556 | Link |
I have a question about resize.
My video is 4K 3840 x 2160. I want to resize to normal HD 1920 x 1080. When I slide the Staxrip resize bar to left, it can go to 1924 x 1084 and not 1920 x 1080. Why? My Output Mod is set to 4. |
24th June 2019, 07:48 | #557 | Link |
Either use the arrow keys or the menu.
24th June 2019, 09:27 | #558 | Link |
The arrow keys do not work, at least in staxrip 2.0.2.0.
What do you mean use the menu? Do you mean change it by hand in the boxes? In that case it does not respect the aspect ratio. If you change one number by hand, the other does not change accordingly. Also the resize target is not always 1920 x 1080. Sometimes it's some other aspect ratio and you can't currently resize by slider or hand correctly in staxrip user interface. Something is broken in staxrip user interface for resizing. |
24th June 2019, 13:50 | #559 | Link |
The menu shows when you click on the resize group box header, when you mouse hover over text and the text gets bold then this is an indication that there is a menu.
What will also work is click on the slider to give the slider focus and then use the left right keys. I don't know what else can be done to make it more intuitive.
24th June 2019, 15:11 | #560 | Link |
Thank you very much. I found the menu when it gets bolder and was able to choose 1920 x auto. That's good enough for me.
One last thing, how to crop visually? I want to crop after resize and not before. When I click on the crop menu on the top, the preview shows the original 4K resolution to crop. Even when I move down the Crop in the AVS Filters menu under Resize, the crop menu shows the original 4K image and not the resized 1080p. How can I crop visually the resized video in Staxrip? Update: The arrows work! Because it is 4K it takes a long time, that's why I didn't notice. When I hit left on the resize bar, I have to wait 8-9 secs for it to go one step. Last edited by Atlantis; 24th June 2019 at 19:27. |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
